Fiesta RS turbo (Restoration)
Re: Fiesta RS turbo (Restoration)
Postby bertinrsturbo on Sun Oct 17, 2010 1:29 pm
Photos soon painted rear calipers with new seals and polyurethane bushes rear set flo-flex.
a greetings.
bertinrsturbo
Your car: Fiesta RST 1990 / Focus st 2.5
Postby bertinrsturbo on Mon Oct 18, 2010 8:40 pm
hi!
I have arrived vibratechnics gearbox.
bertinrsturbo
Postby b0yracer on Tue Oct 19, 2010 8:31 pm
nice project youve done well there. like it :D
b0yracer
Your car: ford
Postby bertinrsturbo on Tue Oct 19, 2010 10:55 pm
thankyou ;-) :)
bertinrsturbo
Postby bertinrsturbo on Tue Oct 19, 2010 10:58 pm
photo.
bertinrsturbo
Postby bertinrsturbo on Tue Oct 19, 2010 11:02 pm
hi!
come, metallic brake hose.
bertinrsturbo
Postby mies1974 on Wed Oct 20, 2010 5:47 pm
bertinrsturbo :Image
Does any body know how to fit the round rear spring top mountings (in the front of the picture) well into the ellipse-shaped top of the rear spring tops? I think the're not fit tight in there, and that they'll move from front to back all the time.
Does anybody have this problem?
Image an XR2i 1.8i 16v (RS1800) owner from Holland
mies1974
Your car: Fiesta XR2i 1.8 16v (130)
Postby bertinrsturbo on Thu Oct 21, 2010 9:24 pm
hi!
when mounted confirm the problem. ;-)
bertinrsturbo
Postby bertinrsturbo on Sun Oct 24, 2010 9:47 pm
hi!
metal brake hose.
bertinrsturbo
Postby bertinrsturbo on Sun Oct 24, 2010 9:53 pm
new paint engine bay.
bertinrsturbo
Postby bertinrsturbo on Mon Nov 01, 2010 10:48 am
hi!
Photos of the reform to put power steering.
steering is a ford fiesta mk3 1.8d.
steering rod replaced, change the hole where the cardan. I will also rebuild the rack (new ball joints, new bellows, and clean up).
bertinrsturbo
Postby bertinrsturbo on Sun Nov 07, 2010 2:24 pm
hi!
more progress and parts.
bertinrsturbo
Postby bertinrsturbo on Sun Nov 07, 2010 2:27 pm
new parts:
steering knuckles
bellows direction
vieleta of direcion
The other parts that appear in the photo are to clean and paint.
a greetings.
bertinrsturbo
Postby bertinrsturbo on Tue Nov 09, 2010 9:20 pm
hi!
Painted servobrake.
bertinrsturbo
Postby bertinrsturbo on Tue Nov 09, 2010 9:28 pm
stabiliser antiroll-bar ford original , gatex distribution kit, ford case for documentation, CVH flywheel bolts.
bertinrsturbo
Postby bertinrsturbo on Tue Nov 09, 2010 9:31 pm
original front bonnet ford, the last one had around Spain.
bertinrsturbo
Postby bertinrsturbo on Tue Nov 09, 2010 9:57 pm
photos of the new front bonnet.
bertinrsturbo
Postby bertinrsturbo on Tue Nov 09, 2010 10:05 pm
cleaning gearbox fiesta rs turbo.
I have 2 gearboxes:
escort rs turbo s2
fiesta rs turbo
which box is better?
it shows the self-locking box s2 escort rs turbo comes standard?
that box has the shortest relationship?
thankyou.
bertinrsturbo
Postby jayrs on Tue Nov 09, 2010 11:52 pm
coming on well mate, keep up the good work :)
Postby bertinrsturbo on Wed Nov 10, 2010 10:33 pm
hi!
thankyou for your comment, i will continue with this proyect.
bertinrsturbo
Postby bertinrsturbo on Sat Nov 13, 2010 12:40 pm
hi!
new photos:
steering rack painted black
new bushings
more progress soon.
bertinrsturbo
Postby bertinrsturbo on Sun Nov 14, 2010 10:32 pm
hi!
more progress.
fuel filter bracket and rubber steering.
bertinrsturbo
Postby bertinrsturbo on Sun Dec 05, 2010 12:10 pm
hi!
then new developments.
Greetings.
bertinrsturbo
Postby Excursion on Sun Dec 05, 2010 5:16 pm
Very nice. For the engine, you can use the PAS brackets from a 1.4 Si.
Postby bertinrsturbo on Wed Dec 08, 2010 10:54 pm
hi!
please help!!!!!!
the bracket pas, is valid for a ford fiesta mk4/mk5.
CVH engine is valid?
thanks in advance.
bertinrsturbo
Postby Excursion on Thu Dec 09, 2010 12:59 pm
bertinrsturbo :hi!
please help!!!!!!
thanks in advance.
Hi,
Fiesta Mk4/Mk5 will not fit. You require brackets from a Fiesta Mk3 1.4 Si (CVH engine but renamed to PTE).
Do you use T2 Turbo? I believe that a T2 will not fit with PAS.
Postby bertinrsturbo on Thu Dec 09, 2010 11:07 pm
hi!
okey, thankyou.
I'm going to use a garret T3
bertinrsturbo
Postby bertinrsturbo on Sun Dec 12, 2010 11:41 am
hi!
some photos retouched.
bertinrsturbo
Postby KEVFRST on Sun Dec 12, 2010 9:05 pm
Nice resto pictures. The damage in the 1st pictures didnt seems so bad but it was servere enough to push the steering wheel to the wrong side. You still havent fixed that.
Keep up the good work.
PS, best colour too.
KEVFRST
Postby bertinrsturbo on Mon Dec 13, 2010 10:47 pm
hi!
thermostat and Clear Perspex Cam Cover.
bertinrsturbo
Postby jayrs on Mon Dec 13, 2010 11:03 pm
love the came cover, gotta be the best clear one ive seen.
where did you get it from and how much was it out of interest?
Postby bertinrsturbo on Mon Dec 13, 2010 11:59 pm
hi!
UK buy on ebay,price of 120 pounds.
thankyou!!
bertinrsturbo
Postby jayrs on Tue Dec 14, 2010 1:19 am
i'll have to keep a eye out, although £120 is a fair amount..
Postby bertinrsturbo on Tue Dec 14, 2010 9:45 pm
bertinrsturbo
Postby bertinrsturbo on Fri Dec 17, 2010 8:34 am
hi!
this week I bought a ford focus st 2.5 turbo 5cylinder.
These days I take photos.Greetings.
bertinrsturbo
