Engine suggestion..
6 posts • Page 1 of 1
Engine suggestion..
I should have my car running by the end of this week...
But need some advice on a few things.
Spec is
Standard bottom end
Standard head
Piper cam
Vernier
Beige injectors
Cossie pump
195 collins chip
Stage2 T3 turbo
Boost.. Was going to run at 7psi.. but been told can run 10-12 fine with this kinda setup
Chip - Should I run it til I get it setup (about 2 weeks) or leave it out and use it then
Setting up.. Who around SW London would set the fueling up properly... ideally would prefer a RR setup so its all on diagnostics equipment.
Spec is
Standard bottom end
Standard head
Piper cam
Vernier
Beige injectors
Cossie pump
195 collins chip
Stage2 T3 turbo
Car is back...
- AndyBlackFRST
- BANNED SELLER
Hi andy...you could try Power Engineering... if not take a trip to Grove Garage? the problem with RR setup's is that they dont simulate a real road and real conditions...if you can...try to stretch for a custom map...that way you know things are safe!
IMO, u will be able to run more boost however the intercooler is the soft spot if its standard as anything more and the ACT's will be through the roof
i know people running 16-18psi on similar setups
bassboy
bassboy
- bassboy
- Authorised Trader
Andy i would leave it until you've set the fuelling up. I'd say just pop into Power Engineering and get it done.
- chumkila
- Dirty Post Whore!
Thanks for the replied you two..
Wanted to get setup on RR so I can make sure fueling is right.. then when i've built my other engine I will fit it and get a live map done.
Car is back...
- AndyBlackFRST
- BANNED SELLER
10 - 12psi should be more than enough fun and keep things reliable
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
