FAO EXPERIANCED ENGINE BUILDERS
14 posts • Page 1 of 1
i have 1.8zvh with beige injectors and 195 chp etc with pace intercooler
i have kent cam and ported head and have a decompression plate
i have standard zetec pistons machined for low comp
finally i have hybrid t2
what boost can i saflet run with this little lot without melting.crackign pistons?
thanks for any advice
carl
carl
FRST IN NEED OF SOME GREEN STRIPAGE,
PM OR RING 07967669115 IF YOU HAVE SOME
- xr2icarl
How much has the pistons been machined down by?
- freak power
xr2icarl :on the reciept it says cutom pistons 20 thou??!! .5 oversize
thats not piston skimming the way i read it. thats taking the bores out 20 thousands of an inch
- 285Andy
- Your car: fiesta rs turbo
maybe 12 to 17psi?
- TomRS1800
I'm concerned enough about running my engine on standard pistons, but skimming standard pistons is pretty nasty practise IMO if you're building an engine to make power!
Count yourself lucky my 1600 bottom end cost me £3k. £220 would get you a pair of low comp pistons and pretty much bugger all else.
If you want a powerful engine you'll need to put some hard earned into it.
take it back and complain if they didnt provide you with the goods/services you specifically asked for.
burton power do a good selection of pistons for the zetec engine.
other wise, i wouldnt like to pushing more than 12 psi on standard pistons.
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
