Fiesta MK3 help
3 posts • Page 1 of 1
Fiesta MK3 help
Hey all first post on the forums ever so first if all sorry for any mistakes.
Basically I have just got me a ford fiesta Mk3 1.1 1ltr 1996 and I have the old disc shaped air filter. I was hoping to fit a cone filter to it but I just don't see how to do it. Is it possible? If so any kits or size cones you would recommend me buying.
Many Thinks
Ryan
Many Thinks
Ryan
- ryansturgess1995
- Your car: Ford Fiesta Mk3 1996 1.1ltr
Re: Fiesta MK3 help
Hi welcome to the forum
As far as I know there isn't a way of fitting a cone filter to these engines... If your just after more noise I would drill it or remove the air filter itself but obviously these will not be the safest option!I suppose you could try to retrofit a filter onto there but from memory with the airbox removed there isn't much room between the bonnet and the inlet
- russ-RST
- Your car: fiesta rs turbo
Re: Fiesta MK3 help
Thanks for your help also my car has the back speakers area but there are no speakers at all. Not even a bracket or wires that indicate they were there in the first place. What can I do as I have done research and know speakers can go here?
- ryansturgess1995
