Fiesta RS Turbo Restoration...FINISHED ITEM CONCOURSE PICS. : Member's Gallery - Page 9 | Fiesta Forums
Re: Fiesta RS Turbo Restoration...More pics!!
Postby RSGeorge on Tue Nov 15, 2011 10:23 pm
What you doing with the roll over spit now eddie?
RSGeorge
Your car: Saab 9-3 & VW T4
Postby fezza89 on Tue Nov 15, 2011 10:24 pm
i can see you trailoring this to shows edd :lol:
fezza89
Postby luca on Tue Nov 15, 2011 10:56 pm
Beautiful resto!!!!!
May I ask what paint you sued for the springs?
also what kind of brush size?
Im currently restoring my S1 and need to do this to the springs
luca
Postby RS EDDIE on Wed Nov 16, 2011 12:27 am
Thanks for the comments people
...and yes i have thought about using a trailor etc, BUT... only if the dust on the road and moisture content in the air doesnt cause any panic!!!! :rolleyes:
George...The rollover spit is coming with me in the new year when ill be restoring FRST Silvers RS Fiesta for him!!!! :D
Luca...The springs have been shotblasted and powdercoated with Du-Pont powdercoat. The paint flicks were done using a 10mm artists brush with Enamel paints (humbrol). :D
Thanks again fellas!!! :Q
RS EDDIE
Postby RS EDDIE on Wed Nov 16, 2011 7:41 pm
Small update:
The car is back on the axle stands and the rear beam and AVOs (temp) on. Just got to build up the rear hubs again usung all new gen ford parts, and then i can drop the rear onto its wheelies!! :D
Did buy a set of front wheel bearings but after 2wks they havent turned up, so ive got to buy some others then get them pressed into the front hubs. Once this id done i can get the drop links ( cannot find any gold ones anywhere!!) and the whole car is ready to be rolled out of the garage and then a big tidy up, ready for the new carpet to be laid!!!
:Q
RS EDDIE
Postby Dave G fsi on Wed Nov 16, 2011 8:01 pm
Nice one Eddie, really getting there now :D
Dave G fsi
Your car: Mk1 FRS and FRST
Postby Colescustomz on Mon Nov 21, 2011 10:31 pm
looking spanktastic eddie
Colescustomz
Your car: Fiesta Rs turbo
Postby RS EDDIE on Fri Nov 25, 2011 9:19 pm
Cheers Fellas!!!... :D
Small updates....
Went to fords last week and bought some new bits and bobs....
Also got a few new fuel feed hoses from Fords for the bay area!!! :Q
Car is now on axles stands awaiting drop links. I have bought some new Brembo front disks and pads, and gen Ford rear brake internals well cheap!!!
The only thing ive got to do is repaint the standard shocks again. I wasnt happy with some of the finishes so i got them shotblasted so now they are totally clean of crud and rust awaiting paint. Once it has dried in the oven i can fit the whole front and rear setup. The rear beam is on already awaiting new bolts for the powdercoated ARB clamps.
Hopefully by the end of next week it will be rolling.
Finally it will have
1) Brand new front Pads...Callipers...Disks...and Bearings on the front
2) Brand new Ford rear shoes, Levers and Fitting Kits for the rear with new bolts freshly painted!!!! :Q :Q
Updates and pics to follow..... :D
RS EDDIE
Re: Fiesta RS Turbo Restoration...Small Update..
Postby rob pace on Fri Nov 25, 2011 9:32 pm
i really want to go concours with my car after seeing this :lol:
just havent got the space! :(
rob pace
Postby RS EDDIE on Fri Nov 25, 2011 9:43 pm
Its a mare already rob!!!
Because theres no bonnet on it etc etc, its proper bad watching all the dust settle on the fresh powdercoated stuff!!! Ive just had to get my car cover out and get it over it for the time being as ive been bricklaying for the last day ar so and the cement dust is well airborne!! :lol:
Also now its off the jig its a pain keep on stepping around it and all the gear layed out ready to go on. I havent stared at the underside for a week!!! :lol:
I think im gonna have to get a detailed wether forecaster for next year and any sign of rain i aint going to the show!!! :D
But to make me feel a bit better, i have just landed two new gearnobs to go with my new steering wheel!!! :Q
RS EDDIE
Postby Excursion on Fri Nov 25, 2011 9:54 pm
Ahh you got the correct strut tops (not that you wouldn't!) - do Ford still supply them like that?
When buying bits for mine I'm finding a lot of what were traditionally zinc plated parts now come painted silver instead.
Postby RS EDDIE on Fri Nov 25, 2011 10:19 pm
Hahaha!!! Yeah got the correct tops now mate!!! :D
Ive found that alot mate. Whereas fords used to do all their nuts and bolts in the goldy zinc, i finding that now nearly all the bits are painted in a naff matt grey rustproof paint....lokks a bit poo if you ask me!!!
RS EDDIE
Re: Fiesta RS Turbo Restoration...Shocks done!!
Postby RS EDDIE on Sun Dec 04, 2011 9:17 pm
Small update.....
Managed to get the standard shocks back from shot blasters. I painted them in 3 coats of enamel gloss black with 2k laquer. Placed the original coded dots onto the legs and some ford stickers with codes...What ya think of these puppies?? :Q
Also managed to get some more bits from various places.....
And before they go to the powdercoaters some new shock brake hose brackets!! :Q
Hope yas like!!! :D
RS EDDIE
Re: Fiesta RS Turbo Restoration...Shocks Done!!
Postby Rhinopower on Sun Dec 04, 2011 9:25 pm
Exceptional attention to detail :)
Rhinopower
Your car: Volvo FH330
Postby Dave G fsi on Sun Dec 04, 2011 9:27 pm
Stunning mate :aviator:
Dave G fsi
Postby Fraggle on Sun Dec 04, 2011 9:44 pm
Awesome :Q :Q
The enamel idea is spot on, ive had a few bits done in the past, real durable protection.
Need to see more now :Q :Q
Fraggle
Postby Excursion on Sun Dec 04, 2011 9:56 pm
Awesome mate.
FYI the factory fit shocks wouldn't have Motorcraft stickers on them; stickers are only on parts that are supplied via the parts network.
Are you sure about the colour code on shocks, I've never seen that on a new car. Springs are correct and the colour match is absolutely perfect :o .
Postby RS EDDIE on Mon Dec 05, 2011 12:13 am
Thanks for the comments people... :Q
Excursion..The motorcraft sticker is only as an idea, as a new shock that mr2orange has for sale has the sticker on the leg.
However when i first got my Fez it still had the colour coded circles on the legs so i know for sure that, that bit is correct.
The other sticker that i might replace the motorcraft sticker with is the white ford sticker that goes on the bottom of the legs. This has the number copied from the stamped number on the leg i.e... Motorcraft K8N7A - O.L.C AND BELOW IT...V90FB - 18076 - AB. Ill see which i prefer as either brakes it up a bit and imo looks good. :Q
Thanks for the comments tho geezas...every little helps!!! :D
RS EDDIE
Postby jonyb4 on Mon Dec 05, 2011 3:31 am
haha brilliant! love the attention to detail, im worried for them stickers though, paper and water dont go, cant you coat them in some plastic film or something?
Postby rsturbonutter on Mon Dec 05, 2011 4:18 am
jonyb4 :, im worried for them stickers though, paper and water dont go, cant you coat them in some plastic film or something?
Jony i don't think this car is ever going to see water lol. At least not from underneath :D :D
rsturbonutter
Your car: Fiesta RS turbo
Postby RS EDDIE on Mon Dec 05, 2011 12:47 pm
Hahaha!!! Johny and rsturbonutter.....I hope it doesnt see rain ever again, BUT........I already thought of that....
The ford stickers have already been coated in a plastic film on front and is coated in plastic double sided to the rear!! :Q :Q
Anyway ive got some new stickers that might replace them now, as excursion says they are for only parts bought over the counter and wouldnt have been on a factory vehicle!!!
Shock sticker updates to follow!!!
Thankyoumanytimespleases!!! :D
RS EDDIE
Postby Fraggle on Mon Dec 05, 2011 1:23 pm
This might be of interest to you Mr Edd...
http://www.youtube.com/watch?feature=pl ... is6r6zXFDc
Wonder if thats adaptable or if theres an equivalent for metal..?
Could be a Concorse pro's wet dream that,, and make them some SERIOUS dough.... :D
Fraggle
Postby RS EDDIE on Mon Dec 05, 2011 1:37 pm
Now that HAS interested me kid!!!!
Ive got a thousand and one ideas running through my head as we speak!!! :D
RS EDDIE
Postby mrorange2 on Mon Dec 05, 2011 3:18 pm
WOW not checked this for a bit loving it them shocks look wicked. Will get you a better piccy of the shock sticker. The one i sent you was taken from an iphone will get a good one with my digital cam.
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby rob pace on Mon Dec 05, 2011 3:24 pm
how the exhaust going mate??
i found another genuine fiesta rs turbo exhaust im keeping as a spare! :bonkers:
rob pace
Postby Fraggle on Mon Dec 05, 2011 3:28 pm
RS EDDIE :Now that HAS interested me kid!!!!
Im following the progress of the product as we speak,trying to find a way to contact the inventors direct,,long chalk but worth a punt imop..
.... but if i ever got to your standard of work i would be killing for some of it..
Was posted on another forum i doss on, simply noticed and pasted it for your possible intrest.
Make keeping your interior less of a worry praps.. :-?
Fraggle
Postby mrorange2 on Mon Dec 05, 2011 4:20 pm
rob pace :how the exhaust going mate??
Where do you find them i'm in great need of a genuine backbox as thats they only none orginal part left on mine.
mrorange2
Postby rob pace on Mon Dec 05, 2011 4:23 pm
mrorange2 :
lol, just people i know! :wink: its the larger backbox as well and not the revised smaller one! havent seen one for sale in years!
rob pace
Postby RS EDDIE on Mon Dec 05, 2011 4:25 pm
Rob, we have that in common dear boy. I know of a mint standard exhaust that will be sitting in my garden very soon!!! :Q
The one you sold me is going for the front pipe to be welded on as i managed to cut a front box with pipe from another old rs exhaust!!! Wheredya find yours mate?? :D
Also was walker an original manufacturer of frst backboxes???
RS EDDIE
Postby rob pace on Mon Dec 05, 2011 4:35 pm
RS EDDIE :Rob, we have that in common dear boy. I know of a mint standard exhaust that will be sitting in my garden very soon!!! :Q
yep, im sure walker was, well for the series 1 rs turbo it was, some had walker or ford logo stamped on them. im sure someone will know if is the same for the fiesta, but ideally you want a ford stamp on it, can see exhausts making a mint soon like the series 1 systems.
im still after a brand new brake servo! :lol:
rob pace
Postby Michael! on Mon Dec 05, 2011 4:42 pm
Fraggle :This might be of interest to you Mr Edd...
mindBLOWN.
brilliant progress as per...
ft-com-members-map-vt190192/
Michael!
Postby RS EDDIE on Mon Dec 05, 2011 4:45 pm
Must have been for the fiesta rs turbo aswell then.
Ive got a walker backbox with the square tailpipe, had it for a few years and its alot bigger than the one you sold me...ill post some pics later!!!! :oooh:
RS EDDIE
Postby rob pace on Mon Dec 05, 2011 4:48 pm
RS EDDIE :Must have been for the fiesta rs turbo aswell then.
cool if you know if of a new servo for sale let me know!
how did you do your underside? all by yourself i.e painting and putting on underseal etc....
rob pace
Postby RS EDDIE on Mon Dec 05, 2011 4:58 pm
Yes mate did it by myself with a compressor, rollover jig, 8 tins of rubberised underseal, 2 tins of zinc paint, 2 bottles of Kurust, 2L of merc grey and 1L of 2k laquer. :D
Yes ill look out for that servo. I managed to find a rust free undented one and tcut then moped it. Came out like a mirror!!! :Q
RS EDDIE
Postby mrorange2 on Mon Dec 05, 2011 5:05 pm
If either of you wanna sell me or can find me an FRST back box let me know i need one as mine has a horrible bosel on it.
mrorange2
