fiesta si pas..... to non power steering
7 posts • Page 1 of 1
hi ive got a fiesta si 2.0 16v and the steering rack is leaking very badly and as it has been sitting in a garage for a few months all power steering fluid has leaked out.
i want to now convert the car to have no power steering and have a manuel steering rack etc ( aka less likey to have leaks)
im not sure what i need to do the full conversion
all i know is xr2i steering rack and a xr2i 1.8 16v alternator bracket, what else do i need?and what fiesta do i need it from?
i also want to keep the steering wheel airbag on the car if i can?
cheers phil
cheers phil
- fiestasiphil
Re: fiesta si pas..... to non power steering
will need a none power steering rack and also a none power steering coloumb.
Have got both of these for sale actually
you will also need a none power steering bracket from either a 1.6 or 1.8 zetec engine from either a fiesta or escort.
Also will need the alt belt for a none power steering car.
then you will just have to un plumb all of the bits for the power steering like the cooler etc and remove and swap bits over.
job done.
job done.
- xrsi
- XR(ustyAtTheMo)SI
awesome, so far all i have is the 1.8 16v xr2i alternator bracket. so with the manuel column, can i still keep the airbag steering wheel? how much would u want for the rack and column?
- fiestasiphil
fiestasiphil :awesome, so far all i have is the 1.8 16v xr2i alternator bracket. so with the manuel column, can i still keep the airbag steering wheel? how much would u want for the rack and column?
yeah can still keep aibag wheel
pm me and will come to an agreement
- xrsi
- XR(ustyAtTheMo)SI
Jus read this and it raised a question 4 me. Whats so bad about keepin old rack and jus removin all the other gubbins and cappin off the pipe's on the rack?
looks $hit goes good
- FezzyGTI
- Your car: Mk5 zetecs 2.0 ITB's
FezzyGTI :Jus read this and it raised a question 4 me. Whats so bad about keepin old rack and jus removin all the other gubbins and cappin off the pipe's on the rack?
have you tried steering with the engine off? Thats why
- dontpannic
Yeah i hav and its easy once you empty the fluid out and cap it off cos its what i hav done wi mine.
- FezzyGTI
