escort engine?
Postby xrsi on Mon Oct 08, 2001 4:42 pm
U need a new a new alternator bracket [ERRR] the alternator is in the way of the lower coolant hose!!!! Hence the alternator end is the worng way up for the fiesta bracket!
Easier to get new cable than mess around modin ur old cable!!!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby BeemanFRST on Mon Oct 08, 2001 5:15 pm
ok, i cant wait, me uncle is comin to look at the engines on saturday, then the followin week we hopefully will bring it home and give it a rebuild.
How much do you rekon the 1.6s mount will be from ford, ill have to get a new one cause there is no cars like that around here.
Anything else to add xrsi/projectst2000.
By the way what are yere top speeds now, is the o to 60 much quicker.
Thank ye sooooo much for all the advice, i should say ill have no problems as my uncle will be helping me along. :cool:
Image Image
If you know anyone from Ireland selling either a frst, or frst engine let me know +353868436316
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby BeemanFRST on Thu Oct 11, 2001 4:38 pm
Engine is bein got on sat.
Im buyin the alternator, mount and engine mount off Ford.
What is the model of car the 1.6s engine came out of.
Its for ordering purposes.
Image Image
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby xrsi on Fri Oct 12, 2001 5:44 am
Right, you need them from a 1.6s Mk3 fiesta '89 to bout '91 ish (f-h/early j).
Would be better getting a recon alternator from a motor factors rather than ford, bout half the price!!!
Dont forget the accelerator cable!!!!!!
Have you got the 1.4/1.6 mk3 fiesta cvh rad and pipes???
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby BeemanFRST on Sun Oct 14, 2001 10:18 am
we is goin to try and use the escort rad first, i got the car on sat and we got it runnin, its a rocket. should sound the bollox with me powerflow. How much is it usually to get an engine gas flowed?
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby BeemanFRST on Tue Oct 23, 2001 1:02 pm
what is the story with the ESC connections onto the 1.6.
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby xrsi on Tue Oct 23, 2001 4:44 pm
I take it that ur escort engine had esc module for it??
If so then just plug the cables off your old ones into the relivant places!
Simple!
If ur engine doesnt have esc module then all you need to do is change part of the wiring in the engine bay for a coil and plug that on to engine and sorted (from black multiplug onwards!)
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby BeemanFRST on Tue Oct 23, 2001 5:16 pm
No mine has a esc, but i dont think this engine has.
We modified the drivers mount to fit it i hope :smile:
Have to get new clutch disc, only for that it would have been in tonight.
Im using the origional rad until i find a cvh one.
But other than that the wireing seems to be the most trickiest, but i presume its just a case of finding which wires on mine go onto the escort 1.6
Image Image
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby xrsi on Wed Oct 24, 2001 3:54 am
Right - if the escort engine doesnt have the esc module (or any module in the engine bay) then just take the wires from the multiplug (black one under the esc module in your engine bay - fiesta) unplug it, then from the escort unplug the coil from the same sort of multiplug and plug this into the fiesta multiplug and then wire this to the engine!
If as you said, the escort isnt edis, then it's the only wiring that the engine needs!!!
I would strongly advise AGAINST modifiying the engine mounts and botching the rad into the cvh system! The engine mounts can cause untold damage and stress' on the car!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby BeemanFRST on Wed Oct 24, 2001 1:06 pm
Its just for 3 weeks cause its comin out again for a gas flowed head, kent cam, and a good clean. just tryin to get it goin firstly, then its gettin sprayed, cleaned and westwood engenering reckon they will get 130bhp out of it so i will need the proper rad and mount.
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby BeemanFRST on Thu Nov 01, 2001 7:00 pm
Eloo,
The car is runnin, still usin the old rad, tryin to find a cvh rad for cheap.Exhaust sounds the bollox, and its runnin fine.
Should be on the road tomorrow night, then its off to the sprayer, for a total overhall-cossie frount, mk5 back, rs windows, kingdom k style spoiler, new doors, bad boy bonnet, one off lexus lights, rool cage, new seats, and crome stuff for the engine.
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby BeemanFRST on Fri Nov 02, 2001 5:34 pm
Had it runnin for 5 mins, then it cut out.
Power is goin to the distbuter but no spark, is the distrubutor managment burnt out, cause it was dead hot. Is there to much power goin to it, the coil was not hot?
Help me quickly!
Image Image
BeemanFRST
Irish Fiesta
Irish Fiesta
Postby Project on Fri Nov 02, 2001 7:03 pm
Beeman,
Are you absolutely sure there's no spark??
Look down the carb venturis and pull the throttle cable - you should see a thin stream of fuel being injected in. If not you may have a fuel problem. Make sure the feed and return pipes are connected the right way round (silly I know but you need at least quarter of a tank full to suck fuel out via the return pickup).
If there is no spark, the first thing to check is the coil lead - this often arcs and allows the spark to go round the outside coil and straight to earth via the coil bracket.
Dizzy rotor arms have a habit of cracking, as do dizzy caps. Take them off and check to see if it's all fallen apart inside. A new pair shouldn't cost more than a tenner at your local motor factors.
If none of this helps, you need to do a bit of checking to find out the type of ignition management systems you have.
The earliest CVH types uses a separate spark mapping box, about 6 inches by 7 inches and about 1.5" thick. Make sure this is connected correctly, and the vacuum lines are clear, otherwise the ignition timing will be slightly out and will make the engine run rougher.
The second type has a small ignition module mounted to one side of the dizzy. This can be removed and checked.
Coil resistances in both cases should be 0.72 to 0.88 ohms at the primary (12v) side and 4500 to 7000 ohms at the HT side of tings (HT to case should work).
The engines are seriously basic and the prob is likely to be just that it needs cranking a few times to get fuel pressure up and fill the float chamber.
To check your fuel pump works, disconnect the hoses in and out, and crank the engine a few times - some fuel should spurt out (have a wet blanket handy in case you set fire to it :rolleyes:)
Failing all that, keep cranking it or call your friendly breakdown assistance chap - worked for me! :grin:
If I was local I'd come round and help ya mate - sorry this is all I can do for ya :sad:
Al
Project
fiftyoneCL
fiftyoneCL
Postby Project on Sun Nov 04, 2001 5:36 pm
Any joy m8??
Project
fiftyoneCL
fiftyoneCL
Postby BeemanFRST on Sun Nov 04, 2001 5:41 pm
yep, vvvvvrrrrrrrummmmmmmmm.
We forgot to fit the supressor to the coil, ddoooooooooooooo.
Got the module for a fiver, and re wired the wireing
Image Image
BeemanFRST
Irish Fiesta
Irish Fiesta
Previous
