F.A.O. Anyone who's done the "Bad-Boy" look....
Postby Danny 2i on Wed Sep 12, 2001 9:12 am
Whats the best way to weld the plates on?
If the brows are welded behind the bonnet will this foul the lights when the bonnet is shut????
If so is it better to weld flush to the outer face of the bonnet and then grind the seam with an angle grinder and then smooth it all off with fibreglass filler???
Help would be appreciated! :wink:
<font size=-1>[ This Message was edited by: dannyboy69er on 2001-09-12 18:22 ]</font>
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby Robz_Fester on Wed Sep 12, 2001 11:43 am
Weld one big rectangular panel on the front of the bonnet, and then cut the eyebrows out. Weld with spot joints behind the rectangular sheet, and then smooth out with filler.
That how I'm gonna do it anyway :wink:
Robz_Fester
Postby Danny 2i on Wed Sep 12, 2001 12:14 pm
i always thought u had to weld eyebrows on from behind the bonnet and then add filler/fibreglass to smooth it off? :???:
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby zetec69 on Thu Sep 13, 2001 3:31 am
Weld the plates level with the bonnet (flush) then grind back the welds. Remember to fold the metal on the edge to give a decent factory like finish. Then smooth over with filler. If you weld the plates from behind the bonnet will catch the headlights. :wink:
zetec69
Postby Tom SX on Thu Sep 13, 2001 3:50 am
what thickness and type of metal is best to weld on, and is fibreglass easy to use to smooth off?
b careful [ERRR] the legality as i dunno how much light you are allowed to block off! :mad:
Tom SX
Your car: A big German gaymobile
Postby Danny 2i on Thu Sep 13, 2001 4:15 am
i know u r allowed to cover up to 50% of the light (i wont be covering anywhere near that...i want mine to be fairly shallow)....somebody must be able to help?! :???: :lol:
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby zetec69 on Thu Sep 13, 2001 9:43 am
I used metal off an old door to use on my brows - perfect [ERRR] it's exactly the type & thickness steel you need.
dannyboy - who told you that you could cover upto 50%? just outta interest
zetec69
Postby Danny 2i on Thu Sep 13, 2001 10:59 am
cheers brad m8! don't remember who told me that.....probably wrong anyway! :lol:
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby Tom SX on Thu Sep 13, 2001 3:31 pm
but how do you smooth down the welds to nothing!? :rolleyes:
Tom SX
Postby zetec69 on Fri Sep 14, 2001 6:00 am
Tom matey all you do is grind the welds back so that they are level with the bonnet & the brow plate you've welded on so it's all flush then you use filler to get rid of any inconsistencies :smile:
LoW MoToR
zetec69
Postby MOONDUST FRST on Sat Sep 22, 2001 6:41 pm
As regards to the MOT problem Ive had mine done and its now time for the MOT so ill let you know the results cos the test centre where i go is fairly strict!:lol:
MOONDUST FRST
Postby Danny 2i on Sat Sep 22, 2001 7:00 pm
How far have u gone with the brows? :???: did you go for the full-on look or just part way? :???: :???: definately let us know mate..... :eek:
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby MOONDUST FRST on Sun Sep 23, 2001 12:58 pm
Ive gone the full on look mate which is from the top corner of the bonnet to the bottom just leaving about the 10mm lip on!
MOONDUST FRST
Postby PhatMan on Sun Sep 23, 2001 4:50 pm
mine has gone from the corner to the bottom of the 10mm lip, all blended so that the lip carries on into the brow :bonkers: :grin:
The PhatFiesta
May she live in our memories forever :(
PhatMan
It's a bit of an Animal..!
