Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13 : Member's Gallery - Page 10 | Fiesta Forums
Re: 1.8 zetec Bonus Dirtbox Sleeper - Santa Pod 24/10/10
Postby Rhinopower on Fri Oct 29, 2010 2:21 pm
Car really did get abused over sunday and monday, covering 300+ miles. For the downpipe to go was no suprise, the mild steel bit failed due to a combination of being sit, holding moisture because of the heat wrap, and being squashed by the jubilee clamp holding the wrap on. Just means we now have a better manifold on there, looks pretty handsome in the bay.
Rhinopower
Your car: Volvo FH330
Postby ~nomad~ on Fri Oct 29, 2010 5:28 pm
picture then? stupid arsehole
~nomad~
Your car: Breadvan
Re: 1.8 zetec Bonus Dirtbox Sleeper - 5/9 Nitrous oxide fitted
Postby andymac on Thu Nov 04, 2010 7:38 pm
Rhinopower :When the pulsoids are used progressively they are pulsed on and off, so it would be a case of building a circuit that increases the pulses as the TPS goes from 0-5volts (the pulsoids run at 12volts). I think i should do a little bit of research :)
Should be quite simple to achieve tbh, program in load sites and use a pwm output to vary pulses - you'd need to know the dwell times on the solenoid though as those times have to be factored into the pulse lengths. blah blah blah etc :)
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Rhinopower on Thu Nov 04, 2010 7:40 pm
andymac :
I bought a proper controller from wizards themselves in the end, does a brilliant job!
Rhinopower
Postby MotorcyclesFish on Thu Nov 04, 2010 7:42 pm
Rhinopower :
andymac :
Yeah but Andy could have made you one from an old matchbox with a spider in it and eight drinks straws :/
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby Rhinopower on Mon Nov 08, 2010 2:13 pm
Megasquirt is all fitted, just wants a little tweak so I can take it to torque of the devil on Wednesday for setting up on the rollers.
Power predictions??
Rhinopower
Postby Smo on Mon Nov 08, 2010 2:20 pm
146 without the nitrous oxide :)
Was any of that stuff I sent of any use to you?
Smo
Postby Rhinopower on Mon Nov 08, 2010 2:33 pm
Yes, very useful. It just has me running mega rich so will check the required fuel settings etc see if that helps
Rhinopower
Postby Smo on Mon Nov 08, 2010 2:40 pm
Yeah, mine was running 1.8 injectors with a slightly faulty narrowband, so it was probably running a little leaner on mine, but at the same time it was difficult to tell accurately just how rich or lean it was running. My idle fuelling was probably the most out because the lambda heater wasn't functioning properly when the exhaust temps were dropping (as far as I can gather!) so I was having to do it all on sound and feel!
Smo
Postby Rhinopower on Mon Nov 08, 2010 2:51 pm
130 or 105 spec injectors? Could be the missing link
Rhinopower
Postby hb69 on Mon Nov 08, 2010 4:05 pm
Rhinopower :130 or 105 spec injectors? Could be the missing link
Arent they the same?
hb69
Your car: Fiesta 1.1 LX
Postby Smo on Mon Nov 08, 2010 6:47 pm
They are indeed the same, the 2.0 ones are slightly higher flowing.
Smo
Postby Rhinopower on Mon Nov 08, 2010 11:11 pm
Turns out the mot is due so booked in for tomorrow and spent this evening prepping it, will get pictures up tomorrow once I have daylight :lol:
I've fitted the kenlow 10" front mounted fan, had to space the top of the radiator back slightly to make sure it all clears for now, although I do have a more permanent idea. I've also relocated all the wiring that runs along the bottom front of the radiator to the top to keep it all away from the heat of the st170 manifold.
Then mapping wednesday :)
Rhinopower
Postby ~nomad~ on Tue Nov 09, 2010 1:46 am
I look forward to seeing it tomorrow, always good to see some new substandard Brian bodges!
~nomad~
Your car: Breadvan
Postby ~nomad~ on Tue Nov 09, 2010 3:30 pm
Here are some random pictures I took today, of the st170 manifold, the nitrous install, the bay in general and the rad arrangement.
Enjoy them, enjoy them or I will sneak into your bedroom and piss in your hand while you sleep.
~nomad~
Your car: Breadvan
Re: 1.8 zetec Bonus Dirtbox Sleeper - Brian gobbles 'conquering
Postby dontpannic on Tue Nov 09, 2010 6:19 pm
I didn't enjoy them.
*awaits piss*
Postby ~S1~ on Tue Nov 09, 2010 8:02 pm
Looks factory mate.
~S1~
Hold On...
Hold On...
Postby Rhinopower on Tue Nov 09, 2010 8:05 pm
~S1~ :Looks factory mate.
Apart from the bright coloured nitrous bits yeah! Lol
Rhinopower
Postby ~S1~ on Tue Nov 09, 2010 8:09 pm
dontpannic :I didn't enjoy them.
*awaits piss*
Aaa.. It's coming out of me like a yella cable.
That was a bad time for you weren't it boy?
~S1~
Hold On...
Hold On...
Postby ~nomad~ on Tue Nov 09, 2010 8:54 pm
~nomad~
Your car: Breadvan
Postby ~S1~ on Tue Nov 09, 2010 8:59 pm
~nomad~ :
Pic no worky
~S1~
Hold On...
Hold On...
Re: 1.8 zetec Bonus Dirtbox Sleeper - Brian gobbles 'conquering device'
Postby ~nomad~ on Tue Nov 09, 2010 9:04 pm
strange, i can see it. but not in your quote
~nomad~
Your car: Breadvan
Postby ~S1~ on Tue Nov 09, 2010 9:07 pm
~nomad~ :strange, i can see it. but not in your quote
It's cos its shit.jpg, its been moderated by photobucket.
~S1~
Hold On...
Hold On...
Postby Excursion on Tue Nov 09, 2010 9:11 pm
:lol: :lol: :lol:
Postby ~nomad~ on Tue Nov 09, 2010 9:14 pm
~S1~ :
ffs! I have changed the name.
~nomad~
Your car: Breadvan
Postby ~S1~ on Tue Nov 09, 2010 10:08 pm
~nomad~ :ffs! I have changed the name.
magicthebrian.jpg :lol:
~S1~
Hold On...
Hold On...
Postby Ratspeed on Tue Nov 09, 2010 10:38 pm
dontpannic :*awaits piss*
dude, does jony know your cheating on him?! :lol:
Ratspeed
Postby knuckles on Tue Nov 09, 2010 11:10 pm
nice cable ties holding metal water hose :wink: :P
knuckles
Your car: Fiesta Rs turbo
Postby ~nomad~ on Wed Nov 10, 2010 12:07 am
speak to Brian. lol, shobky bay indeed, not my stle, not my problem. That said this car does get proper use and seems fairly reliable, so maybe something in it?
~nomad~
Your car: Breadvan
Postby knuckles on Wed Nov 10, 2010 12:16 am
front splash shields missing ?
i got 2 spare
knuckles
Postby ~nomad~ on Wed Nov 10, 2010 2:01 am
you mean arch liners? just never got refitted, have em somewhere lol
~nomad~
Your car: Breadvan
Postby rs220bhp on Wed Nov 10, 2010 9:24 pm
What power did this make or did you not do to totd
rs220bhp
Postby ~nomad~ on Wed Nov 10, 2010 9:25 pm
133bhp iirc
~nomad~
Your car: Breadvan
Postby Rhinopower on Wed Nov 10, 2010 9:42 pm
Yes 133, will scan graph in later. Runs very nice and feels a lot more than that. Chris Todd was very professional and unbiased despite being an omex dealer.
Rhinopower
Postby rs220bhp on Wed Nov 10, 2010 10:03 pm
Did you just have a power run or a set up aswell?
What do they charge if you dont mind me asking
rs220bhp
