Fiesta Azura - 13/05/14 - Page 3 - Just bits and bobs!
89 posts • Page 1 of 3 • 1, 2, 3
Some of you may have seen my poor little Popular Plus is pretty much on its last legs, so a suitable replacement was required to get my track day fix!
My main concern was rust, as that is basically my biggest issue with the old one, but initially I also wanted it to be pre 92 so that I could continue to run it without a cat and also being a MK3, I could use my existing suspension. Having missed out on a few early MK3s, and deciding against one that I actually viewed twice(!) because it had too much else wrong with it, I ended up settling for a 1995 1.1 Azura. I convinced myself the cat issue isn't a major problem, I can just fit a sports cat at some point, and with regards to the suspension I'll just swap the hub carriers, lower arms and turbo drive shafts over in order to use my Koni setup. Everything else should be pretty simple.
There's not a lot else to say at the min, and not a lot will be happening for about two weeks, but when it does there will be some proper updates.
Just a couple of photos for now:
Sadly, it's had a bit of a car park incident and the driver's side wing and a bit of the door are a little untidy:
... but at the end of the day, it's for track, and I can fix them at a later date if it really starts to bug me. The main thing with this is that it's solid absolutely everywhere
Just a shame it's red... The white ones will always be faster!
- Smo
Re: Fiesta Azura - 09/02/14 - Page 1 - The Start!
Haha, yep, white ones are faster
- hb69
- Your car: Fiesta 1.1 LX
I'll run a cat on mine, it doesn't really make any difference if you stick to a decent 200 cell
Would a 100 cell offer any advantage over a 200? 200 seem to be more commonly available and for better money.
- Smo
Looks nice! Can't wait to see what you do with her
- Christina
- Your car: '90 Fiesta Popular Plus Mk3
- knuckles
- Your car: Fiesta Rs turbo
- Smo
Smo :Would a 100 cell offer any advantage over a 200? 200 seem to be more commonly available and for better money.
The performance difference is negligible but the 100 cell can give MOT issues and the cheaper ones don't last very long before becoming completely marginal.
Just seen the car now images aren't blocked by work proxy. I was looking for a Mk3.5 last week and thought you may have bought http://www.ebay.co.uk/itm/1995-FORD-FIE ... true&rt=nc
Yours looks good too!
I was watching that, as well as another in Norwich (which was sold for £500 on Gumtree and then immediately offered for £600 on eBay!), but the distance was a bit further than I was willing to travel if they turned out to not be what they were described as!
Mine's not perfect, but for what I saved in travelling and price, I can correct its issues as and when I feel.
I do wonder how long it'll be before the lack of rear wiper bothers me, though
And cheers, I shall take a look at the 200 cell options
- Smo
If no rear wiper is annoying, try having one that doesn't work!
- Christina
Glad to see you found a clean one don't go spraying it green now tho look forward to seeing this unravel ! If you need a hand with anything give me a shout buddy I'm about to lend a hand also as per the rear wiper il have a look at the weekend I should still have mine somewhere from when I took it off
Russ
Russ
- russ-RST
- Your car: fiesta rs turbo
Christina :If no rear wiper is annoying, try having one that doesn't work!
Oh, I've had years off that!
Cheers, Russ Probably not too bothered about the wiper in the long term, because I don't think I can be bothered messing about with the wiring!
I'll be swapping the engine in a couple of weeks time. Everything's planned, and I'll be giving myself about 12 hours to do it in. We'll see how it goes!
- Smo
Smo :Christina :If no rear wiper is annoying, try having one that doesn't work!
Oh, I've had years of that!
- hb69
- Smo
So, this is the engine going in:
... completely standard 2.0.
Tony Law 4-2-1 will be coming over too:
Not sure about the cage at the min, bit undecided:
Zetec S rear beam will definitely be going over from the white one:
Also the Koni adjustables - they're looking a bit ropey now, though, so I may replace them soon. Poor photo:
Lastly, I have another gearbox, a CTS stage 2 - same longish ratios as my current Escort GTi box, but with the addition of a Quaife ATB differential. This is something I've wanted for ages (not the box particularly, but a decent diff), so I'm looking forward to seeing what it will do. The unfortunate thing is I'll be going back to a front start BC style box, just with an iB5 gear set. Long term, I'll swap the diff out into another rear starter iB5 casing as I've been much happier with this setup. No photo of this either, but it just looks like your average MK4 Escort gearbox!
Once it's on the road, I shall probably do the same as Henry (hb69) and polybush the lower arms using Powerflex's black series bushes - they've looked quite promising so far on Henry's car, so again, looking forward to seeing how they go on track.
- Smo
- dontpannic
Re: Fiesta Azura - 12/02/14 - Page 1 - Jenvey Throttle Bodies
So, bought these back in December...
Jenvey 45mm throttle bodies:
Firstly, in this state they're a major bodge. Poor throttle linkage, white silicon sealant everywhere, standard 2.0 Focus injectors (which actually flow less than 2.0 silver top side feds!), and to top it off, a standard Focus fuel rail - which means the injectors were actually sitting wonky in the bodies! The spacing is completely wrong.
So with all the dodgy stuff removed, I trial fitted them:
Space will be fine, should be enough for a decent foam filter; any longer and I'd have had issues. I'd ideally like to run longer trumpets, but I can do something with the back panel if and when the time comes.
So next up, I wanted a proper fuel rail. The usual one is the two piece Jenvey item which you join with a cut-to-length joiner, however Jenvey make a one piece item properly spaced for the Zetec E setup...
... such as this one on my desk at work:
I also wanted injectors that would happily flow enough for my current expected power (roughly 170bhp) and any potential increase in the future, so I went with VAG 1.8T items from an AUM lump:
AUM engines produce around 150bhp as standard, and easily cope with 220 to 230bhp on standard injectors, and more with an increase in fuel pressure. Basically, they're fine for what I want
The injectors are quite short, though, so some custom spacers were required...
... which I had made for me:
The next problem was brake servo. The manifold had no vacuum port, so I had one fabricated and welded on:
A part complete linkage was obtained:
And with the help of a chap at work, fabricated an additional bracket to use the standard throttle cable:
As you can see, it doesn't allow the cable to sit in the quadrant comfortably, so I will rethink this. However it does allow perfect throttle opening - when the pedal is at the stop, the butterflies are 100% open, without any part under stress. When I come round to fitting them properly, I'll probably use a universal cable to solve the quadrant situation, we'll see.
I've had them running briefly using the standard ECU to make sure they run and get a decent idle - that I'm happy with. What I'm not happy with is the brake vacuum. They're producing a vacuum, but not enough to operate the non return valve to the servo... Something to look at later down the line. I have Megasquirt (which works fine and I had mapped on my old 1.8 to some degree), but I'll probably replace it with something like Emerald when I come round to fitting the bodies properly later in the year. At the min, I'm going to get everything running as it is with the standard inlet and management to make sure all is good with the car, and do a few track days, then come back to these
- Smo
You need a common take off for vacuum, mate.
This was the update I as waiting for. ! I'm so looking forward to hearing this
What are you doing with the old gearbox (s) then I could do with one that doesn't leak oil everywhere
As mark has already said you need a vacuum that comes from all 4 I take runners , if your stuck for ideas look at bike throttle bodie installs , also my mate has a 306 on bike tb's you could nose at that if you like? It's not pretty tho!
Russ
Russ
- russ-RST
Hmm, there seems to be mixed views on that, most saying that one is enough?
Some say a one way valve is required for each if you go that way, however I'll still have the same issue with not producing enough vacuum to operate them?
So do I ideally need a reservoir?
Or a one way valve that requires less vacuum to open?
Russ, my gearbox will be no good to you as it's a rear starter and would foul your rear crankcase breather. Plus it's knackered
- Smo
Smo :Hmm, there seems to be mixed views on that, most saying that one is enough?
One is most definitely not enough; if you think about it you've at worst got a quarter of the available vacuum at one time. In reality and based on firing order and cam duration/timing it is more like half.
Why would you need a one way valve for each? Doesn't make any sense. You should have a take off on each port and a common line to the servo which is where the one way valve belongs - the ideal would be a vacuum rail with 15mm bore to act as a damper. The vacuum potential of your engine hasn't changed hence neither should the specification of the one way valve.
One of my other cars has ITB's fitted from the factory and is plumbed as I describe.
Iv only known people to join then myself, a one way valve with lesser pressure sounds a good alternative.
Ah fair do's buddy , well I'm on the look out for a rear starter ib5 for the zetec also what's on the 1.1? Engine ?
Russ
Russ
- russ-RST
That's fair enough, Mark, I'll go that route!
There is so much conflicting information about this out there!
Russ, you can pick up GTi boxes so cheap, just keep an eye out. You'll need a custom bracket for one half of the front mount as it's different where the starter motor isn't there. I modified the other half as one of the holes was in a different place if I remember rightly. The rear mounts the same. You need a rear starter from something like a late Zetec Escort as the mounting holes are different, and probably some of the wiring too. You'll also need to modify the 1.8 block to allow the starter room to fit. Lastly, you'll need the gearbox register from a rear starter Escort too.
Nothing from the 1.1 is available for the time being, sorry!
- Smo
If I got coilovers would you be interested in my current suspension?
- hb69
I had 1 vacuum on my throttle bodies and it worked perfect.
- Rhinopower
- Your car: Volvo FH330
Rhinopower :I had 1 vacuum on my throttle bodies and it worked perfect.
This is what a lot are saying. What one way valve did you use? The standard one?
- Smo
posting to simply keep updated with this in my posts
- Minstral
- Your car: *
Looks nice and tidy, a mk3.5 would have a slightly stiffer chassis anyways??
- Gus!!
- Your car: Mk3 Fiesta ghia 1.1!!
Indeed it does!
I remember the first time I went out in a Fiesta Si and being amazed how tight everything felt. Driving this new one of mine home wasn't far from that. I'm really looking forward to seeing how different the car will be from the Popular Plus (and its floppy floor) with the suspension and power. That said, the cage definitely made things better in the previous car!
- Smo
Over the weekend, the Fiesta underwent some major surgery. As I had a camera with me, ill update this thread with photos of the events that took place
The setup for the work was pretty substantial, seeing as we were used to lying on the floor in the rain this was quite amazing
The new, the old, and the middle aged
As it was a two day event, myself and smo started by doing the jobs that needed doing at the back of the car, these were fuel pump and rear beam/suspension
Tank coming off the white one
Where it used to reside
Photo through the inspection hole, just because I could
Tank off the red one
Having a gander at the pump
New tank/pump in the red one and fuel line fitted
Then we moved onto the rear beams
Standard 1.1 beam
Removed it
Then the polybushed zs beam and konis off the white one, disconnected the brakes first
Undid the top shock bolts
And on the floor
On the red one, fitting handbrake cable
Steels on, and on the floor
That concluded the antics from the first day.
Next day was the majority of the work due to take place. We started at about 8am
Me and Steve started with the front suspension on the white one. It all needed to be moved across, carriers, lower arms, arb, hubs, track rod ends, and shocks
While Nick and Eddy started dismantling the red one
Eddy had a split glove situation
With the suspension removed, the work started on removing the 1.1
Eddy gave it mouth to mouth
5 minutes later it was sitting on a table on wheels
Table modelled by Burman here
Miniature Simon was happy with this
Burman had conquered it
And Eddy took it away
Where it sat in the naughty corner, and had some time to think about how slow it was
We had a look at the empty engine bay
It was red and empty
Then we started on removing the zetec from the white one
This made Steve happy
And me
Out it came, onto the table with wheels again
Lowered down, ready to have the new clutch and lsd gearbox fitted
Lunchtime!
Then into its new home
Some jiggling to get the cradle lined up
Started to refit the front suspension
Steve with his favourite tool
Me and Toby did the other side
Empty engine bay on the white one
But a garden hose was needed from it
Mark wanted to be in the engine bay, so got in
Then we put the bonnet down
Some sort of leak occurred on the red one
Engine in its new home
Bleeding the brakes
The man in the cabin
Pointing at something?
A commotion
On to starting it for the first time, there was an earth that hadn't been connected so the battery light stayed on
Connected the earth. Started up fine.
Happy days
Back on all its wheels
Old engine in the back of the white one
Slammed
Something in the bin?
White one ready to roll out into the open
With Burman at the helm
Fuel for the journey home
Tired
Time to leave
The car left and im reliably informed it successfully completed its maiden journey. Top banana.
Standard 1.1 beam
Removed it
And on the floor
And me
Lunchtime!
Bleeding the brakes
A commotion
Happy days
Slammed
Tired
Time to leave
- hb69
Re: Fiesta Azura - 25/02/14 - Page 1 - 2.0 Zetec and stuff...
Nice write up, Butler.
I'm looking forward to our "beer and burger" reward for such an eventful day!
- bakewell001
Cheers, Henry, an update and a half!
Thanks to everyone that helped; I only had the ramps for the weekend and was a little stressed out at the thought of not being off the ramps by the end of Sunday!
Pretty boring video, but its first drive:
- Smo
- dontpannic
Nice quick turnaround there. The red car sure is a contrast to the old white one!
Excursion :Nice quick turnaround there. The red car sure is a contrast to the old white one!
We don't f**k about Mark!
- dontpannic
