fiesta mk3 wiring issue help
Postby fezta on Sun Jun 08, 2014 12:01 pm
hi im hoping someone can help me I've a 1995 fiesta mk3 and im having some wiring nightmares I went out this morning to have a look at the wiring under the dash and its a nightmare wires all over the place now the car has a 1.3 cfi engine same as this picture apart from mines doesn't have the silver pipes over exhaust heat shield
but I have what looks like a different ecu like this but there is no where for it to bolt up properly I don't have the same fixing as the picture below in the engine bay all I have is a round hole there which a grommet sits into with holes for wiring to travel through
my problem is where does this bolt up I've looked up underneath behind the glove box and theres only a round hole which the wiring comes though,, mine isn't like this at all
has someone changed around the wiring this meaning the ecu doesn't fit as it should as the car has had electric windows and central locking fitted oem ford parts which look to be from a fiesta xr2i
fezta
Your car: fiesta
