Fiesta RS turbo
4 posts • Page 1 of 1
Fiesta RS turbo
1991 Fiesta RS turbo
H660 MEV <--- original reg
Engine:
OFAM ECU mapped by BoostMonkeys, (Megasquirt software)
2.1 ZVH (silver top bottom end, mahle pistons)
Engine has done 8000miles since build
Stage 3 head
Kent CVH 35 cam and vernier pulley
genuine Ford tappets
Currently on astra VXR injectors 470cc
Stg 2 hybrid t3
Pro alloy frount mount intercooler
Airtec Stg 2 radiator and slimline fan
Full exhaust system with 3" rolled tip
Roose complete hose set Boost/coolant/ancillary
Baileys oil breather
Braided fuel lines/turbo feed
High pressure fuel pump
Group A filter
Battery relocated to boot
ERST LSD BC gearbox
AP organic clutch
Vibratechnic engine and gearbox mounts
Suspension:
Avo coilovers
Fully polybushed
Adjustable bottom arms
Mk5 rear beam
Fully set up on hunter alignment
Team dynamics
Brakes:
Hi-spec 4 pot front
Focus RS 278mm rear
Braided lines
Body had a full repaint in 2012 has no rust but the finish wasn't what I was expecting, had both rear quarter replaced, and a new front wing
L/H wing has a little crease
Front bumper has small crack bottom
R/H rear arch has small dink in it as bonded kit back on and done clamp a touch too tight, but never got round to removing and redoing
Interior is very good, no sagging on bolsters,
This car is a good runner and with a bit of time spent sorting out the small issues/completing the build could be a great example
Car is currently on private reg what I will be taking off soon
Car is currently mapped up to 180hp at 10psi boost, but at current spec can go to 240hp, mapped by Rob at Boostmonkeys.
Car is located in Essex, Colchester
Can contact me on 07818400724
Looking for £4000
pictures: http://www.gumtree.com/p/ford/fiesta-rs ... 1105937299
Many thanks
Engine:
Stage 3 head
Stg 2 hybrid t3
Group A filter
ERST LSD BC gearbox
AP organic clutch
Suspension:
Avo coilovers
Fully polybushed
Mk5 rear beam
Team dynamics
Brakes:
Hi-spec 4 pot front
Focus RS 278mm rear
Braided lines
Looking for £4000
Many thanks
- gleggy01
Re: Fiesta RS turbo
I'm in colchester never seen this bad boy before ?
- Mattious
- Your car: Fiesta rs turbo
Re: Fiesta RS turbo
Surprised, been in Colchester for 7 years 5 of which are me, was off road for a couple of years but wasn't used as a daily.
- gleggy01
Re: Fiesta RS turbo
I've only been here 2 years I'm up on the garrison , I'll keep me eyes open , u may see me floating around in my black fez
- Mattious
