fao anyone looking for ecu's
26 posts • Page 1 of 1
while being on a mad hunt looking for a 2.0 mondeo ecu
i came across a company called Lynx all they sell is ecu's
the guy i talked to was called phil, extremely helpfull
told him my situation and he told me all the codes that would work and which ones he had in stock,
anyway i'm now having an ecu sent to me by tomorrow
which should run my rs1800 lump in my Si
the number for this conpany
LYNX - 01949 836362
LYNX - 01949 836362
- RS rob
- Phil Si
Car: 2000 BMW 330 Ci
- RS rob
- Phil Si
- mike_wall15
Car: 2002 BMW M3
There are based in Bingham, near Nottingham.
Regarding using a 2.0l ecu on a different cc engine there are problems.
eg. MAF calibration data is wrong due to MAF size differences.
injectors calibration data is almost certainly different too.
Whilst KAM data aquired during closed loop operation will compensate to some degree, in open loop you almost cetainly will have fuelling problems.
- sailorbob
sailorbob :There are based in Bingham, near Nottingham.
thats the kinda thing i was thinking too.
did they sort ya out an RS1800 ECU? because as said above, the 2ltr item would work, and that i dont disagree, but i doubt it will be runnin as it was designed to.
what i would like to know is whether anyone has MOT'd an 130ps 1.8 running a 2ltr ecu
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
So you think if I swap MAF-sensor from 2L MOndeo engine the problemm will exist anyway?
Now I have MAF-sens. form 1.8 L mondeo no probs at all, maybe a little poor fuel and air ratio, but not sure, just look to my spurk plugs and they are completely white, not a little bit yellow..
But 1.8 l MAF-sensor form MOndeo is identical by size to 2l MAF.
Sorry for poor eng.
- abbat
sailorbob :Whilst MAF sensor might look physically identical they are calibrated differently so it's always best to use the matching MAF to go with the ecu.
so its best to use a 1800 ecu with 1800 maf even if am running a 2.0?
escort series 1 RS.
Sapph Cossy
Sapph Cossy
- doggpk
sailorbob :If you are running a 2.0l then it's definitely best to use a 2.0l ecu and MAF.
which is matched to the 2ltr ecu you are using, ie, Desk, Deep, Dewy...
JJ
- jdfiesta
- Your car: V70 T5
Just spoke to that Phil guy, he came across as a complete co ck. And he wanted £225 for an ecu.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
i ran a 2.0l zetec in an escort on a 130 ecu and maf and it ran okish.
it was little lean, tick over was litttle hunty and it wasnt great on fuel.
but it did do 145mph!
- escortbreakers.co.uk
Re: fao anyone looking for ecu's
I found the phil guy was also a co ck aswell thats odd lol. He also wanted stupid money, not helpfull at all in end i put the phone down on him lol.
- clarks.2007
they got a website?
- ukgaz
http://www.lynxautomotive.net/ just googled it
RS1800 Done and dusted
- Dwayneology
- Your car: Yamaha YZF R1, RS1800
ok now this is where im having problems... ive got 1.8 16v xr, running 2.0l 136ps mondy units as follows
coil pack
throttle body
maf sensor
yet to insert the cams and a working ecu
the ecu im having major probs with.. ive tried about 4 diff ecus now and the engine just wont turn over and start...any ideas?? i was put off foning this phil guy incase hes a pile of poo
coil pack
throttle body
maf sensor
- XR2i dude
on the 2.0l mondeo ecu the injectors and some other things are on different pins from the 1.8 ecu the loom needs to be modified in order to run the 2.0l ecu
there is a section in the guides forum that tells you how to do this it has a 2.0l ecu pinout chart, i got a haynes manual for the fiesta went to the wiring diagrams and made my own pinout chart for the 1.8 ecu by looking at them both together you should be able to see what mods you need to make to your loom in order the run the 2.0l ecu
faq-regarding-eec-iv-incl-8v-16v-turbo-na-vt93753/page35/
that is the link for the guide on that page somewhere it will explain how to do it
- Dwayneology
thanx loads for your response buddi... the way u wrote it in laymans terms really helped me finally to understand what i need to do and thanx also for posting the thread link... muchos gracias dave.
- XR2i dude
im runnin a 2 ltr zetec with 1800 injectors 2.0 maf & 2.0 ecu no probs are you using the xr manifold or the mondeo 1?
- 2.0zetec
oh and btw try sussex ford breakers they have loads of the right ecu's
- 2.0zetec
2.0zetec :oh and btw try sussex ford breakers they have loads of the right ecu's
Do thay have a website?
- Ollybee
best to google them mate and give them a ring cos there a breakers stock changes daily
- 2.0zetec
sorry for clogging this thread but does this mean u need to modify the loom in a p5 fsi to run a 2.0 ecu
- sisisisi
