Fiesta mk2 - ready for ford fair !
Re: Fiesta mk2 - 2.0 Blacktop Fitted
Postby Tweek on Sat Apr 21, 2012 10:30 pm
So FITP is a possibility then? :wink:
Your car: VW Golf GTD
Postby knuckles on Sat Apr 21, 2012 11:25 pm
Tweek :So FITP is a possibility then? :wink:
fingers crossed :D
knuckles
Your car: Fiesta Rs turbo
Postby jonyb4 on Sat Apr 21, 2012 11:30 pm
top work clark, very neat and tidy
does hold its revs though, a blast around the block should help it i imagine :aviator:
Postby jayrs on Sat Apr 21, 2012 11:49 pm
nice mate :)
that video the first time you fired it up, or did you haver it running before? cos that temp gauge is a bit high for such short time running
Postby - Danny Boy - on Sun Apr 22, 2012 9:44 am
Looks good :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby knuckles on Sun Apr 22, 2012 10:04 am
jayrs :nice mate :)
i had it running 20 mins previous to the vid to bleed coolant through.
new thermostat opened and fan came on before vid as well.
just need to connect up clutch cable to gearbox and tighten up hub nuts then i can give it a test drive
knuckles
Postby dontpannic on Sun Apr 22, 2012 10:15 am
Well done Clark!
Postby jayrs on Sun Apr 22, 2012 6:51 pm
ah thats ok then :lol:
Postby knuckles on Sun Apr 22, 2012 7:03 pm
back in the garage for now.
its not taxed or insured atm and didnt want to risk running into mr plod. End of month it will come back out to play :D
knuckles
Postby Rhinopower on Sun Apr 22, 2012 7:04 pm
You be taking it to Santa pod this year?
Rhinopower
Your car: Volvo FH330
Postby knuckles on Sun Apr 22, 2012 7:23 pm
Rhinopower :You be taking it to Santa pod this year?
may do once i know its not going to break again :lol:
ive been saying to gav it would fun to see it go up against his turbo
knuckles
Postby Rhinopower on Sun Apr 22, 2012 7:25 pm
it will be nice to actually beat Gav this year!
Rhinopower
Re: Fiesta mk2 - the sleeper is back
Postby knuckles on Fri May 04, 2012 10:54 pm
Mk2 is taxed & Insured :D
I completed a 5 mile road test today with the new engine. It does seem to idle quite high @ 1500 rpm. When i cruise along at 40mph in 5th gear i can take my foot off the accelerator pedal and the car will virtually drive its self. The throttle cable is fully adjusted toward the throttle body & the throttle body itself is fully closed so there is no way i can adjust this idle.
On the flip side. This blacktop engine doesnt stall when i come to a stop at traffic lights. The silvertop i removed always used to want to stall when the revs dropped below 1000rpm. So im glad about that.
The car is booked into top gear exhaust center in st albans next wednesday. Im praying they can squeeze the st170 manifold on this so i can get a bit more poke out of it.
knuckles
Re: Fiesta mk2 - The Sleeper is back
Postby jonyb4 on Sat May 05, 2012 12:02 am
hmm sounds like a sensor then, hate sensors on a zetec, theres usually one that has to throw a tantrum :rolleyes:
glad shes going well though, good luck with the ST 4 branch
Postby - Danny Boy - on Sat May 05, 2012 9:47 am
Glad to hear its back on the road. Shame about the idle though, but as Jony said, could be a sensor.
Hope you get it sorted, and will be looking forward to seeing if you can get the ST170 manifold on there :D
- Danny Boy -
Postby MK2 Jamie on Sat May 05, 2012 10:48 am
Good to see its running :aviator: I'm sure top gear will be able to sort the maniold out. They did some work on my old RS1800 as well as my friends mk2 and XR3i. They're a friendly bunch of guys in there, which makes a change from most garages.
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby jayrs on Sat May 05, 2012 11:29 am
nice mate, a good turn around time too.
although, i think you should still be cautious mate.
after all, its eatend 2 silver top engines in a short space of time, i know both may of had there own propblems before they went in the mk2, but the fact is, your still using the same inlet and fuel set up now, as well as ecu (unless your MS one is ready and fitted??) as you have done on the last 2 engines...... as ive said in the past, if theres a fault with something there that caused, or contributed to the past engines failing, then you dont want it happening a 3rd time.
so dont go booting it about untill you have had it checked and set up right, other wise you could end up wanting a new engine again...
Postby Ratspeed on Sat May 05, 2012 8:02 pm
Consider his bonfire, pissed on! :lol:
Ratspeed
Postby jayrs on Sat May 05, 2012 10:42 pm
:lol: :lol: , na its not like, just expessing my concern thats all, clark knows what im getting at as ive spoke to him on the phone and msn about it before :)
Postby knuckles on Sat May 05, 2012 11:26 pm
Ratspeed :Consider his bonfire, pissed on! :lol:
:lol: :lol:
knuckles
Postby jonyb4 on Sun May 06, 2012 12:46 am
lol was gonna say kick him in the beans
Postby knuckles on Sun May 06, 2012 4:38 pm
Ive finally got to the bottom of my idle issues ! :D
The inlet manifold had the incorrect gasket fitted. When i bought the HO inlet the 2.0 throttle body came modified and already fitted so i never took it apart. After getting some good advice i found the vacuum leak by spraying brake cleaner around the inlet which changed the note of the idle. The gasket i took off is a metal tin gasket from a 2.0 mondeo inlet manifold. The HO inlet uses a paper gasket. Fitted that today and it cured the high idle.
Car now purrs just above 1000rpm
Happy days :bonkers:
knuckles
Postby jonyb4 on Sun May 06, 2012 4:40 pm
thats good, still thats a little high to call idle
Postby Rhinopower on Sun May 06, 2012 4:42 pm
jonyb4 :thats good, still thats a little high to call idle
Idle is the speed the engine sits at whilst not under load. Therefore, it could be anything!
Rhinopower
Postby knuckles on Sun May 06, 2012 5:12 pm
Well bear in mind the engine is wired up to a very old mk2 rev counter which gets its feed from the alternator wiring. So it could be even lower 1000 in reality.
Either way its still a breakthru compared to the 1500 it was static at .
knuckles
Postby knuckles on Mon May 07, 2012 11:48 pm
Gave it a run to the petrol station today.
For the 1st time since ive done the 2.0 conversion it finally runs perfectly.
Finding that vac leak must of been playing havoc with the 2 previous engines as well.
lastly id would like to point out that having a brand new engine makes alot of difference power wise. I have noticed a massive difference :P
knuckles
Postby jonyb4 on Tue May 08, 2012 8:20 am
:D glad for you mate
Postby knuckles on Tue May 08, 2012 9:21 pm
Another new purchase today - went down burton power and got myself matching racetech guages.
Oil temp , oil pressure & volt meter
Before ......
After :D
I went for the black guages to match the mk2 instruments. Both the oil guages are electric so will require senders to be plumbed into the engine. I didnt want to run oil pipes inside the car incase i was to spring a leak. Oil temp is going to be plumbed in using a sump plug adaptor. Oil pressure is going to have a T-piece from the block for the sender & oil pressure switch to go into.
Radio is being relocated to the glove box for now.
knuckles
Postby Ratspeed on Tue May 08, 2012 9:29 pm
Them guages look factory mate. Proper love this car :)
Ratspeed
Postby knuckles on Tue May 08, 2012 9:30 pm
Ratspeed :Them guages look factory mate. Proper love this car :)
cheers fella :D
knuckles
Postby jonyb4 on Tue May 08, 2012 9:34 pm
looks great, quite elegant, think id have rather lose the heater vents myself, can still receive air through the windscreen vents :P
Postby knuckles on Tue May 08, 2012 9:43 pm
jonyb4 :think id have rather lose the heater vents myself
I dont want a nice new cd player on show in the car, so relocating it solves this issue and creates the space for the guages :wink:
knuckles
Postby jonyb4 on Tue May 08, 2012 9:48 pm
that makes sense :)
Postby Ratspeed on Tue May 08, 2012 9:57 pm
When i had them in place of the vents the guages got too hot to touch if had the heater on full!! :lol:
Ratspeed
Postby knuckles on Tue May 08, 2012 10:15 pm
Ratspeed :When i had them in place of the vents the guages got too hot to touch if had the heater on full!! :lol:
Exactly why i didnt want to mess with the vents. Guages would look odd down there
Plus they are level with the rest of the instruments which means i dont need to take my eyes off the road by looking down to see them. :bonkers:
knuckles
