fiesta rs turbo, updated, 29/03/16 : Member's Gallery - Page 52 | Fiesta Forums
Re: fiesta rs turbo, decided now
Postby jayrs on Sat Apr 23, 2011 10:50 am
ive never looked into opening them up, but tbh, if there was a way, i think it would of been done a lot by now.
the wheels i have now are 7x15
Postby frst toady on Sat Apr 23, 2011 11:00 am
well u say that but most ppl would just put a high pressure oil pump on wouldnt they?
frst toady
Your car: ranger super cab, frst t3
Postby jayrs on Sat Apr 23, 2011 11:09 am
some have, but i dont see the point, you can adjust the oil pressure on a std pump anyway, but its nott he pump thats the problme, the cvh suffers from poor oil circulation on the far said of the head and always has, although in most cases it doesnt present a problem.
also, ford have been known to have cam probelsm on other engines in the past too, could be crap cams, oil problems bad desgin etc...
if the cam goes again on my engine then its game over imo, i aint gunna waste any more time, effort and money on it, i'll prob bung a cheap cam in and use the car as a daily or maybe, build a zetec turbo engine for it, but thats a long way off, ill get it sorted this time and i will make a point of driving it more, or starting it up more ofton, and i wanna get a really good oil for it, magnitec would be good as it stands more than it drives, but they dont do it in a fully synthectic so i have to look into this more.
i think really i was just one of the unlucky ones with a iffy cam, even though my old cam did wear out on a couple of lobes, i think that was due to couple of tappet breaking down due to getting a good thrashing (dont have a dog and bark ya self after all) plus it was a cam that was fitted when the car was built...
tanyhow, he oil pressure was fine and always seemed to be fine before the rebuild (untill the cam went and took out a big end), so had no cause to change the pump as it worked fine, but i should of put a brand new oil pump on it when i rebuilt it anyway, so thats my fault, but i still belive the cam was the main problem as theres been others that have has therte kent one go, and they have replaced the cam and nothing else and theres are still going fine
Postby Fraggle on Sun Apr 24, 2011 11:54 am
jayrs ::lol: :lol: if i was telling ya to fcuk off i would come out and say it :lol: :lol: :bonkers:
you like the 3 spokes :aaah: :aaah:
i got 2 sets of them and i dont plan on fitting them, not to say some time in the futre i would fancy having it bog standard looking as they may happen, but i will still hate the wheels :lol:
:bonkers: 1,,Jus Checking... I know voodoo's are an accuired taste like Egg nog :lol: :lol:
2,,Not the tsw ones form around 1992 :rolleyes: (i prefered the Venom :wink: )They should all be turned into Kia's..
3,,Standard rst rims are the spuds,End ov :P :P
Again Good too here a plan Formed for her future...Lookin foward too seeing how u gets on with this Geezer :wink: :Q
Fraggle
Postby jayrs on Sun Apr 24, 2011 12:16 pm
venoums were nice, but they became too popular too quick and i ended up hating them.
egg nog is just toss :lol:
and frst rims, well ive seen worse put it that way, but they still aint for me, although the ones clark has do look better than the normal one, clark has very very very early FRST wheels which had dimples drilled/cast into the dark grey bit where as the later ones had them smooth, so i would rather have the very early ones if i went back to std wheels
these are the very early frst wheels i mean, i could have them on my rs, but not the normal ones, i might even mod a std set to be like this for future events :wink:
Postby niracka on Sun Apr 24, 2011 4:12 pm
standard or mo's are the best rims for the frst IMO.
Glad you made your mind up about the cam Jay. Is there any chance that there could be some issue with your head not supplying enaugh oil were is should do but your oil pressure sensor no picking it up as it takes the reading from elsewere. Could be worth investigating when you get the head off. And has noone come up with a solution to the problems with the head like machining some of the oilways a little more open or could that have an adverse effect on pressure??
Anyways look forward to seing it back o0n the road again mate.
Ollie
niracka
Your car: E46 M3
Postby jonyb4 on Sun Apr 24, 2011 4:15 pm
the "drilled" discs on the earlier rs wheels do look good mind...
Postby fezza89 on Sun Apr 24, 2011 4:44 pm
jayrs :venoums were nice, but they became too popular too quick and i ended up hating them.
you are full of knowledge aint ya jay, i did not know that, now i want an early set :lol:
fezza89
Postby jonyb4 on Sun Apr 24, 2011 6:45 pm
neither did i, i figured people just drilled them themselves
Postby jayrs on Sun Apr 24, 2011 9:57 pm
niracka :standard or mo's are the best rims for the frst IMO.
Ollie
i dont think its a oil feed problem on my engine, when i stripped it first time nothing was blocked or gummed up and it was all cleaned through prior to the rebuild, so maye it was a intermitant fault with the oil pump and it lost a bit of pressure :-? i dunno, but i got my oil pressure gauge plumbed into the T that feeds the turbo oil and also what the std ford oil pressure switch goes into, so i dont think theres a issue there, but when the engine is out its being fully stripped for inspection to see if there is something going on, but i dont see the need for any machine work.
i also look forward to it being back on the road, i really do miss it :(
the early wheels thing will have to go to clark, i belive it was him that first found them, or was it me that showed them to him on ebay, i forget now, but it was discovered by one of us, but before then, i didnt even know about them, but they do look a lot better than the run of the mill "std" ones dont they.
i will be sure to take a pattern of the holes before clark takes his car back, and i will knock a jig up to drill them on "std" wheels and ill bang a set out somewhere and stick them in the loft :lol: :lol:
Postby Fraggle on Sun Apr 24, 2011 11:29 pm
:bonkers: I Learned summink new today..See if he sell em for a nifty too me :wink:
Thanks for sharing the fact on the wheels never seen em before an now i want!! :Q
Fraggle
Postby jayrs on Sun Apr 24, 2011 11:32 pm
:lol: :lol: you got no chance mate! he paid more than that for 1 wheel!
took hima while to get a set of 4, all brand spanking new too, the beauty of ebay :wink:
Postby Fraggle on Sun Apr 24, 2011 11:39 pm
:bonkers: Bunch of jammie dodgers u lot :lol:
Nah jus messing i kinda had a figure in mind of what they'd roughly cost..was thinking about a ton each as like i say i aint ever seen a set.
Fraggle
Postby jayrs on Mon Apr 25, 2011 9:24 am
i saw a set go on ebay for about £110 i think it was last year, used of course, clark opnly paid as much as he did for them as they were all new, i think the first 2 he got brand new were a bit of a steal if i remember, i'll get him to post on here about them
Postby niracka on Mon Apr 25, 2011 4:14 pm
Never knew abiout those either. Thats wierd how they did that and then changed them evry soon after isn't it.
Ollie
niracka
Your car: E46 M3
Postby jayrs on Mon Apr 25, 2011 8:44 pm
i reckon it came down to cost more than anything, maybe it was a few pennies more to make one liek that :lol:
but i deffo reckon they look better than normal, although they would suit a red one far better than a white one :Q
Postby Fraggle on Mon Apr 25, 2011 8:48 pm
:bonkers: Suits white better :P
Fraggle
Postby fezza89 on Mon Apr 25, 2011 9:00 pm
look even better on an ask black one :lol:
fezza89
Postby jayrs on Mon Apr 25, 2011 9:22 pm
Fraggle ::bonkers: Suits white better :P
whats that mate, you want to be banned :lol: :lol: :lol: :lol:
just kidding
they will look good on any colour, but im sure we all agree they look better than "normal" ones
Postby Fraggle on Mon Apr 25, 2011 9:26 pm
jayrs :
just kidding
:bonkers: Banned :oooh: :oooh: :aaah: :aaah: :cry: i'll be off then.....
Fraggle
Postby knuckles on Mon Apr 25, 2011 9:28 pm
lay of my wheels you bunch of vultures ! :lol:
knuckles
Your car: Fiesta Rs turbo
Postby Fraggle on Mon Apr 25, 2011 9:30 pm
knuckles :lay of my wheels you bunch of vultures ! :lol:
:bonkers: I'll lay on em if ya want me too..keep em warm an safe at night... :wink: :lol: :P
Fraggle
Postby jayrs on Mon Apr 25, 2011 9:37 pm
:lol: :lol: :lol:
fraggle, i wouldnt ban ya mate, i was just kidding :lol:
Postby Fraggle on Mon Apr 25, 2011 9:41 pm
jayrs ::lol: :lol: :lol:
:bonkers: i was lookin forward to a ban :lol: :lol: Had a clean licence for years an never been banned from anything...Except every Club an bar in my local towns :wink:
Fraggle
Postby jayrs on Mon Apr 25, 2011 10:20 pm
:lol: :lol:
Postby niracka on Tue Apr 26, 2011 5:43 pm
fudgekin pikey c**ts!!!! :lol: :lol:
niracka
Your car: E46 M3
Postby Ratspeed on Tue Apr 26, 2011 5:58 pm
You mean ''lay off my soon to be aqua foam blue wheels you vultures'' dont you? :lol:
Ratspeed
Postby jayrs on Tue Apr 26, 2011 7:29 pm
Postby Fraggle on Wed Apr 27, 2011 10:47 am
:bonkers: Morning Mr J how goes it.... :)
Fraggle
Postby jayrs on Wed Apr 27, 2011 7:40 pm
same old $hit :lol:
Postby Fraggle on Wed Apr 27, 2011 8:24 pm
Same here its like groundhog day :lol: :lol:
So you liking my sig?? :lol: :lol:
Fraggle
Postby jayrs on Wed Apr 27, 2011 10:56 pm
nice sig mate, but still its a no :lol:
Postby knuckles on Wed Apr 27, 2011 11:34 pm
Fraggle : :lol: :lol:
crawling will get you know where mate
buying him a steak dinner and a few pints normally does the trick for me :lol:
knuckles
Postby jayrs on Wed Apr 27, 2011 11:45 pm
knuckles :
wouldnt get ya a bonent though :lol: :lol:
although for another steak dinenr and a couple of pints i will give ya YOUR fcuked bonnet back :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :bonkers:
Postby Fraggle on Thu Apr 28, 2011 12:03 am
:lol: :lol: :lol: :lol: How about if i buy you's both a steak dinner,,will you's find me a bonnet??XXXXXX
Oh an Mr J theres one more post on this site about me needing a bonnet u might wanna take a look about for.....Steak dinner an a After Eight mint if u can find it...... :lol: :lol:
xxxxxxxxxxxxxxxxxxxxxxx
Fraggle
