expected bhp????
32 posts • Page 1 of 1
expected bhp????
hello, im booked in for a rolling road session on saturday. got a fiesta turbo on a t3 turbo with beige injectors and a 195 chip. what bhp do you think it could be running?? thanks guys ...
- blower_rs1800
Re: expected bhp????
2200 bhp and 10000 ft/lbs of torque
- Ruishy1
haha i thought about that too
- blower_rs1800
170-180 ish maybe ?
- andy-rs power
andy-rs power :170-180 ish maybe ?
if ya lucky mate , i dont want to put a dampener on it all but if you get that id be very happy.
ill say 167
let me know yea
remeber to put shell optimax in it yea
- ben26
- Your car: Escort and Fiesta RS Turbo
What boost are you running? Is the engine completely standard?
Take it the session was yesterday? what did it make?
- JamieFRST
- Keep It Tidy
its running at around 14 psi and i hit 181 bhp at the wheels very very happy
- blower_rs1800
Nice one mate. I'd b well happy with that. What is the full engine spec of the car?
- ben26
rs turbo on a t3 running 14psi, beige injectors, 195 superchip, vernier pulley, full stainless straight through exhaust, air filter. standard intercooler. last run clutch slipped so it would of seen a bit more. so gonna put a racing clutch in a pace charge cooler system and a perfromance manifold and will hopefully see 200bhp :)
- blower_rs1800
blower_rs1800 :its running at around 14 psi and i hit 181 bhp at the wheels very very happy
you sure its at the wheels mate, as that equates to 200 odd flywheel bhp
- Ruishy1
- ben26
thats about right surely... t3, beiges 195 chip
- dangerousdave
yh m8 its 181bhp at the wheels
- blower_rs1800
- ben26
yeah really why wouldnt it be running that lol
- blower_rs1800
I would imagine that sort of power would be at the flywheel. But if you say it is that power at the wheels then it must be around 210 at the flywheel !!!
- ben26
sounds about right, normally with uprated I/C. cossie fuel pump etc there around 188
- TANGO.
vauxhallscum :sounds about right, normally with uprated I/C. cossie fuel pump etc there around 188
yea it does sound right , but not at the flywheel ? More like the wheels
- ben26
dunno then dude, maybe there are mods to the engine that he doesn't know about!!
- TANGO.
ben26 :vauxhallscum :sounds about right, normally with uprated I/C. cossie fuel pump etc there around 188
ha ha ha ha the flywheel is more than the wheels so what your saying is is should be more now not less....??
- dangerousdave
dangerousdave :ben26 :vauxhallscum :sounds about right, normally with uprated I/C. cossie fuel pump etc there around 188
lol , that came out wrong then .
i knew what i ment thats all that matters
- ben26
my old fiesta rs turbo was running a t3, beiges, stage 2 powerchip, uprated fuel pump, piper cam, etc. that made 191.6 bhp at the fly, and 156.7 at the wheels. with 202lb/ft torque
- slipper
Car: 1991 Ford Fiesta Popular Plus
- ben26
That figure has to be at the flywheel..
Either that or got some other funky stuff going on! haha
- moondustka
bloody hell, how much money you think you've spent on it?
my car made 211.9bhp at the flywheel on a dyno dynamics R/R. t3,fmic,cam,chip,injectors,and uprated cossie pump. but it was runing 21psi peak and holding 19psi.
- matty872
- ben26
I don't know I only had a print out for it at the flywheel would have prob been around there.
- matty872
does your car go well ? what sort of things are u on par with ?
the set up u have is my ideal set up with dropping a turbo'ed zetec in
- ben26
It used to go really well but it is only runnig a 165 chip at the min. as I rebuilt the engine and have brought aftermarket management but ran out of money to get it all mapped + there are a few other bits I wanted to change but should be approx. 300bhp when finished.
- matty872
my rs has got 1.8 zvh bottom end, crowns skimmed 0.1mm, new piston rings and bearings, seals throughout, stage 1 big valve head,
burton power 285t cam,vernier pully,t3 garret turbo,-31 collins group A actuator, cozi fuel pump, alloy radiator, alloy front mount intercooler, beige 701 injectors, escort cozi uprated fuel pressure regulator, ofac ecu with chip, bailey swirl pot, cone air filter (universal), 4" Scorpian full stainless system, group A felpro head gasket, arp head bolts, lsd box, baily dumpvalve, baily swirl pot & catch tank, skimmed flywheel, ap racing fast road organic clutch uprated to 350bhpand it only made 228.1 at 6138rpm max power with 221.4 max torque fun fun fun
- iain6790
Seems like it's not too hard to get 200bhp for the money, but to go from 200 to 250 is ££££s
I'm running 221 lbs out of mine! which was done on dyno dynamics rollers also.
- moondustka
