Fiesta RS turbo (Restoration)
Postby bertinrsturbo on Wed Sep 29, 2010 7:44 pm
hi!
I am restoring a fiesta rs turbo, and if you do not mind I will be putting pictures of the entire process.
a greeting.
bertinrsturbo
Your car: Fiesta RST 1990 / Focus st 2.5
Re: Fiesta RS turbo (Restoration)
Postby bertinrsturbo on Wed Sep 29, 2010 7:54 pm
so buy it for £ 500
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:02 pm
more photos
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:08 pm
more photo.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:12 pm
more photo.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:19 pm
hi!
after purchase service a little high the coup.
below disassemble the engine and weld a front and a new fin.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:25 pm
more photo.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:30 pm
here some pics of when shopping.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 8:37 pm
I hope not to disappoint or upset with the restoration. I have many photos.
below darkening the tail lights.
bertinrsturbo
Postby jayrs on Wed Sep 29, 2010 9:21 pm
hello mate.
nice project this, repairs so far are going well :)
the rear lights, if you want a real set of lights like that (propper hella RS accessory), with proper smoked indicators, send a PM to Carbonboy67 as he has a few sets of euro spec ones
Postby bertinrsturbo on Wed Sep 29, 2010 9:22 pm
hi!
preparcion engine. the engine will be phase 2.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 9:32 pm
side indicators fin I have them in transparent, I will contact to get the tail lights. thank you very much.
below blue painted engine block, new oil pump, new seals, new pistons, bushings and new segments and new gaskets.
lightened crankshaft and flywheel.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 9:40 pm
more photo.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 9:46 pm
below the purchase of a Garrett T-3.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 10:03 pm
I have the stage 2:
701 beige injectors
-31 actuator
Garrett T-3
Superchip 195bhp stage 2 (OFAB)
Powerchip Stage 2 195bhp (OFAB)
bosst controller
gearbox escort rs turbo s2
grease gave himself T-3
turbo pressure gauge
I need to buy:
airtec front intercooler t-3
kent cams camshaft CHV 35
adjustable pulley
cometic laminated gasket
donwpipe escort rs turbo
walbro 255
fuel pressure regulator HKS
mongoose exhaust line 4 "
map sensor Sierra Cosworth 2WD (2bar)
I think that with all this stuff finished the stage 2, I expect you can help me with your suggestions.
many thanks. a greeting.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 10:12 pm
I have also again:
distribution kit
crankshaft gear
head bolts
Rear Bumper (fiesta rs turbo)
transparent side indicators
and 2 nd hand:
front brakes 2000 escort rs 260mmx24mm
hubs + rs 2000 escort rear brakes
bar front and rear cups
assisted rack mk3 fiesta 1.8d
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 10:19 pm
next photos are clean and painted hollow motor.
bertinrsturbo
Postby bertinrsturbo on Wed Sep 29, 2010 11:04 pm
some photos do not have very good quality because they are made with a cell phone, I'm sorry.
A question on the front intercooler. best option is mounting:
airtec front intercooler T-3
GRS intercooler EVO3 Front
thanks a greeting.
bertinrsturbo
Postby bertinrsturbo on Thu Sep 30, 2010 9:45 am
hi!
hollow motor ready to start assembling.
preparing the front bumper for the intercooler.
bertinrsturbo
Postby bertinrsturbo on Thu Sep 30, 2010 9:52 am
apart from the front fender gap for the front intercooler I'm going to put a golf vr6 spoiler, as I had put in my ford fiesta RS1800, here you have some photos of my RS1800.
a greeting.
bertinrsturbo
Postby MK2 Jamie on Thu Sep 30, 2010 12:06 pm
Looks like you got a good car for £500, Shell looks clean. I do like those white wheels too.
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby jayrs on Thu Sep 30, 2010 8:55 pm
looks nicly done mate
what have you done with the green stips you have taken off the sides?
there getting rare and worth £100 easy, provided you have taqken them off ok and not bent them up
Postby bertinrsturbo on Thu Sep 30, 2010 10:32 pm
thanks ;-)
the green line I'm looking for one for the front bumper since I had is broken. here in Spain is discontinued there. some time on ebay but was sold a very expensive .... 190£
a greeting.
bertinrsturbo
Postby jayrs on Thu Sep 30, 2010 11:50 pm
bertinrsturbo :thanks ;-)
a greeting.
they have been discontinued here in the uk also mate.
put a wanted ad up in the wanted section, your get one, wont be new (unless your lucky, but it would be expensive) and seconf hand, bumper stips go for between £20 and £40
Postby bertinrsturbo on Fri Oct 01, 2010 10:57 am
thankyou ;-)
bertinrsturbo
Postby bertinrsturbo on Fri Oct 01, 2010 11:48 am
hi!
a few pictures of items you buy new.
OFAB unit with Superchips and powerchips.
bertinrsturbo
Postby bertinrsturbo on Fri Oct 01, 2010 11:54 am
pressure gauges
bosst controller
grease tube T-3
transparent indicators
bertinrsturbo
Postby bertinrsturbo on Fri Oct 01, 2010 11:57 am
rs turbo sticker
head screws
bertinrsturbo
Postby bertinrsturbo on Fri Oct 01, 2010 12:02 pm
Escort RS2000 rear bushings
Escort RS2000 rear calipers
bertinrsturbo
Postby bertinrsturbo on Fri Oct 01, 2010 12:04 pm
rear brakes I have to restore, paint, new bearings, new discs and pads.
bertinrsturbo
Postby bertinrsturbo on Sat Oct 02, 2010 10:37 pm
hi!
be kind of a question for the preparation stage 2?
standard clutch (Valeo)
ceramic clutch (AP Racing)
thankyou.
bertinrsturbo
Postby bertinrsturbo on Mon Oct 04, 2010 9:45 pm
hi!
comment that started today Trainee mechanic at a Ford dealership.
'll post pictures soon of a new Escort RS2000 rear calipers, crankshaft sensor, brake hoses and metal blocks around flo-flex polyurethane.
Greetings.
bertinrsturbo
Postby knuckles on Tue Oct 05, 2010 10:13 pm
bertinrsturbo :hi!
thankyou.
depends on what power you plan to run
150bhp would be ok on a std clutch
i run 170bhp through a std clutch and it slips in 3rd so i fitted an Ap paddle clutch
knuckles
Your car: Fiesta Rs turbo
Postby bertinrsturbo on Wed Oct 06, 2010 9:40 pm
ok !
thankyou.
I have planned stage 2 (190bhp-195bhp)
bertinrsturbo
Postby bertinrsturbo on Sun Oct 17, 2010 1:19 pm
hi!
I have received:
steering bolts
crankshaft sensor
front strut top mount in poly flo-flex
bertinrsturbo
