Fiesta rear beams and adjustments : Tuning / Handling / Braking | Fiesta Forums
Postby luca on Wed Feb 25, 2009 8:08 pm
Has anyone ever adjusted rear camber on there beams.
luca
Re: Fiesta rear beams and adjustments
Postby FRSJON on Wed Feb 25, 2009 8:11 pm
is it possible??.. :-? ..not 100% on this but im sure i read that jimmy added some camber to my rear beam when it was shortened... :-?
FRSJON
Postby luca on Wed Feb 25, 2009 8:24 pm
Anythings possible... :lol:
Just wondered if what how when someone has done this already before I look into it further
luca
Postby FRSJON on Wed Feb 25, 2009 8:33 pm
well with your wallet i suppose it is.... :P .. sure theres a post about for a group buy on adjustable beams??
FRSJON
Postby luca on Wed Feb 25, 2009 8:36 pm
:lol: :lol: :lol: :lol:
I was thinking of a big hammer :bonkers:
luca
Postby FRSJON on Wed Feb 25, 2009 8:55 pm
not sure on the strength of it but could you not shim the rear hubs ??
FRSJON
Postby luca on Wed Feb 25, 2009 8:59 pm
FRSJON :not sure on the strength of it but could you not shim the rear hubs ??
This is what im thinking at the mo mate with a selection of plates machined down to offer the desired camber.
-.5degree
-1degree
-1.5 degree shim
luca
Postby FRSJON on Wed Feb 25, 2009 9:00 pm
sounds good to me.. :Q
FRSJON
Postby ~S1~ on Wed Feb 25, 2009 9:06 pm
luca :
-.5degree
-1degree
-1.5 degree shim
Sierra's suffer from excessive camber when lowered at the rear. One of the fixes is offset shims to counteract the effect. No reason why the same idea cant be applied to the Fiesta beam.
~S1~
Hold On...
Hold On...
Postby 0010 on Wed Feb 25, 2009 9:37 pm
0010
Your car: BMW E30 318is
Postby luca on Wed Feb 25, 2009 9:48 pm
0010 :http://www.espdesign.co.uk/p285800/Rear_Alignment_Shims_for_Ford_Fiesta_Mk3/product_info.html
Eibach make shims.
You sir are just showing off! :lol:
Cheers for that link looks interesting -
Will order a set tomorrow and see what they look like :)
luca
Postby Turboboy67 on Wed Feb 25, 2009 9:50 pm
Eibach make shims.
Good find fella :aviator:
Something else to add to my list now :rolleyes: :lol: :lol:
Turboboy67
Your car: 911GT3 RS
Postby Ruishy1 on Wed Feb 25, 2009 9:56 pm
did captain tightpants not make up a rear beam from a mondeo that was adjustable, and he said its not too difficult :D
Ruishy1
Postby ~S1~ on Wed Feb 25, 2009 10:11 pm
IMHO they look s**t! TBH I reckon you're better off to get an alignment check and then get some machined up locally to your required spec.
Are ESP still going, I heard they'd fallen victim to the credit crunch?
~S1~
Hold On...
Hold On...
Postby luca on Wed Feb 25, 2009 10:25 pm
S1 :IMHO they look s**t! TBH I reckon you're better off to get an alignment check and then get some machined up locally to your required spec.
This is what i am looking at doing but for £16 if still available I can see how these work /adjust.
Bit strange being plastic... As the heat generated on track is far greater than road.
I would prefer something that the bolts slot through and the bolts them selves need to have shims too i would imagine due to the angle.
luca
Postby ~S1~ on Wed Feb 25, 2009 11:36 pm
luca :I would prefer something that the bolts slot through and the bolts them selves need to have shims too i would imagine due to the angle.
Use a thick washer and give it a bit of work with a soft-disc grinder or a linisher.
~S1~
Hold On...
Hold On...
Postby luca on Wed Feb 25, 2009 11:43 pm
S1 :
Ive cracked the code guys!
:aviator:
Will show my findings once i have had some fabricated and tested them.
luca
Postby - Danny Boy - on Thu Feb 26, 2009 8:34 pm
I was going to say use washers... but someone beat me too it :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby freak power on Thu Feb 26, 2009 8:45 pm
Angled spacers
freak power
Postby Silversleeper on Sun Mar 01, 2009 10:41 pm
I have an adjustable rose jointed rear beam from Zoo Motorsport. Havent fitted it yet though and I've had it over 2years now haha.
Should be fitting it soon as just stole the beam off the car it's intended for so i could fit it to my road car project.
Silversleeper
Postby ~S1~ on Mon Mar 02, 2009 1:43 am
Silversleeper :I have an adjustable rose jointed rear beam from Zoo Motorsport. Havent fitted it yet though and I've had it over 2years now haha.
Unless they did a different one the Zoo beams adjustment is only to get the beam aligned correctly, it wont adjust the camber. I looked at buying one but was very wary of their welding abilities so bought the hardware and fitted it to my own beam.
~S1~
Hold On...
Hold On...
Postby AndyKam on Fri Mar 06, 2009 1:15 am
I've got an adjustable Zoo beam on mine. Been of for 4 years now with no problems. As Paul said its used just to get the rear wheels aligned properly with the fronts. Works well for its purpose.
AndyKam
AndyKam
Your car: 1991 Red FRST
