Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13 : Member's Gallery - Page 17 | Fiesta Forums
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update21/4 - Engine fitted
Postby Rhinopower on Sun May 01, 2011 2:41 pm
Hi Mark!
Was missing the cambearing that holds the vvt. Unfortunately because the head is line-bored the part is unique to the head.
The valve spring compressor I purchased, and got a refund today now ive finished with it :)
Rhinopower
Your car: Volvo FH330
Postby Excursion on Sun May 01, 2011 2:53 pm
Rhinopower :Hi Mark!
Curses, Ryan. Curses!
Postby Rhinopower on Sun May 01, 2011 3:05 pm
With the steel stripped it should weigh in for £30 ish. It's left me with unfinished throttle bodies and no money to spend on mapping :(
Rhinopower
Postby jonyb4 on Sun May 01, 2011 4:04 pm
lol at the refund!
ive done similar things in my time :P
Postby ~nomad~ on Sun May 01, 2011 4:33 pm
lol, Brian you pikey. Still not sure I would strip and scrap the other head, those bits are almost certain to turn up if you do!
~nomad~
Your car: Breadvan
Postby Excursion on Sun May 01, 2011 5:31 pm
Rhinopower :With the steel stripped it should weigh in for £30 ish. It's left me with unfinished throttle bodies and no money to spend on mapping :(
Ahh :( I can't remember the specifics of the ST head, it's been a while since I had one apart - is it the bearing cap/oil seal end you're missing?
If yes, see if you can get hold of another one, have a couple of thou milled from the bottom so it's a tight fit, then get the lot line bored. Line boring is around £50 locally to me, and the milling can't be more than £20 - would it make financial sense at those prices?
Postby knuckles on Sun May 01, 2011 7:59 pm
lol :lol: @ the refund of the valve tool after getting use of it.
I once took back a chain oil filter removal tool. It was so s**t and kept slipping. All it did was dent my filter. Guy told me i couldnt have a refund and i said to him come remove the oil filter on my fiesta and i will keep the tool. He then backed down and refunded me :lol:
knuckles
Your car: Fiesta Rs turbo
Postby jonyb4 on Sun May 01, 2011 8:26 pm
knuckles :lol :lol: @ the refund of the valve tool after getting use of it.
haha damn id love for you to have done that to my old line manager, guy was a right c**t, would argue a goose isnt white!
them chain ones are crap, i use the steel belt one with a screw tightener, works perfectly
Postby ~nomad~ on Sun May 01, 2011 10:01 pm
i use the type you hammer thru the filter, also handy for undoing screws!
~nomad~
Your car: Breadvan
Postby Excursion on Sun May 01, 2011 10:06 pm
~nomad~ :i use the type you hammer thru the filter, also handy for undoing screws!
I use that occasionally, you can't beat the feeling of warm oil down your sleeve :D
Postby jonyb4 on Sun May 01, 2011 10:44 pm
haha my old mk4 hcs always ended up in me doing that, never wanted to come off :rolleyes:
Postby ~nomad~ on Sun May 01, 2011 11:23 pm
Excursion :
got it down to a fine art :lol:
~nomad~
Your car: Breadvan
Postby hb69 on Sun May 01, 2011 11:38 pm
I think thats the only way ive ever undone an oil filter. Tried the chain type once but it didnt go well
hb69
Your car: Fiesta 1.1 LX
Postby Rhinopower on Mon May 02, 2011 11:19 pm
Words of wisdom...
Make sure when you rebuild a head that all the valve springs are the right way up and you dont forget one before you torque the head down :x
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 2/5 - I hate cars
Postby Smo on Mon May 02, 2011 11:49 pm
Does this mean you need to re-purchase the valve spring compressor? :lol:
Smo
Postby Rhinopower on Mon May 02, 2011 11:58 pm
Well I would of had to, but i picked up my original from my uncle so it's all good! I just need to buy a third set of headbolts and fix it down again
Rhinopower
Postby Smo on Tue May 03, 2011 4:30 am
Shame you're not down this way because unless you're going genuine Ford I'm sure I could sort you out, but to post it would kinda defeat any saving!
You'd probably be fine re-using, but I'd probably question it and buy some new ones too :(
Smo
Postby Minstral on Tue May 03, 2011 3:20 pm
hb69 :
I tink thats the only way ive ever undone an oil filter. Tried the chain type once but it didnt go well
not the best
Minstral
Your car: *
Postby Excursion on Tue May 03, 2011 3:30 pm
Rhinopower :Words of wisdom...
Curses! Have you got an airline? Make an adapter from a spark plug, or use one from a compression testing gauge, then pressurise the cylinder. I use this method to replace valve springs and seals without removing the head.
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 3/5 - Looking good!
Postby Rhinopower on Tue May 03, 2011 6:43 pm
Feeling happier now :)
Rhinopower
Postby Smo on Tue May 03, 2011 6:58 pm
Lovely. Now make it work!
Smo
Postby Rhinopower on Tue May 03, 2011 7:02 pm
Plan is to chuck a standard focus 2.0 manifold on for now, i've also got to join two power steering pipes, i presume a bit of rubber pipe and two hose clamps wont be sufficient though :(
Rhinopower
Postby Max M4X WW on Tue May 03, 2011 7:09 pm
You fitting PAS?
Postby Rhinopower on Tue May 03, 2011 7:13 pm
Yes!
Rhinopower
Postby jonyb4 on Tue May 03, 2011 7:59 pm
Excursion :
CLEVER!
i thinkt he pas piping is far harder than rubber, its almost a plasic, dont think its lined though :oooh:
Postby Ratspeed on Tue May 03, 2011 8:06 pm
that looks at home in that bay, very nice.
Ratspeed
Postby Rhinopower on Wed May 04, 2011 12:04 am
Ratspeed :that looks at home in that bay, very nice.
Cheers. Mounting it as I have done also gives me the option to bolt straight in a focus rs lump if I decide to go forced induction later.
I'm going to have to fit bonnet raisers. The plastic cover that goes over the vvt solenoid is hitting the bonnet :(
Rhinopower
Postby jonyb4 on Wed May 04, 2011 2:16 am
thats not the worst thing though, but sleepers with this much power or more usually have a compromise of sorts :(
Postby andymac on Wed May 04, 2011 2:49 pm
My hero ! :lol: :lol:
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby ~nomad~ on Wed May 04, 2011 4:56 pm
Who wants to touch me.
~nomad~
Your car: Breadvan
Postby Excursion on Wed May 04, 2011 5:20 pm
Oh! My, how delightful.
Postby jonyb4 on Wed May 04, 2011 6:27 pm
Excursion :Oh! My, how delightful.
did ya touch his penis mark? :oooh:
Postby ~nomad~ on Wed May 04, 2011 6:45 pm
Thats a silly question. Me and Mark have a long history, sometimes violent, sometimes sad, but mostly loving.
~nomad~
Your car: Breadvan
Postby knuckles on Wed May 04, 2011 11:32 pm
Rhinopower :Feeling happier now :)
i like this :D
glad you got it all sorted now.
knuckles
Postby Rhinopower on Thu May 05, 2011 7:51 am
I've got soooo much to do today, its supposed to be at PE tomorrow for an hour on the rollers to be tweeked :o
Rhinopower
