escort rs turbo engine in fiesta
2 posts • Page 1 of 1
hello people i m planning to build a escort turbo engine in my fiesta has anybody done this?? and what do i have to adapt to make all this fit??
sorry for the bad english i m just a dutchman!!
- treehugger
all depends what management you are thining of running...if its the ERST stuff....then it will go straight in but you will have problems mounting the metering unit etc
but if its the FRST stuff, you will need to get a Crank Position Sensor put into the block of the engine, use the FRST flywheel, FRST inlet manifold, FRST head or EFI adapter plate to hold the injectors, FRST coil pack, FRST loom....cant remember what else off the top of my head
HTH
bassboy
HTH
bassboy
- bassboy
- Authorised Trader
