ERST head.
ERST head.
Postby Brianscotty on Wed Jun 26, 2013 10:30 pm
I have just rebuilt my engine & have been having a few issues getting it to start. Anyway after sorting out most of those issues I have noticed that on cylinder number 1 both the valves look slightly open when at TDC. I am using a ERST head with FRST valves, rockers, lifters & cam. My question is are both the Fiesta & Escort heads the same or is there any differences between them?
Any help on this would be really appreciated...
Brianscotty
Your car: Vectra VXR & FRST
Re: ERST head.
Postby mikeymikeyp on Thu Jun 27, 2013 9:28 am
Have you put the rectangular spacers on before you put it together ,,they slip over the rocker studs
mikeymikeyp
Re: ERST head.
Postby Brianscotty on Thu Jun 27, 2013 12:05 pm
Yeah m8 there on. All the components in the head were on the original head fitted to the car. I am now using a head from an Escort. When I found that the valves looked open I thought that the Escort head should have longer valves fitted.
Brianscotty
Re: ERST head.
Postby mikeymikeyp on Thu Jun 27, 2013 9:53 pm
You used the fiesta valves mate in an escort head now i would have thought that would have been okay but the escort head will be MFI probably ,, did u lap the valves in if they lapped okay then that kind of rules out them not sitting in right
mikeymikeyp
Re: ERST head.
Postby Brianscotty on Thu Jun 27, 2013 10:48 pm
Yeah they were lapped in absolutely fine m8. I take it that the Escorts parts are identical to the Fiesta parts ( in the head that is) .
Brianscotty
Re: ERST head.
Postby mikeymikeyp on Fri Jun 28, 2013 9:58 am
apart from the inlet side buddy i would have thought so ,,it wouldnt matter if you put a carbed head on a turbo it should stilll work and vice versa cos its the pistons that differ
does the car run
mikeymikeyp
Re: ERST head.
Postby mikeymikeyp on Fri Jun 28, 2013 10:00 am
its a cvh aye ? you 100% on the timing uv not got an adjustable cam pulley and i heard the turbo cam pulleys diffrent to the standard 1600 cvh but cant confirm that :-? :-?
mikeymikeyp
Re: ERST head.
Postby Brianscotty on Fri Jun 28, 2013 8:56 pm
mikeymikeyp :apart from the inlet side buddy i would have thought so ,,it wouldnt matter if you put a carbed head on a turbo it should stilll work and vice versa cos its the pistons that differ
Thats what ithought as well.
mikeymikeyp : does the car run
It does now.........just.. :lol:
Brianscotty
Re: ERST head.
Postby Brianscotty on Fri Jun 28, 2013 8:58 pm
mikeymikeyp :its a cvh aye ? you 100% on the timing uv not got an adjustable cam pulley and i heard the turbo cam pulleys diffrent to the standard 1600 cvh but cant confirm that :-? :-?
Yep definitely a CVH. I ain't got the adjustable pulley yet as I was waiting to get my new cam.
Brianscotty
Re: ERST head.
Postby mikeymikeyp on Sat Jun 29, 2013 1:01 am
prob best to take a vid ,, youtube it then link here :) :wink: :wink:
mikeymikeyp
