Engine Tuning (1.8 16v)
21 posts • Page 1 of 1
I have now sourced a 2i 16v engine and I just wondered before I put this in what I can do to tune it!
I will be changing fuel and oil filter, putting high quality oil in etc and just wondered what sort of cams, throttle bodies, air filters there were for this and what people had tried?
- Poom
2.0 Mondeo Throttle Body, Cams & ECU, should see you producing RS1800 Power (somewhere around 130bhp)
- MuttleyMcLad
MuttleyMcLad :2.0 Mondeo Throttle Body, Cams & ECU, should see you producing RS1800 Power (somewhere around 130bhp)
So if I see a mondeo in a scrappy and nick the throtle body and the cams and ECU it should work?
- Poom
only the throttle body u need from the mondeo, i think
You need a RS1800 ECU and get sum 16v 2i cams, am i right any1??
- MuttleyMcLad
You'll need aftermarket Cams as you can't use secondhand cams not a good idea. A set or piper or kent cams made from blanks would be perfect
Call 01753 632811 or visit http://www.xfactormotorsport.co.uk
- xfactor
- Authorised Trader
sourcing the rs1800 spec bits is a good way to get 130 quite cheaply,
but first i would go for a decent filter and zorst, ive got a piperx indcution kit and a full scorprion system on my 2i and its reacted well and pulls a lot better
- Nick 2i
with these u will b producing f**k all power as the car will not start
- fiesta boy
- One big spelling error...
fiesta boy :MuttleyMcLad :2.0 Mondeo Throttle Body, Cams & ECU, should see you producing RS1800 Power (somewhere around 130bhp)
with these u will b producing jolly flip all power as the car will not start
economical tho
- DaveZetec
- fiesta boy
why not?
- FezzR
- God Damn Lazy
why? using the 2.0 ECU you mean?
- Nick 2i
xfactor :You'll need aftermarket Cams as you can't use secondhand cams not a good idea. A set or piper or kent cams made from blanks would be perfect
what do you mean by blank
My Bad!
Sorry
Sorry
- Fiestasi-Andy
- chumkila
- Dirty Post Whore!
get a nice set of cams an air filter and maybe polish and port the head mate before the engine goes in. But first give the engine a good clean and make sure it sweet and that u will get no headaches when working with it good luck with it mate!!
- custom boy
- custom boy
- chumkila
- Dirty Post Whore!
basically some cam firms re-profile old cams rather than starting from a blank this is not always a good way to profile a cam. Both Kent and piper start with a blank to create the profiles for the zetec cams.
- xfactor
- Authorised Trader
Some of you know i have been researching just this topic for a long time!
Just fit a good exhaust, K&N PANEL filter and 2.0 throttle body. you will notice such a difference. The car will be so drivable!
You can go the TB, Cams, ECU route but it is costly.
Also, dont just go plugging in a rs1800 ecu. it will make the car WORSE!! it needs the cams and tb to make the most of it all
st
st
Too old and too bald.
- SimonT
2.0 ecu will not work on the early external edis wireing loom been there done that and deffoned me self for a short while 2.0 cams not suited 2 the 1.8 engine better 2 fit the 130 ps 1.8 set up
- fiesta boy
