Fiesta mk5 fuel pump problems
Postby ianFRST on Fri Mar 21, 2014 9:27 pm
hi chaps
long time no post.
i find myself with a little mk5 fiesta. most of the time it start and drives lovely
but a few times, ive had it where you come to start it, switch ignition on, and you dont hear the fuel pump prime like it should.
when its doing that, you can hear a "knock" from the rear, but no priming? ive been told (its a 2001) that its an early pump, like the mk3 rs turbo
where shall i start in trying to find the cause? new fuel pump?
99% sure its not the immobiliser, the little red light stays on when cranking then goes out
ianFRST
Re: Fiesta mk5 fuel pump problems
Postby ZetecsTurbo on Sun Mar 23, 2014 10:27 am
Probably the pump but could be the relay, try asking on zsoc if u get no luck on here theres not many zs owners on this forum so hard to get help with things like that
ZetecsTurbo
Your car: Mk5 Zetec s
