Engine Mounts
6 posts • Page 1 of 1
Engine Mounts
Hi there!
Does anyone has changed the engine ou gearbox mounts to make less "cockpit" vibration?
My diesel engine makes the car vibrate as hell, but the mounts seem good! what if mk4 or mk5 mounts are better designed to make less vibration?
Thanks!
Thanks!
- So_SiMpLe_
Re: Engine Mounts
But wouldnt they be totally different, because i'd assume they'd have a different gearbox ?
*theoreticly speaking*
- Sai007
Re: Engine Mounts
So you mean that for the same 1.8d engine the mk4 and mk5 gearboxes are different from the mk3?
I suppose that the engine and gearbox mounts are fitted in exactly the same place as the mk3...
Thanks!
Thanks!
- So_SiMpLe_
Re: Engine Mounts
You could use lower spec engine mounts but throttle response will be a bit jerky if they can't cope with the torque.
- Tweek
- Your car: VW Golf GTD
Re: Engine Mounts
Yes that's a fact, but that kind of engine mounts are not made by ford! Aren't they?
- So_SiMpLe_
Re: Engine Mounts
I don't get that?
- Tweek
