fiesta si turbo( Small Update )
Postby russ_si on Thu Nov 16, 2006 11:56 pm
Hello,
Thort id show you all how my fiesta came to be what it is to day.
It stared out life as a 1.4cvh fiesta si which iv had for about two and a half
years now its still my 1st car allways liked si's :)
To cut a long story etc....
Iv allways joked/dreamed of putting a rs turbo engine in it and after going to FITP this year(my 1st show) and seeing all the nice cars i thort why not.
I got my self a very rusty rs turbo cheap to use as a donor car
and just after going to ford fair i booked some time off work and got to, well work :lol:
1st day started taking the engine out of the rs
Going down
Out
Hole
Found the hardest bit was trying to get the abs off and out the way :x
Next job was to get the engine reddy to go into my car
Fitting power steering pump and cleaning/painting replacing broken bits
ERST gearbox
Buy this time i had the engine out of my car dont have pics of this dont
know why must have been to busy :)
Spot the hand.
[img]http://www.fiestaturbo.com/forums/gallery/russ_sigsgshgpp[.JPG[/img]
Engine going in
Its in!! :D :D at this point i was so happy just kind off looked back at
thort YES iv done it :lol: :lol: :lol: still a long way to go tho..
Thats it for now i will update the rest later,
Let me know what you think iv miss out some bit cos it would just be to
long if i put every thing in.
Thank for looking,
Russell.
russ_si
Postby MAD_Adamski on Fri Nov 17, 2006 12:55 am
wicked keep it coming!
MAD_Adamski
Postby purple_fiesta on Fri Nov 17, 2006 1:20 am
Love it, allways nice to see a chv turbo Si instead of the usual 2ltr 8)
6 Point Safety Devices Cage.
purple_fiesta
Postby knuckles on Fri Nov 17, 2006 1:57 am
looking sweet .... :Q
i got to attempt fitting a rs engine on saturday.
Bring on the recaro ! :P
knuckles
Your car: Fiesta Rs turbo
Postby adz on Fri Nov 17, 2006 2:48 am
:Q tidy
might get my arse in gear and put my new engine in my mk3 :Q
does the 1.4cvh loom plug straight in? or did u swap looms aswell?
adz
Postby heeman10 on Fri Nov 17, 2006 1:12 pm
Glad you bought one with a proper turbo on the front too ;) Keep it coming!
Postby Bkjames on Fri Nov 17, 2006 1:29 pm
Looks nice mate :Q :Q :Q
Brian
Bkjames
Postby jayrs on Fri Nov 17, 2006 5:25 pm
nice one mate, bet ya wouldnt get that power steering pump on with a T2 :lol: :lol:
Postby russ_si on Fri Nov 17, 2006 6:21 pm
Your right jayrs theres no way you would get the pump in there with a t2
lots off room with a t3 tho or as heeman puts it a "proper turbo" :lol:
As for the looms iv used the rs engine loom and the si interior loom the si loom looks much the same as the rs one but sure all the pins would be wrong for the ecu.
Knuckles good luck on fitting your engine.
Thank for all you comments update is on its way.
Russell.
russ_si
Postby jayrs on Fri Nov 17, 2006 6:22 pm
proper turbo :lol: :lol:
Postby heeman10 on Fri Nov 17, 2006 6:26 pm
jayrs :proper turbo :lol: :lol:
Postby jayrs on Fri Nov 17, 2006 6:42 pm
:P
Postby jonosi on Fri Nov 17, 2006 7:36 pm
nice stuff there
keep us updated on yer progress
Jon
jonosi
Your car: Ford Focus 1.6 Ti-Vct
Car: 2005 Ford Focus
Postby chris-fiesta on Fri Nov 17, 2006 9:40 pm
looking good m8... hope it all oges well!
got anymore pics of the si?
chris-fiesta
Postby russ_si on Fri Nov 17, 2006 11:44 pm
Back to it.
By this time i had run out of time off work so every thing was done in the eveings and at weekends which is why its taken so long to do.
Or so why i didnt put this up when i was doing it just didnt have time.
Inlet manifold going on and turbo
Power steering bottle, had to move this from buy the brake servo to the inner wing because i didnt want to run all the hoses past the hot turbo
and really just seems esayer having it there.
Rest off the stuff going in not really that hard just takes time had to cut
and join some off the water hoses to fit around the p/s pump.
Air fillter on
Rad and intercooler fitted had to cut a bit away to clear the fan.
Tank painted black then fitted with frst fuel pump
Put the drive shalfs back in used the si ones as the hub end is bigger on
the si's (30mm nut on an rs to 32mm on si's) same size gearbox end.
Then came in my view the hardest bit the wiring :aaah: this in its self
took about a week and a half.
I had fitted the rs engine loom into the car and left the si interior loom
the problem came when i went to plug the looms together.
Cant remember this exactly so dont hold me to it but the si loom had
some thing like 12pins onit and the rs 7pins and there all diffrent colours
So started looking at all the diagrams but this wasnt really any help as
they didnt show this plug so i started taking the looms apart and fine out
what each one did one by one.
Found out a lot of the si ones werent needed for the rs loom and a lot of
them were just current returns so conected the ones that i needed put some petrol init and tryed my luck, after terning it over for ages i still
wouldnt start so swaped over the current returns and it started :D :D
Thats about it sure iv miss bits out just ask if you have any questions.
Still finshing it off now im being really picky about it because i want to get
every thing just wright befor its back on the road so still lots off updates to
come.
This is it as off a few weekends ago
Now with pace cooler :wink:
Thanks again
Russell.
russ_si
Postby jayrs on Fri Nov 17, 2006 11:55 pm
nice one mate
take it yuo fitted the alternator at the back then?
and used what pully for the bottom mate to run the belts?
Postby russ_si on Sat Nov 18, 2006 12:13 am
No the alternator is fitted under the p/s pump same as i was on the old
engine used the pully of that as well, belt is 6pk by 937 or so and runs
around the out side of them all.
Can get a pic if you want?
russ_si
Postby Ghost on Sat Nov 18, 2006 12:14 am
absolute quality matey, and keeping the PAS :D
although i hate PAS im sure you dont, and good on you for sorting it out. :)
Ghost
Postby jayrs on Sat Nov 18, 2006 12:32 am
russ_si :No the alternator is fitted under the p/s pump same as i was on the old
yeah please mate, would be good to see how its set up :)
Postby russ_si on Sat Nov 18, 2006 10:12 pm
Ok try get some tomorrow for you.
russ_si
Postby jayrs on Sat Nov 18, 2006 10:35 pm
no rush mate, when ever you have time mate
Postby Xr_Dub on Sun Nov 19, 2006 3:17 pm
Good stuff Russ :Q
Postby russ_si on Sun Nov 19, 2006 5:45 pm
Alternator, PAS pump and bottom pully. Hope this is ok hard to get a good pic of it all.
Let me know if you want any more.
I got a new exhaust as well the other week,
mongoose system only got it back the last weekend after having the T3 down pipe fitted. #
Very happy with it fits really well and sounds ace :aviator:
Also fitted my swirl pot.
Russell.
russ_si
Postby jayrs on Sun Nov 19, 2006 5:59 pm
i see, wonder if a p/s pump could be fitted under the alternator on a T2'ed rs.....hmm
Postby russ_si on Sun Nov 19, 2006 6:09 pm
Sorry mate that pic is tacken from under the car looking up.
So the p/s pump would be on top of the alternator :)
russ_si
Postby jayrs on Sun Nov 19, 2006 6:22 pm
sorry mate i dont really make my self clear some times.
i ment if i was gunna fit p/s on my rs i wonder if i could fit the pump under my alternator as i still run a t2
Postby bikerlegend on Sun Nov 19, 2006 7:23 pm
looks really good, hope you keep the si bumpers and dont change them to xr or rs ones
bikerlegend
Postby russ_si on Sun Nov 19, 2006 7:37 pm
:lol: :lol: sorry.
Not sure would be very low, think you would end up hitting it.
The si bumpers will be staying on :wink:
russ_si
Postby jayrs on Sun Nov 19, 2006 7:44 pm
russ_si ::lol: :lol: sorry.
yeah prob right mate, oh well, ill stick with the electric pump idea.
thats if i fit it :lol:
Postby small_paul on Sun Nov 19, 2006 10:24 pm
hi mate nice job. just curious how much did the rs donar car cost you?
small_paul
Postby garyhurn77 on Mon Nov 20, 2006 5:45 pm
looking good nice to see a cvh turbo in an si over the 2.0!
:D :D :D :D
looks a tidy engine as well
garyhurn77
Postby AGAR on Mon Nov 20, 2006 6:35 pm
Not many Si's about with the turbo treatment.
Looking very good and the PAS is a neat touch.
Oh and if your breaking the turbo after this can i have the green stripes please?! :wink:
AGAR
Postby russ_si on Tue Nov 21, 2006 7:48 pm
small_paul:- Too much :x seeing how much rust it had in it.
AGAR:- The rs has now gone i still have all the parts off it but unsure what im doing with them
if i do end up selling them ill let you know. :)
russ_si
Postby AGAR on Tue Nov 21, 2006 8:04 pm
russ_si :small_paul:- Too much :x seeing how much rust it had in it.
Ok cheers - thanks for letting me know.
I have been searching for a full set of green stripes for AGES :lol: - cash waiting..
Just drop me a PM if you plan to sell.
Looking forward to your next updates on the project too :D
AGAR
Postby LeePFRST on Fri Nov 24, 2006 6:31 pm
good job mate, looking really nice. Glad tyo see you've taken the poxy dump valve out - chatter all the way!! :D
Keep up the good work
Escort GTI Turbo
LeePFRST
Car: 1990 Ford Fiesta RS Turbo
