Fast idle with clutch in while driving?
Postby jamezz666 on Wed Apr 15, 2015 12:58 pm
hi guys,
bit of an annoying one here, no matter what when i drive the car, if i put the clutch in the engine stays ticking over fast and when i come to a stand still it will gradually go down. but i could move the car the slightest bit and put the clutch in and the revs stay high and gradually come down?
jamezz666
Your car: mk3 xr2i
Re: Fast idle with clutch in while driving?
Postby mikeymikeyp on Mon Apr 20, 2015 9:49 pm
id try cleaning the idle vale ,,the fact you dip the clutch when stationary is tricky to diagnose ,,Unplug the idle valve take it a spin and if its okay then clean the idle valve :-?
mikeymikeyp
Postby jamezz666 on Tue Apr 21, 2015 12:24 am
hello,
thanks for the reply, iv'e solved it now, i have 5 idcv and all of um done the same, even after dipping them in petrol. well i went and got a can of pressured carb cleaner and blasted the idcv and it worked a treat :) so i guess petrol wouldn't cut it haha
jamezz666
Your car: mk3 xr2i
