Escort S2 RS Turbo - Stage 2 turbo?
4 posts • Page 1 of 1
My Mate just got his stage 2 turbo for his scort.
Question is:
Is it a straight swap over job, he has bleed valve fitted, does this need to be changed?
It came with -31 actuator, any ideas please?
Question is:
CheeRS
Maky
Maky
- maky
You shouldn't really need the bleed valve with the actuator. Obviously he's going to get it setup straight away anyway right?
If it's a stage two (bearing change and recon) it should be a straight swap as the casing is exactly the same.
does my big look arse in this?
- The Gilly
