external fuel pump to run fiesta rs turbo??
5 posts • Page 1 of 1
hi all! im using fiesta rs turbo engine, loom, managment with ofac ECU on my 1962 ford pop 100e but as for using a fiesta rs turbo fuel pump... well thats out.
has anyone used a escort rs turbo fuel pump (external) to fuel these systems? if thats a no no, any other recomendations??
ta for any help
ta for any help
- 285Andy
- Your car: fiesta rs turbo
Re: external fuel pump to run fiesta rs turbo??
as long as the fuel is fed to the fuel rail at the correct pressure then there is no reason why you can not fit an external pump, you may well need to fit a lift pump and then a swirl pop to remove any air from the line before the actual high pressure pump but there is no reason why it can be done.
as for an escort turbo pump im not sure if that would be the best option but it may well work...
best bet is to get on a forum for mk1/2 escorts and see how they fit fuel injected engines in them and take that as inspiration.
- xrsi
- XR(ustyAtTheMo)SI
the pump is lower than the tank so a lift pump and or air bubles is probably out the way and the tank outlet is at the bottom of the tank as well. the pump im thinking of is rated @ 195ltr/hr @ 3bar. dont know what standard (for the sake of argument) a fiesta rs turbo pump is rated at?
cheers!
cheers!
- 285Andy
i dont know how much fiesta pump is but was just going to say the best place for advice on using non injection tank with an injection engine would be somewere like
http://www.turbosport.co.uk
they should know as they all got modern engine in mk1 and mk2 escorts etc
- White2i
White2i :i dont know how much fiesta pump is but was just going to say the best place for advice on using non injection tank with an injection engine would be somewere like
i wasnt so sure tbh thats why i asked you chaps but fair enough maybe i'll give it a go!
cheers!
- 285Andy
