Exhausts & Cat Replacement Pipes....
8 posts • Page 1 of 1
Following on from my post about the 2.0 conversion i need some help about the exhaust i'm running.
I have a cat back Mongoose system which is ok, its the cat and downpipe that are my problem.....
I can't use a cat replacement pipe as the cat is part of the downpipe, i'm assuming that the cat replacement pipe would bolt into position??
Or is it a case of cutting the cat off of the downpipe and fitting and clamping the replacement pipe into place?
Has anyone done this or got any good advice/pictures to offer me?
CheeRs for you help in advance.
- BillyCabrio
- BillyCabrio
after the manifold there is a flexi joint where the rest of the down pipe connects to which joins to the cat.
2.1 Zetec turbo Fiesta RS - 261bhp 310lbft
- phil_pearce
Not on mine there isn't!!
Cat is fixed to a rigid pipe, the whole system - manifold to tailpipe is rigid pipe
- BillyCabrio
the flexi joint should be before the cat ie between the cat and the manifold.
- phil_pearce
- BillyCabrio
