Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13
Re: 2.0 ST170 Bonus Dirtbox Sleeper - throttle bodies ready 10/8
That's a proper way to make some throttle bodies up!
- Smo
Much better than the st170 manifold that doesn't line up with a standard head, and ports which are oval and don't match motorbike body oval ports. This setup is full of win!
- Rhinopower
- Your car: Volvo FH330
Think you need to get another one made up
- Smo
The jig is made now so any further manifolds will be cheaper. Still looking at about £400 all in but worth it IMO
- Rhinopower
- Smo
Come on monkeyspank, get it fitted. You can always drop it off to me and I will return it in a couple of years.
I've just got some bolts and instant gasket to bolt it to the head. Tonight Simon!
- Rhinopower
It runs!
- Rhinopower
- Smo
Re: 2.0 ST170 Bonus Dirtbox Sleeper - ITB's Fitted 10/8
On my Facebook page! Haven't uploaded it to photobucket yet
- Rhinopower
re nos, are you going to go for a separate, progressive delivery system or use the megasquirt to deal with that ?
Nothing to see here...
- andymac
- Elite Pie Master
andymac :re nos, are you going to go for a separate, progressive delivery system or use the megasquirt to deal with that ?
Running a progressive controller, and megasquirt to only allow the nitrous to operate between 2k and 7800 rpm
- Rhinopower
2.0 ST170 Bonus Dirtbox Sleeper - Trumpets & Cams
Finally got some trumpets on the throttle bodies, and pretty cheap at £21 delivered for a set of 4 from hong kong, they are direct fit
Also received a nice package of my piper BP285 cams!
Also got a nice shiny vernier and a set of valve top shims which will all need machining once i've calculated clearance and tolerances. The cams are reprofiles!
Im going to remove the head and give it a complete overhaul, check valve seal & re-lap as required, remove any of the sharp lines in the casting marks inside the ports, and replace all the valve stem oil seals. With the head off it will make valve clearances easier to check.
Enjoy!
Enjoy!
- Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Trumpets & Cams
nice fuel filter install
did you move the power steering pipe away from the brake pedal bar ?
- knuckles
- Your car: Fiesta Rs turbo
knuckles :nice fuel filter install
Yes! Thanks for spotting that one!
I did have a smaller filter on there but had to change it when i fitted the braided fuel lines
- Rhinopower
yea snap lol, might i recommend this?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220812335795&clk_rvr_id=288984317176
cams should give it a gooood kick up the arse, i want some verniers, do blacktop ones fit silvertops?
jonyb4 :knuckles :nice fuel filter install
Nice one with the sticker! Lol
Yeah blacktop ones fit too!
The head is going to have a skim, valves refaced, 3 angle valve seats cut, lapped, shimmed, new stem oil seals and camshaft oil seals.
Everything i should of done before fitting it in the first place!
- Rhinopower
ahh great , shall be wanting some one day
should breath plenty better soon then
jonyb4 :ahh great , shall be wanting some one day
I was reading all about the three angle valve seats earlier, really interesting stuff how standard seats slow the air down due to turbulence, but with the 3 angles you can get 8-15cfm more air into the combustion chamber. More air, more fuel, bigger bang!
I will smooth the sharp casting marks of first before it gets skimmed and dunked in the acid bath etc!
- Rhinopower
Next set of results should be interesting mate. Trumpets work out well - are you going to run a sock over them?
Yeah. Socks ftw! Soak them in an oil based air filter cleaner to stop any moisture ingress given their position.
- Rhinopower
yea at college we spent quite a bit of time on valve seats and 3 angle seats, was really interesting, the turbulence it causes makes the air entering the cylinder in a bad way and can actually effect the combustion pulses on the power stroke!
Re: 2.0 ST170 Bonus Dirtbox Db250 - Trumpets & Cams
Title edited to reflect the probable power after new cams are fitted.
- ~nomad~
- Your car: Breadvan
- Rhinopower
omg your SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO funny
cheers man! xxxx
- ~nomad~
Well played lads!
- Michael!
~nomad~ :Title edited to reflect the probable power after new cams are fitted.
- dontpannic
Little update:
Car went on the rollers the other day, and came away pretty disappointed.
Firstly, the car was going really lean after 5800rpm. Fuel pressure was perfect so we flow tested the injectors. These turned out to deliver 85cc/min, quite far from the expected 320cc/min. On further investigation these turned out to be 1.4 zetec injectors, not st170. However, dyno man Ian at power engineering had a spare set of audi 225bhp injectors kicking around (made by Bosch) so these were chucked in and instantly added another 15bhp.
The next problem was the car hitting a 'hard cut' rev limit at 6800rpm. Pretty annoying seeing as the car is built to rev to 8000rpm. This was discovered this evening to be because the crank sensor wiring needed reverting, although this is not listed in the megasquirt manual when you upgrade from ms1 to ms2.
On the day the car came away with 166bhp @ 6800rpm, so plenty of scope to climb higher in the last 1200rpm, it might even make a bit more across the scale if it's picking up a better crank signal, the sensitivity of the signal has been adjusted perfect using the tooth logger option in the diagnostics.
- Rhinopower
- Smo
Re: 2.0 ST170 Bonus -166bhp @ 6800rpm...
Smo :Come on then, get it sorted!
I have, just can't get it back on the dyno at this time of the evening! Lol
- Rhinopower
The noise this makes i wouldnt care if it only had 1bhp
- hb69
- Your car: Fiesta 1.1 LX
It sounded amazing on the rollers, and went very well on the road the other day. Just needs another run to get a figure and iron it out
- ~nomad~
hb69 :The noise this makes i wouldnt care if it only had 1bhp
The noise is epic
Glad you found the problem mate, roll on RS Combe.
- Turboboy67
- Your car: 911GT3 RS
I said on the day that it sounded like a helicopter. I've changed my mind now. It sounds like predator.
- dontpannic
