few issues with the fiesta rs turbo
Postby rob pace on Tue Dec 03, 2013 1:16 pm
hi peeps got a couple of issues with the fiesta rs turbo -
basically when i come to a stop when i am in gear with the clutch depressed i get a juddering, also there is a bit of a crunch and judder when the car goes into reverse gear, its not smooth to get into reverse!
also when i come to a stop the car will idle at about 2000rpm before taking some time to get down to idle speed again!
ive got an idea but want to hear your possible thoughts? best regards :)
rob pace
Re: few issues with the fiesta rs turbo
Postby Boostjunky on Tue Dec 03, 2013 2:50 pm
Thrust bearing and or pressure plate :)
Boostjunky
Your car: Ford
Postby mikeymikeyp on Tue Dec 03, 2013 7:22 pm
have u the proper oil in it ,,they usually aint a great gearbox for reverse ,i usually press the clutch twice then go for reverse
is it jumping out of gear ,im guessing its an ib5 fiesta or escort ,mind the escorts a lsd so needs synthetic oil
mikeymikeyp
Postby rob pace on Thu Dec 05, 2013 9:50 am
mikeymikeyp :have u the proper oil in it ,,they usually aint a great gearbox for reverse ,i usually press the clutch twice then go for reverse
cheers, lot of people said its possibly the self adjustor or the ratchet on the pedal.
rob pace
going into gears is fine when cold, just a few issues when engine is up to temperature :)
rob pace
Postby rob pace on Wed Dec 25, 2013 12:39 pm
im thinking its the diff in the gearbox as the seals are weeping oil a little? goes into reverse fine when its cold, only occurs when warm!
rob pace
Postby jayrs on Wed Dec 25, 2013 2:31 pm
Hmm, could be a few things really, basically what's been said already.
I think I would be tempted to start with a new clutch cable, mainly because there cheap (provided you don't go to ford for one!) and easy to fit.
Would also check the fork on the gearbox, I've seen these split around the spline and cause issues.
All that said if its doing it when warm but not cold its prob not that.
As for the idle problem when stopping, mine used to do it, then stopped by it self after checking countless stuff, however I did swap out the TPS around the time it stopped, so it could of been that.
But bare in mind, this time of year when the ambient temp is low, it can cause the idle speeds a Frst to sometimes act erratic
Postby rob pace on Fri Dec 27, 2013 10:38 am
jayrs :Hmm, could be a few things really, basically what's been said already.
hmm im think its a new box thats possibly needed as its fine when cold but when warm its a bit clunky!
rob pace
Postby jayrs on Fri Dec 27, 2013 10:47 am
Could well be mate, or rebuild it
Postby rob pace on Fri Dec 27, 2013 10:01 pm
jayrs :Could well be mate, or rebuild it
any ideas where i can get a new frst box from? seen a few on ebay over the years!
rob pace
Postby jayrs on Fri Dec 27, 2013 10:47 pm
Problem is rob, getting a new one is going to be hard if not impossible, and any that are new or sold as recon may not be a proper FRST box.
Your be better off getting a ERST recon box and having the LSD, or sending your box away to be rebuilt
