engine?
4 posts • Page 1 of 1
engine?
i have a 1.1 k reg fiesta mk3 and i was woundering what would be needed to put the 1.6 xr2i engine in mine? cause i just want a little bit more power untill i can afford a nice lump... just woundering what sorta work/cost i would be looking at.?
- phillipsuk
the parts shouldn't come to too much - uprated brakes, suspension etc. then the engine, ecu, loom, g'box, perhaps mount, perhaps tank/lines etc...
as for putting it in ....
i've just been quoted 1000 fudgekin quid to fit a 1.6 in my 1.1.
any other options?
any other options?
- andyleesy
Assuming yours is carb, you'd be better off with a carbed 1.4 or 1.6 engine. to stick a 2i lump in you'd need to convert the fuel lines for injector feeds, or something like that.
- Tweek
- Your car: VW Golf GTD
you would need a fuel return line, and a fuel pump/tank from a 2i, rs or si.
youde need the loom, the ecu, and a haynes
then the lump
engine mounts
you can keep the gearbox you have.
then the lump
engine mounts
- JayC
