Expected bhp???
7 posts • Page 1 of 1
Expected bhp???
Could any1 give a good prediction of what bhp i should roughly b running with the following:
1600 xr2 engine
Ashley full system + 4 branch manifold
K&N Filter
Stage 2 Head, gas flowed ported
Kent cvh33 cam
Any help would be great thanks
1600 xr2 engine
K&N Filter
Kent cvh33 cam
- Matt L
130 aswell!!! u need to get a dyno tune!!! really they give u read out of powerl! instaed of getting a rolling road!
middlesex tunning!!!
or redline!
or redline!
- Xr_Dub
not a chance 130 unless u run twin webers, these engines only put out 95bhp on a good day on standard trim, dont get 35bhp from those mods on an n/a engine, pre 1985 lumps are better, propper cvh heads.
- snake
- Trainee Burger Flipper
- Your car: ford
snake :not a chance 130 unless u run twin webers, these engines only put out 95bhp on a good day on standard trim, dont get 35bhp from those mods on an n/a engine, pre 1985 lumps are better, propper cvh heads.
Yea was [ERRR]' bout 110-115 at the flywheel
Oh well, in about 5 yrs no claims bonus time i'l av a FRST
- Matt L
As a guide, Dave Moore's (PF Dave) old XR spec was:
Fully Rebuilt Engine with RS Turbo big end and main bearings, Overbored 1mm = approx 1644cc, Newman Phase 3 cam with Solid Lifters, Kent Adjustable Vernier, Stage 2 Big Valve Head (43.43mm inlet valves and 38.10 exhaust valves), bronze valve guides, multi-angle cut valve seats, Skimmed 20 thou of an inch, Magnex four branch manifold and system (wrapped in heat wrap), Facet Silver Top Competition fuel pump, Filter King (FPR), Weber twin 40 DCOEs, Magnecor 8.5mm Race Leads. Lightened Flywheel, Limited Slip Differential from a Series One ERST, LUK Low Lift Clutch, reconditioned closer geared - gearbox with 4:1 final drive ratio.
And was putting out 116bhp @ wheels = 134bhp @ flywheel
his new setup is:
Fully Rebuilt 1600 CVH Block, Line bored, Overbored 0.5mm, RS Turbo big end and main bearings, Lightened and balanced crank, Farndon H section Steel rods, ARP 2000 bolts, Cast ceramic coated Pistons with removed piston skirt, valve pockets and gudgeon pin inserted allowing fully floating movement, Baffled sump
Fully worked head, including Sodium filled big valves, full porting, multi angle valve seats, balanced chambers, Newman Phase X race cam with Newman solid lifters and double valve springs, Kent vernier pulley.
Weber twin 45 carbs, enlarged inlet manifold
Magnex S/S four branch manifold and system
and is putting out 132bhp @ wheels without gas = 155bhp @ flywheel.
hth
Info copied straight from http://www.fastfords.org.uk/
his new setup is:
hth
- XR_Ben
