FAILING brakes!!
11 posts • Page 1 of 1
FAILING brakes!!
Please help!!!
My brakes failed on me as i pulled up to some traffic lights
What could be th problems, as i cant drive the car newhere????
- gambo_si
have you lowered your car or put bigger alloys on it??
if so chances are the the wheel has rubbed through one of the front flexable hoses and burst it!!
this has happened to me twice so far!!! very scary when it happens!!
best way to check for this is have someone in the car repeatidly pumping the peddle whilst you look under the front of the car at each wheel in turn to see if fluid is comming out!!
otherwise if it possably one of the back pipes that have burst, or a faulty servo!!
hope this helps!!
James
hope this helps!!
James
- xrsi
- XR(ustyAtTheMo)SI
yeh mate, cars lowered, 16's on it, and yesterday back prtof exhaust broke from its bracket so is lower, so could be a pipe then! cheers for ur help,
how much woul it cost for a new front flexable hoses ?????
- gambo_si
if the hoses have gone get braided, about £35ish and shouldn't wear out, also firm up the feel of the pedal
- MFkev
Firstly check the level of the fluid to see where it is in the reservoir.
If theres hardly in there, look for a leak, and that will be the problem.
Hoses as said, or caliper bleed nipples may have come loose or a leak from the master cylinder.
As mikey said if theres no leaks then maybe master cylinder has failed, or the servo.
- MarkFRST
