Engine Swap
12 posts • Page 1 of 1
Engine Swap
I know very little about engines so excuse my naivity, I have a 1.1 or 1.3 carb engine in my fiesta mk3.5, i am unsure which tho lol registered as a 1.1 but the engine says 1.3 but anyways that wasnt my question. What would be the easiest engine that could be fitted into this car without having to mess about with mounts, wiring loom or fuel injection?? would the engine from a mk2 xr2 fit straight in and mate to the gearbox? also could i use the ecu from the xr2?? I Know some people that are competant with stuff like this and would be able to fit it all for me, but i just want to know what to look out for as i literally just want a straight swap with engines with minimal effort as im sure some of you can apreciate lol
- YoungRogue
Re: Engine Swap
mark 2 xr2 does not have ecu man
- bas saph
Re: Engine Swap
see there is my naivity lol so would that engine fit in or would it be crazy wiring loom changes?? i just want to know what a good engine around a 1.6 that will go in there with ease with no messing about with wiring and mounts
- YoungRogue
Re: Engine Swap
if your swapping to a different engine the easiest way is to get the wiring loom from the car that used to have that engine in
- happypaul
Re: Engine Swap
but am i right in thinking my engine is ohv? if so if im putting an xr2i engine in for say, will i need to change the mounts for the engine? and also i would need an xr2i fuel tank aswell would i not?
- YoungRogue
Re: Engine Swap
with the carb engine from the xr2 it is very easy the mounts are pretty much already there for you, you will need to make a modificaton to the fuel pump as it is mechanically driven and as for a loom it is a case of running three wires, With the injection it will be the same mounts just the wiring maybe slighlty different. And if your fiesta is a mk3.5 it will not be carb it will be single point injection.
- W1LL14MS
Re: Engine Swap
my engine is definatly not injection lol its an overhead valve 1.1 or 1.3 hcs i am unsure which, but deffo know its not injection as i got the k&n bolt on on the top of it
- YoungRogue
- YoungRogue
Re: Engine Swap
does your engine have power steering?
- W1LL14MS
Re: Engine Swap
no no power steering, not that posh lol i know the one in the pics does but mine doesnt
- YoungRogue
Re: Engine Swap
who needs power steering lol
- Scott69
Re: Engine Swap
exactly lol just get a bigger steering wheel
- YoungRogue
