Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13 : Member's Gallery - Page 9 | Fiesta Forums
Re: 1.8 zetec Bonus Dirtbox Sleeper - 5/9 Nitrous oxide fitted
Postby Excursion on Thu Sep 09, 2010 9:08 am
Sounds like good fun!
Can you use the TPS to bring in the NOS progressively?
Postby Rhinopower on Thu Sep 09, 2010 10:25 am
When the pulsoids are used progressively they are pulsed on and off, so it would be a case of building a circuit that increases the pulses as the TPS goes from 0-5volts (the pulsoids run at 12volts). I think i should do a little bit of research :)
Rhinopower
Your car: Volvo FH330
Postby Excursion on Thu Sep 09, 2010 11:17 am
Rhinopower :When the pulsoids are used progressively they are pulsed on and off, so it would be a case of building a circuit that increases the pulses as the TPS goes from 0-5volts (the pulsoids run at 12volts). I think i should do a little bit of research :)
Definitely :D 555 timer and a few other readily available components. Easy :D
Postby GRANT-XR on Fri Sep 17, 2010 9:59 am
Hi mate love this car seen it in pf mag i also have similar plans to do this conversion on my mk5 escort popular, Thing is i can do it all myself but im at a loss with the wiring joining the new engine loom into the original car loom just wondered if you can help me out with wire order and colours if you dont mind~? cheers, Grant :D
GRANT-XR
Re: 1.8 zetec Bonus Dirtbox Sleeper - 22/9 Gotech Pro
Postby Rhinopower on Wed Sep 22, 2010 9:56 pm
Little update with pictures to follow.
Yesterday i made up two pig-tail looms for my gotech pro ecu, cannibalising an ofab loom in the process as i only had new plugs and terminals to go with the ecu,
Tonight i soldered in most of the wires onto the existing zetec loom with a couple of jumper wires to change it from sequential efi to batch firing on the injectors, and in such a way that if needs be, it can run on a DEEP ecu. Left to wire is the Tps, Cts, and IAT sensors but the engine does start and run, all be with my foot resting on the throttle pedal to slightly open the butterfly, the gotech pro doesn't run an ISCV!
Rhinopower
Postby ~nomad~ on Wed Sep 22, 2010 11:50 pm
lovely business, cant wait to get started on sleeper 2!
~nomad~
Your car: Breadvan
Postby Excursion on Thu Sep 23, 2010 9:09 am
Rhinopower :Little update with pictures to follow.
So without a DBW TB, how are you supposed to manage a stable idle?
Postby jimmyesh on Thu Sep 23, 2010 4:00 pm
Top work - I love sleepers and this one just keeps getting better :Q
jimmyesh
Your car: Yes
Postby Smo on Sat Sep 25, 2010 12:57 pm
I better get a move on with mine :oooh:
Smo
Postby Rhinopower on Sat Sep 25, 2010 1:13 pm
You are still alive then! Best get yourself sorted and come Santa pod end of October and see who is fastest on the quarter mile!!!
Rhinopower
Postby Smo on Sat Sep 25, 2010 1:47 pm
I've been away :D
And it'll be you and Dave because there's no chance of me being there :lol: Need to go back to a shorter gearbox because that one I've got is useless and I've got loads I want to do which I can't see being done this side of Christmas :(
You going to map the Gotech yourself? :D
Smo
Postby Rhinopower on Tue Sep 28, 2010 9:11 pm
Gotech is out, fudgekin thing! Probably the most un-userfriendly software in the world, made a tidy profit on it and going for megasquirt instead.
Also picked up a second 11lb nitrous bottle today to save on trips to get refills.
Further down the line were now looking at a st170 engine based on the fact the bottom end can take around 300bhp in standard form, and ignition can be retarded sufficiently to run a 100bhp shot of nitrous, and running throttle bodies.
Rhinopower
Re: 1.8 zetec Bonus Dirtbox Sleeper - 28/9 Gotech Pro REMOVED
Postby Smo on Tue Sep 28, 2010 11:27 pm
Oooooh.
Smo
1.8 zetec Bonus Dirtbox Sleeper - 7/10 - Innovate LC1
Postby Rhinopower on Thu Oct 07, 2010 10:43 pm
Came next day delivery from latvia! Pretty good from an ebay seller, should have the ms tomorrow and then upgrade it
Rhinopower
Postby ~nomad~ on Thu Oct 07, 2010 10:47 pm
cheeky stuff. desperate to start version 2 now lol
~nomad~
Your car: Breadvan
Postby Smo on Thu Oct 07, 2010 10:48 pm
Haha, excellent. Was that the same seller I used?
Smo
Re: 1.8 zetec Bonus Dirtbox Sleeper - 7/10 - Innovate LC1
Postby Rhinopower on Sun Oct 17, 2010 4:56 pm
Smo, yes the same seller, very good turnaround.
Today i fitted my WoN progressive controller so i can get more gas from a bottle, should help with traction issues when it kicks in too!
Also dummyed up the twin bottle mounting, the red and black looks pretty handsome i think.
Rhinopower
Re: 1.8 zetec Bonus Dirtbox Sleeper - 17/10 - More Nos Upgrades
Postby ~nomad~ on Sun Oct 17, 2010 5:52 pm
controller mounting looks pony, will make sure i do a better job in ka!
~nomad~
Your car: Breadvan
Postby Ruishy1 on Sun Oct 17, 2010 6:47 pm
maybe need to change your name to NitroPower :lol:
i like the mounting, who needs pretty when you can have fuinctional :Q
Ruishy1
Postby Smo on Sun Oct 17, 2010 7:31 pm
Beautiful :)
Smo
Postby ~nomad~ on Sun Oct 17, 2010 9:49 pm
Ruishy1 :maybe need to change your name to NitroPower :lol:
you can have both!
~nomad~
Your car: Breadvan
Re: 1.8 zetec Bonus Dirtbox Sleeper - Santa Pod 24/10/10
Postby Rhinopower on Mon Oct 25, 2010 9:26 pm
New personal best at santa pod yesterday, 15.2 1/4 mile, 97mph terminal speed :)
Few more updates to follow once i've got pics.
Rhinopower
Postby ~nomad~ on Mon Oct 25, 2010 10:27 pm
I have a few pics, will upload them.
~nomad~
Your car: Breadvan
Postby Smo on Mon Oct 25, 2010 11:05 pm
Not bad! Was that with the nitrous oxide?
Smo
Postby ~nomad~ on Tue Oct 26, 2010 9:30 pm
few pics from sunday, was a good day, good to see Shaun (carbongay69er), Jon Frst and other fella what bought Shauns shell, also saw Lucas car, didnt speak to luke as he looked busy lol, car looked rapid thou :o , Gav (butcher) was there, car looked great, and saw Crazy cages car but didnt manage to see it run.
The que for strip was mental!
pod at 8 in morning, weird seeing it so empty, we were actually the first in que for strip, ended up 3rd to run.
awesome Jamsport FRS, only thing I didnt like was the cage, which looked dangerous to me tbh.
stupid, loud, anorak attracting fudgekin dragcrap.
got spanked
mighty boosh themed drag bike!
datsun 240z, this is a real car folks!
Brians s**t bodged wiring meant he had to do another bodge as nitrous controller was blowing fuses lol
ratchet strap and hairy string around the nitrous bottle, as Brian cant even do a bottle bracket up right.
fudgekin hell
lovely Pod
Harvey gibbs doing 10.5!
~nomad~
Your car: Breadvan
Postby FRSJON on Thu Oct 28, 2010 7:38 pm
was good to see you mate,bloody cold though :oooh: some rapid cars :Q those bloody bikes though,just like they do on the road,go round everyone to get to the front! saw a bike go up the strip,drive all the way round and push back in to the front! i would of ran the c**t over! :D
FRSJON
Postby Smo on Thu Oct 28, 2010 7:40 pm
One day I shall be there! :lol:
Smo
Postby Rhinopower on Thu Oct 28, 2010 7:59 pm
Smo :One day I shall be there! :lol:
Yeah, and the dirtbox will do a 12 second quarter!
Rhinopower
Postby Smo on Thu Oct 28, 2010 8:07 pm
Oi!
And I did say one day... It's not like I've specified exactly when that'll be yet :lol:
Smo
Postby jonyb4 on Fri Oct 29, 2010 12:53 am
looked like a great day out guys, f**k harveys car is mental! i remember its 2.9 at silverstone :aaah:
and that jamsports focus is stunning!
Postby Excursion on Fri Oct 29, 2010 8:44 am
Go and do some real driving :lol:
Postby ~nomad~ on Fri Oct 29, 2010 1:27 pm
Excursion :Go and do some real driving :lol:
like what? Car did a trackday at Bedford the day after Pod, and gets the f**k thrashed out of it everytime it goes on the road, last time I drove it I offroaded it to escape from a L200 on the lanes! I cant think of many cars that get used as real as this one tbh! :lol:
I has a st170 exhaust manifold fitted now, boosh.
~nomad~
Your car: Breadvan
Postby ~nomad~ on Fri Oct 29, 2010 1:35 pm
One st170 manifold modified for mk3 fiesta zetec fitment, fitted to the car now, bolts straight up to zetec, will be tested extensivily and then can be provided as a service if anyone wants one!
~nomad~
Your car: Breadvan
Postby Excursion on Fri Oct 29, 2010 1:54 pm
~nomad~ :
Oh, in that case, my apologies :D
Postby ~nomad~ on Fri Oct 29, 2010 2:05 pm
Excursion :
~nomad~ :
accepted lol. Did you think it was a 1/4 mile car? Not really suited for that tbh, not enough power and gearbox is too long, 3rd for 60! But 1/4 days are fun. I don't see alot of point in cars that are only good for that thou tbh.
~nomad~
Your car: Breadvan
