fiesta rs turbo power
26 posts • Page 1 of 1
ok got a stage 3 head with piper rally cam , t2 stage 2 turbo ,195chip for the ecu , front Alloy intercooler i no the engine useing this set up was doing 211bhp but it had 132k on the engine with out a rebuild so i fort 1st thing is to rebuild the engine but im geting a new set of pistons have had the bottom end rebored to 0.5+ and looking at geting Wossner forged pistons any one used them and what type of power will i get in the end with this set up
thanks ben
thanks ben
- essexracing1
About 200bhp forged pistons woun't give you any more power they will just let you run more with out blowing a hole in them you need a T3 to give it a push well over the 200bhp my mate has the same spec and he got 198bhp i would get a chip mapped form Grove or MSD afetr the T3. I hope you have the fuel pump and injectors to go with the chip
- j7aoc
You shouldn't be driving your car around unlees you have 701 injector's in there and and a escort cossy fuel pump i would remove the chip asap and you wouldn't be able to run cossy injector's on a stage 2 chip as there low impedance and a fiesta turbo need's high impedance. Stage 2 chip's need 701 injectors as that's what all standard stage 2 chips are mapped for
- j7aoc
j7aoc :You shouldn't be driving your car around unlees you have 701 injector's in there and and a escort cossy fuel pump i would remove the chip asap and you wouldn't be able to run cossy injector's on a stage 2 chip as there low impedance and a fiesta turbo need's high impedance. Stage 2 chip's need 701 injectors as that's what all standard stage 2 chips are mapped for
oh sorry i forgot to post up the injectors are beige but i dont think they are cosworth one's do you no what the beige one's are ??
thanks
- essexracing1
If there cossy one's there no good what so ever you need beige 701's which are high inpedance (16ohms) you can only run cossy injectors if you are running cossy managementessexracing1 :j7aoc :You shouldn't be driving your car around unlees you have 701 injector's in there and and a escort cossy fuel pump i would remove the chip asap and you wouldn't be able to run cossy injector's on a stage 2 chip as there low impedance and a fiesta turbo need's high impedance. Stage 2 chip's need 701 injectors as that's what all standard stage 2 chips are mapped for
thanks
- j7aoc
j7aoc :If there cossy one's there no good what so ever you need beige 701's which are high inpedance (16ohms) you can only run cossy injectors if you are running cossy managementessexracing1 :j7aoc :You shouldn't be driving your car around unlees you have 701 injector's in there and and a escort cossy fuel pump i would remove the chip asap and you wouldn't be able to run cossy injector's on a stage 2 chip as there low impedance and a fiesta turbo need's high impedance. Stage 2 chip's need 701 injectors as that's what all standard stage 2 chips are mapped for
thanks
just been doing some homework and they are 701's what are the next ones up to go for
thanks ben
- essexracing1
Ford motorsport one's or lancia delta intergrale injectors would be next step up but the chip you use must be mapped for the injectors so you will need to get a chip mapped so you can go to the next step
- j7aoc
I would find out if it has an uprated fuel pump as you need one for a stage 2 chip then t3 after that i would have it all set up on a rolling roadessexracing1 :ok thanks mate and will i see a good boost of power then ??
- j7aoc
j7aoc :I would find out if it has an uprated fuel pump as you need one for a stage 2 chip then t3 after that i would have it all set up on a rolling roundessexracing1 :ok thanks mate and will i see a good boost of power then ??
i no 100% the fuel pump is off a cossie as i fitted it and looking into geting a t3 turbo later today as dad has just taken over ford spares and he's geting me one for free with no play and the oil pipes to as i need them
- essexracing1
You'll also need the rubber oil return elbow and the metal push fit to block for the drain and braided oil supply pipe. As well as this you will need the Escort RS turbo exhaust manifold and downpipe and somebody who's a dab hand with a welder to mate the Escorts exhaust to the Fiestas.
It's not quite as straight forward as just bolting bits up but it's not too far off and well worth doing in the pursuit of power.
Oranoco :You'll also need the rubber oil return elbow and the metal push fit to block for the drain and braided oil supply pipe. As well as this you will need the Escort RS turbo exhaust manifold and downpipe and somebody who's a dab hand with a welder to mate the Escorts exhaust to the Fiestas.
thanks mate i can get a exhaust manifold and downpipe very easy as work for ford spares and i do welded to got a little mig set up here and if i cant do it i bet my boss / dad will do it
with all the bits i have done and useing a t3 im hopeing to get about the 220bhp is that doable ??
- essexracing1
- essexracing1
Yes it would be. Just look out for a paddle clucth and a lsd gearboxessexracing1 :thanks mate i can get a exhaust manifold and downpipe very easy as work for ford spares and i do welded to got a little mig set up here and if i cant do it i bet my boss / dad will do it
- j7aoc
- j7aoc
j7aoc :Yes it would be. Just look out for a paddle clucth and a lsd gearboxessexracing1 :thanks mate i can get a exhaust manifold and downpipe very easy as work for ford spares and i do welded to got a little mig set up here and if i cant do it i bet my boss / dad will do it
im going fitp on sunday going to look out for one for sale
- essexracing1
Make sure you make yourself known then chap. I shall be on the FordSport stand with a Mercury grey FRST called Noo
Oranoco :Make sure you make yourself known then chap. I shall be on the FordSport stand with a Mercury grey FRST called Noo
will do mate
- essexracing1
- j7aoc
- j7aoc
soz i didnt come and say hi was over with ford force a lot of the day
no one had a lsd box for sale come to think of it not a lot of ppls saleing at all
- essexracing1
