Re: Fiesta RS Turbo Restoration...UPDATED.
Thanks lads!!! Took ALOT of fiddling around to get right, and plenty of goes to match colours!!!
Top right blue sticker= Battery Live red lead info sticker
Yellow sticker=Rear Top of Servo
Two white stickers=Different sizes of front lower servo (to match top rear!!)...Just got to decide on size to use!!!
Jay...I couldnt think of anything to use other than an old baking griddle!!!
Rob....I will be trying to make a few sets depending on interest and time available...Got so much on atm getting the car ahead of schedule!!!
- RS EDDIE
They look brill mate i'd be interested in a set depending on price mate
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
ok eddie the money is waiting for you mate for the stickers!
- rob pace
it done the job mate, good enough
Small update....
Been getting some of the engine bay gear finished ready to bolt up to the engine when it comes back in the next few weeks. Painted the manifolds in a permanent paint, then used my ol dears oven, (gas mk6 for around 35mins) to harden and cure the paint.
Fairly pleased with the outcome as i was going to get it all vapour blasted, but saw a friends work on a BDG engine so decided to try it.
This is the outcome...
Crossover pipe....
Inlets including new stickers and some of the new zincd metalwork...
Over time the cleaned metal will oxidise a bit and tone down. Just gona get two rocker covers powdercoated, one silver and one original grey then choose which looks the better and go for that one!!!!...
(some of the zincd stuff in these pics looks very orangy-yellow, which is the light making it look alot richer than it is in natural light!!)
Crossover pipe....
- RS EDDIE
Re: Fiesta RS Turbo Restoration...INLETS
ooooow that is stunning!
Thats cleaner than it came out the factory!!!
- - Danny Boy -
- Your car: Fiesta Si 2.0
Thanks fellas, glad you like.
I do sometimes look at myself and wonder why im sitting at home cleaning the insides of manifolds and the threads of screws etc, maybe itll be worth it!!!!!
Was looking over the car last night and believe it not, NEARLY ever part, bar the shell, will have been overhauled or brand new!!!!!
- RS EDDIE
stunning work mate!
- rob pace
Wow thats nice very good work i wouldnt wanna take this car outside once finished lol
- mrorange2
excellent mate
you dont see that throttle bracket on the frst's much, there norm on xr2i's, but i think there the better ones when it comes to ease of removing the rocker cover!!
one concern though, on the inlet, where the vac pipe comes out to the brake servo, theres the push fit connector in that, and its brass and plastic.
i dunno how long you baked the inlet, but im thinking there might be a good chance the plastics been effected and you might end up with a slight vac leack on the seal, so might be worth changing before you refit the inlet, that way you can get it out easier, and any bits that go in the inlet, isn't going to make its way into the engine.
- AndyKam
- Your car: 1991 Red FRST
Absolutely stunning as per usual Eddie, bet your well pleased with how its all coming together now
- Dave G fsi
- Your car: Mk1 FRS and FRST
you make me so angry, i cant even afford a car and you make me drool over this everytime i click on it!
- Michael!
chillax now Michael
wow thats unreal looking!! the zinc coated bits set it off a treat!
- Dave5300
Hahahaha!!!! Thanks fellas. Makes it worth the while to have some good input recieved.
Jay...The heat from the oven curing i doubt was hot enought to distort that part, as i could handle the inlet straight from the oven, and ive double checked it but much appreciated for the heads up, easily overlooked if you get tunnel visioned into looks of the items when done!!!!
The bracket ive always prefered to the other style for the reasons mentioned and i think it gives a bit more interest to the engine.....Here the pic from a 1991 Ford Brochure i found.....
##Been to the painter today and im 100% happy witht the fella, and his ccracking attitude to things such as overspray etc on the inner arches and underneath etc. He seems a real friendly chap with an interest for the car, and doesnt see it as "just another blow over coming through" and iv seen his work on a merc grey S2!!!!
Thanks again!!!
Thanks again!!!
- RS EDDIE
if you could handle it, then it wont be effected so all good mate.
sounds goon on the paint, get some pics up
i ejoy professional people like that, nothign worse than a snob who just takes you for an idoit and does what he likes to your car, ive stopped going to my local mechanic for these reasons, he doesnt even ask what i want done if say a brake caliper has seized, he simply took it to himself to buy a brand new (refurbed) unit, instead of rebuilding mine
if he had asked id have bought a 2nd hand one
sorry jibber jabber
sorry jibber jabber
thing is though jony, unless you tell him you want s/h he wouldnt rebuild your old one, in most cases its just not worth the hassle or cost as it might still leak after.
and thats another reaosn most garages wont fit s/h ones, cos if it leaks, or fails, they could be held lible for it
That looks great Edd, there's not a huge difference between that finish and vapour blasting. Very nice
Cheers Mark....
- RS EDDIE
Finally the car is nearly ready for paint!!!!
Was meant to be going in yesterday, but i was let down by the lowloader and it has taken me a fair few drill bits and plenty of cigarrettes, trying to get a rusted in door pin out!!! Then i couldnt get hold of any. Turns out my mate at Fords can still get hold of them for me, so i went and bought 4 + clips earlier today!!!
Heres a few pics of it at the moment...
As i said, a few things to do yet like temp fix the drivers door on, and the bonnet ready for the painter to easily unnattach them when he starts it. Although he said hes gonna take extra care and skirt the car im still gonna wrap all the underneath in binbags and tape so its easily to take back off, when its back.
The engine is being started as we speak and the gearbox has all new gaskets and circlips fitted ( Thanks for the help Excursion (Mark) ol Chap!!) and is currently being taken back to metal for the repaint.
Its not going to be at Central Day as its far too early as ive got to test stuff when it gets nearer the time, such as brakes, fueling etc, then got to get it MOTd, Taxd etc....Oh and insured again!!!!
Anyway only a small update, but do enjoy!!!!
- RS EDDIE
good news man, shes looking sorry for herself but i cant wait to see her back
Should look good when back, ive been and met the painter and seen his work and hes also fully aware of the job i want so im confident it should come back box fresh!!!
- RS EDDIE
You need to put the charge pipe and inlet in a display cabinet. f**k me mate they are stunning!!!!!
- Maxwell
- Your car: FRST - 2wd SAFF COS
Thanks mate....
Ive got pals who've got 911s and top class range rovers, and they cant understand my thinking, that them cars are run of the mill and boring, commanding no attention.
Good to see your thoughts are with mine!!!!
- RS EDDIE
Looking very good fella when it gets painted now you will appreciate all the other work that you have done. Just wish mine was in this league fella. A big credit to you. I don't think there will be a better standard example of rs turbo out there. I take it paint day is soon though
- rsturbonutter
- Your car: Fiesta RS turbo
looks great edd
who's doing the paintwork for you in the end
- pauldolman
Getting close now eddie
- Dave G fsi
not long now mate.
i just love the attention to detail, cant wait to see her finished
- Dave5300
More problems!!!!
Was going for paint today, but i took the bonnet out of storage, and remembered i filled the underside lip at the front a few years ago. When i looked at it i could see some rust bubbling on the paint and the underside was filled resulting in the lip going leaving a smooth underside....Didnt like this.....Any way after a bit of prodding around this is how i was left a day before painters!!!
Holy Rustman Robin!!!!
Bonnet is fooooked!!!!
After searching the whole of Europe for a new bonnet i was unsuccesful as they are NLA anywhere, even afterparts depts.
Had a touch tho, after loosing out on one on ebay, i contacted the seller and he said the timewaster who won it, didnt turn up for it.........Moral of the story????........£70-00 later i had another MInt bonnet in the same colour with a superb front lip, not a sign of rust anywhere!!!!...Result!!!!
Took the wiring loom brackets out again as they were getting too dusty and id forgotten to put the bonnet hinges back anyway....
The New addition to the car!!!!
NOW booked in for paint on tues/wed next week!!!!!
- RS EDDIE
Re: Fiesta RS Turbo Restoration...PROBLEMS!!!!
lucky baxtered finding that in time!
made me wonder though, im damn happy my turbo bonnet is actually rust free, turbo parts are getting rare now! even worse some are rusting away, or dented to fook, and some ruined by being bad "boy'd"
will she be ready for show season then mate?
Chop chop, not long until Central Day
- Turboboy67
- Your car: 911GT3 RS
