FAQ - Tuning the 1.1 & 1.3 Engines..
30 posts • Page 1 of 1
DONT!!
Do NOT tune your 1.1 & 1.3 Engines. Its a waste of money.
By all means buy a Backbox as the standard ones do look crap and Drill your airbox or if your rich buy a K&N or Green Airfilter. For that nice noise.
I drilled 12x10mm holes around the back of my airbox on the edge. I think this gives the best noise that you can get from the engine and i have experimented a lot. Also remove the big spaceship pipe and hot air shelid from the exhaust manifold.
For a Green filter, You will need part #P296..
http://www.needforspeed.co.uk/images/fi ... T-P296.gif
For a K&N, You will need to read this post..
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=62698
Note: The Green kit supplies two mini filters for the oil breather and vac hose. The K&N does not.
Here is my engine with drilled airbox, warm air feed and heatshield and long 'pipe' removed with piper-x oil breather..
You can see a couple of the holes in my airbox here..
Rear exhaust boxes will need to be of the correct smaller bore size than the sport models. Allthough reducers can be made or bought for exhausts meant for the sports model fiestas including the fitment of Standard/OE Si16v or XR2i exhaust's.
Adjusting your tappets is also a good idea, See your Haynes manual!
Probably can get colourd spark leads, Ill see where haynes got them from for thier books fiesta.
Yea dave, I will see if i have any problems with mine.
Green filters are £90ish, hence why id rather do what ive done!
greenfilters.com AFAIK
Well, This is the one that i thinks correct..
http://www.needforspeed.co.uk/green/ind ... artNo=P296
P296, £93.52
Will make a very small difference, if at all to power and you probably wont notice anything.
Why do you want one?
P296, £93.52
Replacment element? Seems like a good idea. How much are they?
Ive drilled 12x10mm holes around the back edge.
Im not sure if the 1.1 and 1.1 Carbs/CFi units are the same. As with the manifolds.
1.3 EFi inlet should fit on i suppose.
DONT JUST REMOVE THE WARM AIR FEED LOL LOL LOL
If you do, all the air you're gettign in wil be coming from just above the exhaust!!! If you're gonna do that you'll have to get some piping to run from the front of the car to the air box...
- Robz_Fester
ive a green induction kit on my fez, deffo helps a bit, a lot more pull thru the gears, not that theres a lot there anyway... sounds class too, need something to drown out the tappets
btw my induction kit is for sale, best offer +P+P gets it. ill give it a good clean for whoever takes it ill throw in an authentic green induction duct too, a big wide one, nut sure how wide but i run it from the air filter to the gap between the headlight and the grill on the passenger side, seems to work well.
Richy
Richy
- bigrichybyrne
http://tinypic.com/l8m0l
cudnt get the image tags working so... click the link
as you can see, i keep my engine in tip top condish
the coke bottle is there to catch all the burining oil, turned the breather black within minutes it has now been unprgaded to a garden hose straight out the floor , havent got the ducting on in that pic tho
oh and ive since cleaned the filter
- bigrichybyrne
- Richardson
I got that green filters bolt on kit and i love the noise it makes when you toke it. In terms of power gains there is hardly any but id still say buy it. Im not saying the "drilling in your airbox" idea is crap as ive never tried it.
Ive also got some blue spark leads made by splitfire. They cost £45 and i think i got themm from http://www.potn.com/p1604015.htm
I think they are the right ones but search for others first. If i can be bothered ill get some pics up of the engine bay.
James.
James.
- shabtheventurer
