Engine conversions
8 posts • Page 1 of 1
Engine conversions
I have a few ideas for my fezzy van i can get a cossie lump but whats the cheapest price to have fitted or a zetec 2.0 turbo or turbo my rs1800 and suggestions and prices would be a help,cheers.
- robsrs
2.0 Zetec - £350
Turbo Conv - £1500 - £4000 depending on whether u do the work urself or not. I've seen someone turbo a 1.8 Zetec for £900.
- chumkila
- Dirty Post Whore!
Yeah zetec turbo is only for people who have a lot of money and can pay someone to do it, or if u are handy at engine building then you could probably considerably reduce the costs by having a go yourself but at some point expensive management setup is needed. I know people on here have done it so somebody must know more?
- moulder
visit Tony Pastie's site - http://www.zetec-turbo.co.uk/
- chumkila
- Dirty Post Whore!
chum tony uses a compression plate
ask sunny what he thinks of using standard zetec cast pistons in a turbo engine.
BANG will be your answer
- MadcatCraig
- BANNED SELLER
turbo zetec will turn out to be alot of money considering u have to modify the engine to accept the turbo, then modify it even more to get more power out of it...once all thats done, u have to make sure all the fuelling is up to spec...and more than likly gonna have to spend mega money just for the fuelling and a correct map. To find out how much just for the map, ask Sunny howmuch he has to pay for a mapping session!
howmuch can u do the cossie conversion for?? im sure the zetec turbo option will be cheaper than that??
bassboy
bassboy
- bassboy
- Authorised Trader
MadcatCraig :chum tony uses a compression plate
Sunny's original 2.0ZVH motor that he had for ages used to run std zetec cast pistons, and ran for 90k miles i believe 100% reliably. And at even 10psi, it was a weapon (videos confirm this).
For a 16v engine, cast pistons are not an option, as std ones will have a CR that is FAR FAR too high for turbo usage (9.8:1).
First EECIV 'plug n play' SECS S8
- PhilM
- chumkila
- Dirty Post Whore!
