False Floor Build.
15 posts • Page 1 of 1
False Floor Build.
- Zak
Re: False Floor Build.
are you putting the false floor all the way? I cut my MDF using my old boot carpet as a template...
- dontpannic
- CossieDan
Car: 1995 Ford Fiesta Ghia 16v
try using the carpet for the boot part and trimming some cardboard til it fits for the forward parts.
- RSTom
Car: 1990 Ford Fiesta RS Turbo
And if you are doing the build over where the backseats were too.
Use the bottom of the rear bench as a template
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
Where have they gone?
I know they aren't in the car.
Did you give them away or something?
- M1K3Y_B
if you build it out of a few bits of wood, make sure they are all the right way, i dont want to admit but i will just get a very large box a cut around it.
this is my fez standard above, passed in aug, best thing i have every done.1.25 zetec s.
- festafoff
festafoff :if you build it out of a few bits of wood, make sure they are all the right way, i dont want to admit but i will just get a very large box a cut around it.
Huh?
- Zak
in other words i build the boot build went to place it in, then i realised i put the two parts on back to front and they dint fit, just check and check again with these things.
- festafoff
Zak :festafoff :if you build it out of a few bits of wood, make sure they are all the right way, i dont want to admit but i will just get a very large box a cut around it.
Huh?
I think he means get a big sheet of cardboard and cut it to shape, then use this as a template.
- properphatboy
- Your car: Peugeot 306 D L
Anyone got any ideas where i could go to get a big enough piece of cardboard to cover the rear?
cheers,
Zak.
cheers,
Zak.
- Zak
The side of a big box
- M1K3Y_B
zak where are you based? (sorry if youve mentioned already i aint read the whole thread) i have some huge boxes here that you can try to use
bassboy
bassboy
- bassboy
- Authorised Trader
