engine upgrade
12 posts • Page 1 of 1
engine upgrade
hi all
ive currently got a 1.1 engine in my fezzy and is on its way out.
i was thinkin of upgradein 2 a 1.3 to keep the insurance sweet etc
will the brakes, gearbox etc need upgrading 2???
- danfezSi
It must be the time of year. How many engine conversion questions have come up in the last week?
DonnyDan, you should always fit vented brakes if you don't have them (you need calipers, discs and pads).
Gearbox will be fine.
You should fit the 1300 carb and inlet manifold.
- Project
- fiftyoneCL
Carb won't always come with the engine.
If you can find one, fit the 1300 exhaust but the 1100 exhaust will do the job fine for the time being.
- Project
- fiftyoneCL
just lettin u all know its 4 a mk3
had words with a garage and they say its only the engine i need, even the fcukin carbs the same apparently! not quite sure bout that though??????
any1 know if its diff? in the hayes manual theyre the same kind of carb, but diff model no's? whos right?
cheers all
engines only £175 recon
cheers all
- danfezSi
As I said, quite helpfully I thought, GET IN TOUCH WITH ALWAYSMODS2DO, HE DID THE VERY SAME CONVERSION.
- Mikee_RS
Car: 1995 Ford Fiesta
how about my 1600cvh (xr2 carb) with everything you will need including brakes, radiator, hoses, wiring lomb converted to plug straight in..... make me an offer and its yours (only done about 42k).... somewhere around £200
- Simmo
