Fiesta Ghia RS1800 Sleeper : Member's Gallery - Page 3 | Fiesta Forums
Re: Fiesta Mk3.5 Ghia L reg
Postby HCS PIMP on Mon Nov 14, 2011 11:50 pm
lol I know I'm good
HCS PIMP
Postby jonyb4 on Wed Nov 16, 2011 12:08 am
hope this goes well for you, not like previous cars :(
anyone know what a standard yet 2.1 bored zetec will produce?
Michael! :
jonyb4 :35mm ;)
Says 25 in his post near the top smart guy :p :)
was simply saying what my perfect height would be, nothing to say what was said by you or pimp :)
Postby HCS PIMP on Wed Nov 16, 2011 8:36 pm
well halfords cannot offically organise a piss up in a bargain booze
springs have arrived 35mm kit LOL
not fused gonna fit the rear in about 10 mins
HCS PIMP
Postby Tweek on Wed Nov 16, 2011 8:38 pm
Rhinopower :i was watching that engine on ebay, went for silly cheap money!
me too :lol:
Your car: VW Golf GTD
Postby HCS PIMP on Fri Nov 18, 2011 11:19 pm
well cars lowered now, collected the engine, been to machine mart started making a work bench / engine assembly area :D
made a massive pile of parts to scrap I have
Rear turret carpets, parcel shelf, fuel tank and door seals all goign for free with the 2 old bumpers if anyone is wanting
give me a bell 07969408299
also 260mm mondeo calipers modified to fit a fiesta hub and going to be selling the 1.6 block, and head with cams if anyones wanting
only want £20
HCS PIMP
Postby jonyb4 on Sat Nov 19, 2011 12:32 am
whats the door seals to fit? 3 or 5door?
Postby HCS PIMP on Sat Nov 19, 2011 9:14 am
5 door and im not posting
HCS PIMP
Postby HCS PIMP on Sat Nov 19, 2011 7:03 pm
HCS PIMP
Postby jonyb4 on Sun Nov 20, 2011 12:27 am
nice welding :)
does the car fit in that garage? looks to small with the bench
its in need of some skirts of some sort, the bumpers sit lower and its uneven ya know?
escort mk5 RS2000 skirts would suit it well :)
Postby AW3K on Sun Nov 20, 2011 12:33 am
the bumpers on mine sit like that johny, cant really do much about it
AW3K
Postby jonyb4 on Sun Nov 20, 2011 12:36 am
well thats my point, they hug the floor, needs skirts to equalise it L:)
something i never got round to doing on my mk4 :rolleyes:
Postby Ratspeed on Sun Nov 20, 2011 9:14 am
jonyb4 :nice welding :)
:oooh: :lol:
But on the skirts topic, it deffo needs something.
Ratspeed
Postby Michael! on Sun Nov 20, 2011 6:34 pm
rs skirts and arches otherwise it looks s**t.
ft-com-members-map-vt190192/
Michael!
Postby HCS PIMP on Sun Nov 20, 2011 6:45 pm
well welding has never been my strong point I didn't prep for the welds and did it in like 1 hour so im not fused i built the bench purley to do the engine then ill be storing it down the side of the filing cabinate
Still got a fuel tank going cheap looks brand new even got a fresh coat of tetra shults on the underside and the 1.6 head and bottom end if anyones interested
going to go and take the crank off clean the bottom end and then rebuild with the new ARPs and some lube :D
Then thinking sump and tape off the water galleries so I can store it off the bench ready for the Head
HCS PIMP
Postby HCS PIMP on Tue Nov 22, 2011 1:48 am
HCS PIMP
Postby HCS PIMP on Tue Nov 22, 2011 10:14 pm
HCS PIMP
Postby Excursion on Wed Nov 23, 2011 1:11 pm
Just some advice but make sure those valve guides are reamed before use, and some of the seats look a bit marginal too.
Postby jonyb4 on Wed Nov 23, 2011 9:06 pm
those ports aint looking very smooth, give them a polish if your going through the effort to try and enlarge them
Postby HCS PIMP on Wed Nov 23, 2011 10:07 pm
i am going do i did write a long piece of text explaining the pictures and windows crashed so i just added the pictures it only a zorst port but i do plan on goign over with a flap wheel to smooth it out thats just the rough work will do all the ports rougly like this then go over with some 80 grit then 150 grit
HCS PIMP
Postby HCS PIMP on Fri Nov 25, 2011 1:04 am
HCS PIMP
Postby Ratspeed on Fri Nov 25, 2011 6:59 pm
Not sure if its the pics or not, but them ports look fudgekin butchered! :-?
Ratspeed
Postby HCS PIMP on Fri Nov 25, 2011 7:11 pm
got my new thermostat seal today and got a price list for some part for the engine rebuild also got a price on a sport cat :D
HCS PIMP
Postby jonyb4 on Sat Nov 26, 2011 2:45 am
hard to tell or not, but how smooth are the ports now? id go down as far as 300 grit to get them baby bum smooth :D
and just a observation, take it easy around the valve seats, your starting to score them, you could ruin your seal if your not careful
at this time id stop using power tools and do it by hand (if i were ever to use a power tool to do this)
keep it up though :)
Postby HCS PIMP on Sat Nov 26, 2011 8:10 pm
goign to regrind them all and the valve guides so not that massive a deal and will be skimming the head
also got quoted £250 for a sport cat with pipe work :D
HCS PIMP
Postby jonyb4 on Sat Nov 26, 2011 9:51 pm
ive seen sport cats go for £300 from prospeed in cardiff so quite a good price
but they weld them in for that price
surely regrinding the seats will need oversized valves?
all this is best left to the professionals imo
Postby HCS PIMP on Sat Nov 26, 2011 10:35 pm
but i am a mechanic and have rebuilt engines before
you can regrimnd the valve seats at home with valve grinding paste the valves sat true of the seat by 4mm anywho so regrind won't damage anything
I won't be skimming the head myself as i dont have the tool used to do a skim also for £40 I woudl rather they did it
I would never do proper machining work but porting a cylinder head is failry straight forward
also having the ports too smooth can actually reduce performance as shown In David Vizards engine book
Im not going for Major BHP but know how much the area around the valve guide reduces air flow
I won't the car to be comfortable to drive around town hence standard cams and more than likely exhuast manifold as once the EGr is blanked flows more than enough without having to faf with either a mild steel ashley 4-2-1 or a stainless escort item that requires major effort
HCS PIMP
Postby HCS PIMP on Tue Dec 06, 2011 11:34 pm
2-1-zetec-bottom-end-brand-new-vt192561/
testing the water as im skint
HCS PIMP
Postby jonyb4 on Wed Dec 07, 2011 12:18 am
that lasted long, why did you buy it if your skint now? its only been about 2-4weeks since you bought it, did you not anticipate you'd be a bit skint if you got it?
Postby HCS PIMP on Wed Dec 07, 2011 12:52 am
my work owe me £800 that should have come this month just gone it didn't urgo Im skint
HCS PIMP
Postby jonyb4 on Wed Dec 07, 2011 11:09 pm
:x
Postby HCS PIMP on Thu Dec 08, 2011 12:47 am
mini update pic of fez at work and some inlet work i just did
HCS PIMP
Postby HCS PIMP on Fri Dec 09, 2011 9:03 pm
did one inlet today im happy with the finish
HCS PIMP
Postby jonyb4 on Fri Dec 09, 2011 9:43 pm
getting better, thought you were selling up why you still doing it?
stupid image shack
Postby HCS PIMP on Sat Dec 10, 2011 8:43 pm
cause if i get enough pay this month im keeping the engine lol
plus if i sell the block ill still have the head
i did the exhuast rough because the gasses passing through are being forced anyway and will be more back pressure from the standard manifold and cat
inlets were always going to be a better finish
HCS PIMP
Postby HCS PIMP on Mon Dec 26, 2011 10:44 pm
well im keeping the engine not done any major work as ive been working my arse off at the min
and ive been really unwell plan is finish the head off this week just need to get tomorrow at work finished then a rare day off :D
my department was heaving today took over 30k so was a gr8 day only had 4 hours sleep
i really miss working with cars i just need to get my act together and get an apprentiship
shame the puma speed job never happened last year all due to a few typos
meh stuff happens main thing i still love cars
HCS PIMP
