Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13
Re: Fiesta Bonus - Zetec Turbo Update
Postby Excursion on Tue Jan 29, 2013 6:45 pm
Coming along nicely. What's with the snapped off block lug?
Postby Rhinopower on Tue Jan 29, 2013 7:30 pm
Erm..... Where? I've not noticed anything :-(
Rhinopower
Your car: Volvo FH330
Postby Rhinopower on Tue Jan 29, 2013 7:34 pm
Next to the dipstick tube? Normally it just sticks out a bit. I expect it was removed as part of the fitment in the kit car it was removed from
Rhinopower
Postby Excursion on Tue Jan 29, 2013 7:48 pm
Rhinopower :Next to the dipstick tube? Normally it just sticks out a bit. I expect it was removed as part of the fitment in the kit car it was removed from
Ahh ok. Might be worth blowing brake cleaner along the metal feed line if you haven't already done that, as those hard lines are responsible for early turbo failure in a lot of cars. They don't tend to dissipate the heat like braided hose so the oil gets cooked and cokes the inside walls near the turbo itself, which then leads to issues.
What's your ETA for this? It will make a nice engine when complete.
Postby Tweek on Tue Jan 29, 2013 7:51 pm
Now I've seen the pics it makes sense. I got your message before I saw this :lol: Cheers.
Your car: VW Golf GTD
Postby Turboboy67 on Tue Jan 29, 2013 8:03 pm
Good progress mate :Q
Turboboy67
Your car: 911GT3 RS
Postby Rhinopower on Tue Jan 29, 2013 8:06 pm
Il get on the case of cleaning the line through. It is something I wasn't aware or thought of.
If everything goes to plan 4-6 weeks it will be on the road!
Rhinopower
Postby Excursion on Tue Jan 29, 2013 8:12 pm
Rhinopower :Il get on the case of cleaning the line through. It is something I wasn't aware or thought of.
I forgot to ask - do you still have the rear ARB on the ST170? I'll buy it if so mate.
Postby Rhinopower on Tue Jan 29, 2013 8:19 pm
Yes, drop dave a message, i believe its already unbolted so easy to post :)
Rhinopower
Postby ~nomad~ on Wed Jan 30, 2013 12:22 am
yeah the full beam is off the car, in fact i have 2 lol
~nomad~
Your car: Breadvan
Postby Excursion on Wed Jan 30, 2013 12:33 am
~nomad~ :yeah the full beam is off the car, in fact i have 2 lol
Text me a price inc delivery please Pooks.
Postby Rhinopower on Sun Feb 17, 2013 7:12 pm
Got some more enthusiasm today at about 3:30pm.
Bolted in the battery tray, ran the new fuel lines, battery cable, bolted in the swirl pot and fuel pump, and fitted the front live terminal to the inner arch. Pictures should explain all :)
Rhinopower
Re: Fiesta Bonus - Zetec Turbo Update 17/02/13
Postby knuckles on Sun Feb 17, 2013 7:22 pm
I'd recommend venting the battery to atmosphere.
I can get you a vent tube from ford off a transit which goes through the floor ?
Stops any harmful smells coming out of it when charging :)
knuckles
Your car: Fiesta Rs turbo
Postby Rhinopower on Sun Feb 17, 2013 7:40 pm
Yes please mate!
Rhinopower
Postby ~S1~ on Mon Feb 18, 2013 12:40 am
If that's a rigid joint between pump & swirl pot you'll need to mount the pump better otherwise you'll end up fracturing the swirl pot or fuel pump.
~S1~
Hold On...
Hold On...
Postby Rhinopower on Mon Feb 18, 2013 8:41 am
Yes it's rigid, I just need to find my clamp I got for the fuel pump to bolt it down too!
Rhinopower
Postby RS rob on Tue Feb 19, 2013 3:06 pm
just had a quick catch up through the last few pages,
really is coming along nicely, shall keep an eye on the progress :D
RS rob
Postby knuckles on Wed Feb 20, 2013 12:05 am
your battery vent tube is now in stock
£9.50 :)
knuckles
Postby Rhinopower on Sat Mar 23, 2013 4:01 pm
Wiring loom is almost done! All i need now is the connector from a focus so my injector loom can be connected to the main loom, i wanted to keep it detachable like standard
The main earth connection
Crank sensor and coil pack connections (all brand new terminals)
Connector to make it plug and play with the car loom, and a sub connector to make the wideband lambda controller detachable
The last wires going to the new connector
All comments and criticism welcome :)
Rhinopower
Re: Fiesta Bonus - Zetec Turbo Update - Wiring 23/03/13
Postby dontpannic on Sat Mar 23, 2013 5:45 pm
Looking good dude!
Postby jonyb4 on Sat Mar 23, 2013 7:09 pm
looks crap!
nah man its some good work there! digging the rug too ;)
Postby Tweek on Sat Mar 23, 2013 10:18 pm
Hopefully yours works when you plug it all in :lol:
Postby Rhinopower on Sat Mar 23, 2013 10:35 pm
Tweek :Hopefully yours works when you plug it all in :lol:
I hooked it up onto a 12v supply and checked over most of it on the floor this evening, temp sensors work. I'l plug the rest into the car tomorrow and test the fuel pump relay and other 12v connections
Rhinopower
Postby Max M4X WW on Sat Mar 23, 2013 10:48 pm
Dreading looking at my loom, no idea about any of it.
Postby Tweek on Sat Mar 23, 2013 10:54 pm
Max M4X WW :Dreading looking at my loom, no idea about any of it.
Well, you've got a few months before you look into that :lol:
Postby Dave5300 on Sat Mar 23, 2013 10:55 pm
just read threw this hole thread, love it! some work gone into it :)
Dave5300
Postby Smo on Sun Mar 24, 2013 5:00 pm
Very sexy!
Smo
Postby dontpannic on Sun Mar 24, 2013 5:10 pm
You're all lucky. My loom is French. Half of it is probably made from cheese.
Postby andymac on Wed Mar 27, 2013 11:41 pm
Sheriff Burman :You're all lucky. My loom is French. Half of it is probably made from cheese.
Nearly, it's 50% made from the holes in cheese, that's why French electrics are historically a bit... gorgonzola.
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Rhinopower on Mon Apr 01, 2013 7:51 pm
Today this happened
With only 2 trolley jacks....
Need to work out spacing the rad and intercooler setup, but I expect first step is ditch the bonnet release cable, fit removable slam panel, and lockable aero catches
Rhinopower
Re: Fiesta Bonus - Zetec Turbo Update - April fools! 1/4/13
Postby jonyb4 on Mon Apr 01, 2013 8:13 pm
:Q Getting there
Postby Tweek on Mon Apr 01, 2013 11:13 pm
I managed to do it with the original slam pannel, radiator and bonnet catch support so I'm sure you can :lol:
Postby Rhinopower on Mon Apr 29, 2013 6:55 pm
New slam panel, originally fitted to one of the uk's fastest zetec turbos, hopefully it gives me some good luck!
Rhinopower
Re: Fiesta Bonus - Zetec Turbo Update - boring update 29/4/13
Postby Rhinopower on Tue May 14, 2013 6:39 pm
It's running! Waiting to get my downpipe back then make up the flexi pipe. It's idling a bit high so il check for vacuum leaks before I start messing with iscv settings.
Rhinopower
Re: Fiesta Bonus - Zetec Turbo Update - engine running 14/5/13
Postby Smo on Tue May 14, 2013 7:25 pm
What, no video?!
Smo
