Fiesta mk2 - ready for ford fair !
- Smo
Re: Fiesta mk2 - 2.0 Zetec Its In !
top work guys!!
- Ratspeed
I like helping clark, he does me lots of favours!
- Rhinopower
- Your car: Volvo FH330
Rhinopower :I like helping clark, he does me lots of favours!
shhhhhh !!!
- knuckles
- Your car: Fiesta Rs turbo
knuckles :Rhinopower :I like helping clark, he does me lots of favours!
shhhhhh !!!
Ahh I wondered how this arrangement worked!
Well done gents, your doing a grand job
.......and I think my 3 hours work on the entire build was key to whole project
- Ghost
6mm feed pipe removed from the car - easy peasy !
Trying out the new pipe bender on the 8mm copper pipe i purchased a while back.
This is the outcome... ruined the pipe. Not happy at all.
- knuckles
do as i said on msn mate, should be alright then
Fill pipe with water, freeze it, then bend it
- Rhinopower
how do i freeze a 2 meter lenght of copper pipe ?
Roll it up again
so fill it ,cap it , freeze it , bend it
Roll it up again
- knuckles
Yeah freeze it when it's rolled up!
- Rhinopower
dont waste ya time freezing it.
do it as i said on MSN, or get ya self a bending spring for this size pipe
your a good bender!
the plumbers i know use an extra bit of metal between the pipe and bender to stop that happening.usually comes with the pipe bender and there are different sizes ,but we are talking about 14mm copper pipe to 22mm .
- SEG1
im sure you gotta inch your way along the bend while bending it? so your not focusing the pressure on one particular spot?
might be wrong though
Those benders will kink the pipe like that when you try to bend a big angle. We used to use them at work but now use a spring as you get a much better curve. I made my fuel lines out of the same copper but got it free from work
- rs220bhp
done a bit more today - im waiting for more copper pipe to arrive so i can try my luck again with the pipe bender. Got the hang of it now and realised you need to bend it slowly to prevent it kinking.
Brand new Fiesta mk2 cvh radiator specially made
Trial fitting the brand new xr2 cvh radiator
The next problem is the radiator bottom outlet faces the Head light. Where on the fiesta mk3 zetec rad the bottom outlet faces the water pump.
i cut up a old bottom fiesta rs turbo bottom rad hose and created a 90 degree bend
Then i placed the fiesta zetec bottom rad hose on. I now need a hose joiner to finish it off. I am eventually going to get a hose made up by roose motorsport using this as a mock up.
Here is a picture of the fuse box ryan added to my current setup. this operates the fuel pump and basically does the job of priming it when you switch on ignition. It uses all original ford wiring.
Neatly connects upto the original fuse box
- knuckles
Re: Fiesta mk2 - zetec plumbing
I love Clarks bum
- ~nomad~
- Your car: Breadvan
nice progress mossy
Looking good! Whens it gonna be running?
- Ratspeed
hopfully before the 1st of may
should have some bits friday thats been sent over
Ratspeed :Looking good! Whens it gonna be running?
fuel lines are holding me up atm
im having trouble bending the copper fuel line to match the 6mm steel one from the car. Keeps kinking.
Jay sending over a box of goodies that should be here friday
- knuckles
Escort mk5 zetec top rad hose cut either end and fitted. New fan switch fitted
Modified fiesta mk3 zetec bottom hose. 35mm alloy hose joiner installed between and clamped up.
Special delivery from roose motorsport this afternoon.
90 degree bend 16mm flurolined silicone hose to go from the tank to the pump. the straight bit i installed last week has kinked in middle restricting flow to pump. so once i cut this one down a tad it will be perfect fit
Fancy new fuel filter connectors from ford, these basically connect the rubber flexy line from the metal feed pipe to the filter. Then from Filter to the Feed pipe to the Fuel rail.
Not long to go now !
- knuckles
coming on nice mate, you best let me have a go in it when you come over.
you should have them bits tomorrow
jayrs :coming on nice mate, you best let me have a go in it when you come over.
of course you can have a go
just dont put it in a ditch
- knuckles
lol, more chance of some old bid taking you out
Good work clark.
Where did you get your fuel tank from? Mine is rubbish and after castle combe im looking for a new one.
Gareth.
Gareth.
- black2
black2 :Good work clark.
Gareth.
pm sent dude
- knuckles
- GavStyli
- Your car: Fiesta Turbo
ah thats a nice pic for the pikey thread
New parts from jay arrived friday morning
zetec air intake , zetec aitbox complete
mk2 xr2 cvh fan and housing
Mk2 mondeo servo/master cylinder & speed sensor
Top rad hose and switch fitted
fuel filter located and plumbed in
fuel lines all plumbed in now. 8mm return hose was made out of steel pipe in the end. The copper pipe was too soft and was kinking on the 90 degree bends.
Pump to tank has a flurolined roose motorsport hose.
Had it started briefly to make sure it all works. Fuel pump is very loud !
Exhaust is being done tomorrow
- knuckles
If your going to drive it back tomorrow make sure that crossover pipe is secure, if it falls off on a zetec it just wont run, and obviously you need the maf connected.
Looks very nice tho!
- Rhinopower
sweet as mate, nice to see its happened in a short time, and there you was flaming over it when i told you not to worry
i'll get some gas for the welder and some metal sorted out as your bound to want to me knock something up for it when ya come over
jayrs :i'll get some gas for the welder and some metal sorted out as your bound to want to me knock something up for it when ya come over
funny you say that
my dipstick need bolting to the head since the standard exhaust manifold is not being used
- knuckles
