fiesta rs turbo - coilpack and tps
Postby rob pace on Mon Feb 10, 2014 5:41 pm
want to try these as my fiesta rs turbo is not running right!
rob pace
Re: fiesta rs turbo - coilpack and tps
Postby rs220bhp on Mon Feb 10, 2014 8:49 pm
Got both £35 delivered.
rs220bhp
Postby rsturbonutter on Fri Feb 14, 2014 6:25 pm
Do you leave it unused for long periods rob. Mine used to do it if I left the battery off or no charge it takes the ecu a while to learn all the values/readings. I found leaving it tickiver for a while then a half hour drive used to sort it until I left the battery run flat again
rsturbonutter
Your car: Fiesta RS turbo
Postby rob pace on Fri Feb 14, 2014 8:56 pm
rsturbonutter :Do you leave it unused for long periods rob. Mine used to do it if I left the battery off or no charge it takes the ecu a while to learn all the values/readings. I found leaving it tickiver for a while then a half hour drive used to sort it until I left the battery run flat again
yes i left it for a year unused until next MOT time, thats when the issue occured! always garaged! its doing it all the time now!
rob pace
Postby rsturbonutter on Sat Feb 15, 2014 1:16 pm
Have you sprayed all sensor connections with wd40 or similar
rsturbonutter
Postby rob pace on Mon Feb 17, 2014 6:11 pm
rsturbonutter :Have you sprayed all sensor connections with wd40 or similar
no i havent dude!
rob pace
Postby rsturbonutter on Mon Feb 17, 2014 6:18 pm
I suggest that you do mate just in case you have a dry connection somewhere
rsturbonutter
Postby rob pace on Mon Feb 17, 2014 6:31 pm
rsturbonutter :I suggest that you do mate just in case you have a dry connection somewhere
cool, my friend is lending me a coilpack so going to try that first!
rob pace
rob pace
Postby rsturbonutter on Mon Feb 17, 2014 6:54 pm
I can send you a tps to try mate as well if you like if its not that you can send it back
rsturbonutter
