FAO ZT people!!! Injectors that fit Zetec fuel rail (56k!!!)
Postby disc on Mon Jun 20, 2005 8:58 pm
OK.
Since I'm plan to build ZT few months ago start search for sidefeed injectors that fit Zetec fuel rail. They can be not direct replacement fot ECC-IV, cause I'll use Megasquirt. And finally found!
Nissan 200SX (S14) injectors fit perfect in Zetec fuel rail! Just need to swap small O-rings, cause Zetec ones is little bit big.
Now some comparison:
Zetec injectors (1 800cc, 105HP):
Flow rate ~ 160-170 cc/min
Impedance - 16 Ohm
Nissan injectors (SR20DET - 2 000 cc, 200HP)
Flow rate - 375 cc/min !!!
Impedance - 10,7 Ohm
So if u plan ZT why don't you take a look at
Megasquirt <- Click, also check Asad's Megasquirt topic <-Click. MS is cheap, easy DIY thing.
Now some pics.
Nissan fuel rail:
Nissan injector:
Zetec fuel rail vs. Nissan fuel rail:
Ford Vs. Nissan injector:
And finally Nissan injector in my Zetec fuel rail:
But that's not all. If you plan REALLY BIG power 375 cc/min can't be enought. 375 cc/min Nissan injectors are good for 300+ HP. Then... just simply shave the cap of injector!!!
Read more about this mod here:
http://forums.probetalk.com/showthread.php?t=1701147295
Ok, with "shaved" cap now you have ~550 cc/min injectors and can get up to 500HP (!?!).
Have luck!
Sorry for my bad english...
disc
Your car: 1991 Orion ZetecTurbo 270BHP
Postby Hartza on Tue Jun 21, 2005 8:51 pm
Are you planning to disconnect original fuel pressure regulator in the fuel rail?
Hartza
Postby disc on Tue Jun 21, 2005 8:55 pm
Nope! Regulator will sit in place. Why you asking about?
disc
Postby Hartza on Tue Jun 21, 2005 9:03 pm
disc :Nope! Regulator will sit in place. Why you asking about?
I´m Planning to get rid of it and use FSE regulator, just wondering how to disconnect it... I´m not that far yet :)
Have you tested the injectors yet for leaks ect.? Seems to me that the nose is a bit smaller in Nissan injectors.
Hartza
Postby heeman10 on Tue Jun 21, 2005 9:30 pm
The fuel regulator is held onto the fuel rail by two small (6 or 7mm I think( bolts and a little O-ring :)
Postby disc on Tue Jun 21, 2005 11:50 pm
Injectors are not tested yet. Almost all dimentions of injectors are indentical.
disc
