Fiesta cosworth. a few years later... : Member's Gallery - Page 6 | Fiesta Forums
Re: Fiesta zetec turbo..... not anymore
Postby tompeteRS on Thu Apr 12, 2012 1:11 pm
Interesting way of doing things but ultimately I think it will drive a lot better doing it that way! :D
tompeteRS
Authorised Trader
Authorised Trader
Postby MircoJ on Thu Apr 12, 2012 1:31 pm
Awseome project mate. If only german "Tüv" would allow those things...
MircoJ
Your car: Ford Fiesta MK3
Postby luke_mk3_st on Sat Apr 14, 2012 12:36 pm
thanks guys. its going well. hopefully it will drive well. we shall see when its done. :)
luke_mk3_st
Postby Rs Adz on Sun Apr 15, 2012 8:05 pm
wow will be keeping an eye on this
Rs Adz
Your car: xr2i and mk1 fiesta
Postby dontpannic on Mon Apr 16, 2012 10:42 am
Holy s**t, thats awesome!
Postby mrorange2 on Tue Apr 17, 2012 4:33 pm
WOW thats wicked good luck with it!
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby Dave G fsi on Tue Apr 17, 2012 4:38 pm
What ana wesome project, will be watching this closely! :Q :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby MAD_Adamski on Sun Apr 22, 2012 3:17 pm
Thats more like it..... But i think you will regret rwd, a 4x4 is far better and not as expebsice as you think as the power in your car.will feel alot quicker due to the weight... Rwd will get no grip at all if you never knew dan he had a 4x4 blue one and he.struggled to get grip .... 350 hp in a fez will be like 450 in a cossie... But ive not been on here in a while keep it up tho wanna see this completed but 4wd :P
MAD_Adamski
Postby luke_mk3_st on Sat Apr 28, 2012 12:38 pm
Just a small update. Skyline has camber and Castor pillow ball top mounts are fitted. The shell is nearly welded up so will take pics soon.
And nope 2wd it is!!! And there is a difference proper 4wd box 25k. tko 2wd box capable of easy 800bhp 2500. Big difference :)
luke_mk3_st
Postby fiestarsturboblack on Sat Apr 28, 2012 11:19 pm
mate [ERRR] did u do with thm top mounts u made????
fiestarsturboblack
Your car: fiesta rs turbo
Postby MAD_Adamski on Sat Apr 28, 2012 11:42 pm
are the top mounts fitted correct? i'm sure i have seen them fitted slightly different!? not a pick just trying to help. Also yes you are kinda correct but if your trying to save money why do what your doing? :wink: there are 2-3 4wd potential gearboxes that will cope with the power 1 lude (which i have), 2 quaife just released a sequential and 3 oppleiger motorsport in italy also do a sequential too all these are under 10k the ffd and all that are very expensive and even they break with high power...
I am actually tempted to change to sequential myself but will be getting mine running perfect before i do that.
edit : check how the mounts are in wennys
MAD_Adamski
Postby luke_mk3_st on Fri May 04, 2012 7:50 pm
i tell you what if you want to donate the box shafts and diffs it will be 4wd ?
luke_mk3_st
Postby jonyb4 on Fri May 04, 2012 8:40 pm
thats a bit abrasive, MAD_Adamski has a habit of sounding forward, but he's only trying to help
Postby luke_mk3_st on Sun May 06, 2012 11:05 am
Ye I know mate I'm not having a go either I'm being serious. I'd love to do it 4wd but I cannot afford to so if someone wants to donate the parts then 4wd it will be
luke_mk3_st
Postby jonyb4 on Sun May 06, 2012 5:43 pm
if you asked me mate, id say sod it, go ahead with rwd and have some laughs, id go easy on the power around bends of tight and dangerous areas for obvious reasons, and in the meantime id save up for a 4wd set up, simple enough to convert at a later stage, just get this massive project squared away first, you have enough on your to do list imo
Postby luke_mk3_st on Sun May 06, 2012 8:27 pm
U just took my next answer out my mouth mate. I was going to say it doesn't matter anyway as its an easy conversion at a later date.
luke_mk3_st
Postby SEG1 on Mon May 07, 2012 9:02 am
4wd is the way forward but if you can't afford it now it's no biggie as you said its a simple conversion later on.
As for rwd, just put a LSD on my daily BMW and haven't performed a 3 point turn since! :D :lol:
Rwd is far funnier , but also has its disadvantages
SEG1
Postby jayrs on Mon May 07, 2012 10:50 am
SEG1 :4wd is the way forward but if you can't afford it now it's no biggie as you said its a simple conversion later on.
like seeing a gap in the traffic and nipping out quick :lol: dont do it on a wet road unless you plan a spin :lol:
Postby MAD_Adamski on Mon May 07, 2012 6:02 pm
jonyb4 :if you asked me mate, id say sod it, go ahead with rwd and have some laughs, id go easy on the power around bends of tight and dangerous areas for obvious reasons, and in the meantime id save up for a 4wd set up, simple enough to convert at a later stage, just get this massive project squared away first, you have enough on your to do list imo
that would be my choice if funds dont allow!! IMO any RWD car over 450hp is a waste of time unless its bone dry, theres just no grip... its ok if your into that but i value my life too much! :lol:
MAD_Adamski
Postby SEG1 on Mon May 07, 2012 9:42 pm
jayrs :
im lucking as i leave the traction control on in the wet, just means the power is cut every time you try to boot it. :lol:
SEG1
Postby jayrs on Mon May 07, 2012 10:02 pm
:lol: :lol:
Postby luke_mk3_st on Wed May 09, 2012 6:51 pm
tell a top fuel dragster that with 3000bhp rwd all the way lol. and iv never had that problem driving a m6.. m5.... m3.. v12 bi turbo mercs skyline r33 all rwd get the power down and dont just spin around! just because you have big power doesnt mean u 1 have to use it all the time. and 2 doesnt mean u apply it all when pulling into a gap etc. iv driven all of the above cars "not the dragster" with tcs off and have been sidways but never around in circles.. unless intended or going fudgekin mental!! my superbike doesnt just spin unless i want it to either. obviously 4wd has more traction. but driving abality comes into it aswell... why do soooo many people convert cossis to rwd ? and why was the best ever cossi "rs500" rwd and won everything ? just out of interest ? :-?
luke_mk3_st
Postby Excursion on Wed May 09, 2012 7:37 pm
I'm sure it will be a good laugh mate :D
Postby luke_mk3_st on Wed May 09, 2012 8:33 pm
Excursion :I'm sure it will be a good laugh mate :D
dam right mate :D
luke_mk3_st
Postby fiestarsturboblack on Sat May 12, 2012 10:27 pm
what hks mounts r thy mate? an how much am thy????
fiestarsturboblack
Postby luke_mk3_st on Sun May 13, 2012 8:06 am
fiestarsturboblack :what hks mounts r thy mate? an how much am thy????
I ordered them a long time ago now and can't fully remember if they are skyline or evo 8 mounts!! I think there evo ones tho. Not sure who I bought them off either think I found a retailer off the hks site. But they was very expensive at £550!!
luke_mk3_st
Postby luke_mk3_st on Wed Jun 13, 2012 10:58 pm
Just a quick update. The shell is fully welded now, and the bottom is done!! All prepped seam sealed stonechipped and painted! Got a few pictures off my phone. It's back on the floor now and the steering is also all hooked up. Going well! Next will be get the inside sealed and painted and then the bodywork.
luke_mk3_st
Re: Fiesta zetec turbo..... not anymore update
Postby rsturbonutter on Thu Jun 14, 2012 9:26 am
Fiarplay to you mate steaming along. Did you inlist any problems getting to this stage
rsturbonutter
Your car: Fiesta RS turbo
Postby Excursion on Thu Jun 14, 2012 9:52 am
Decent progress!
Postby fiestarsturboblack on Thu Jun 14, 2012 9:10 pm
looks good mate. hope to see more soon :)
fiestarsturboblack
Postby jonyb4 on Fri Jun 15, 2012 7:02 pm
i think the main reason most big power cossies are converted to RWD is the T5 box is much stronger than the 4wd set up in the sierra and escort, and its far cheaper than a strong 4wd set up also
loving the work, weird seeing that floor pan under a fiesta :P
Postby curly on Fri Jun 15, 2012 8:04 pm
first dibs on when you come to sell it ;) i always ggot told the sierra floor poan wouldnt fit, but obviously it does lol
[HOONIGAN]
main priority!!!
A-B-U-S-E-!-!
curly
Postby Michael! on Tue Jul 03, 2012 11:23 am
i want this
ft-com-members-map-vt190192/
Michael!
Postby luke_mk3_st on Fri Aug 31, 2012 11:27 pm
Ok not a huge update but enjoy
Got some work done to the engine block bored out .5 honed and all cleaned up. Got 16 guides in the head all valves re seated etc. spec is
Newman double valve springs
Newman bd14 cams
Vernier pulleys
Forged pistons
Forged rods
Heavy duty bearings
Arp head stud kit
Arp main cap stud kit
Arp flywheel bolts
Arp con rod bolts
Full cometic gasket set and oil seals
High pressure oil pump
Kent cambelt and tensioner
7.1 compression ratio gt35 dual roller turbo still need to order a manifold and some other bits also the gearbox will be ordered soon :). Here are some pictures see what you think
Ps rocker cover isn't done
Engine mock fitted into the bay to make sure everything fits! Will be removed for paint shortly
luke_mk3_st
Re: Fiesta cosworth update engine.
Postby - Danny Boy - on Fri Aug 31, 2012 11:58 pm
Looking good! :D
- Danny Boy -
Your car: Fiesta Si 2.0
