excursion help needed!!!
3 posts • Page 1 of 1
all to do with the 2 litre bottom end for my zetec fiesta, as i have the original sort of mk1 zetec head would i only be able to fit a mondeo bottom end from the same sort of age or would i be able to fit the zetec-E bottom end? Plus how do i get on with the gearbox and clutch, do they fit the 2litre bottom end without having to make a new gear box cradle? Finaly what do i do about the engine mounts? will i have to get a custom set?
cheers from Matt
cheers from Matt
- grintermatt
allright m8
Any 2.0 zetec from 1993-1998 with the silver cam cover is compatible.
For the gearbox and clutch just use the fiesta item (1.8 zetec). Youll have to swap the flywheel for a fiesta/escort zetec one. standard xr2i clutch (cvh or zetec) is up to the job.
Standard Zetec engine mounts are well up to the job
