fiesta st170 turbo : Member's Gallery - Page 9 | Fiesta Forums
fiesta st170 turbo
Re: fiesta st170 turbo
Postby andymcd on Sun Feb 21, 2010 10:41 pm
looks good mate, what turbo are u using?
andymcd
Postby crazycage on Sun Feb 21, 2010 10:49 pm
andymcd :looks good mate, what turbo are u using?
gt2871.86 trim 56. (the biggest 2871) :) hoping to max it very soon...
crazycage
Postby luca on Sun Feb 21, 2010 10:51 pm
Whens the next pod trip mate ?
luca
Postby crazycage on Mon Feb 22, 2010 8:32 am
luca :Whens the next pod trip mate ?
central day :D
crazycage
Postby FRSJON on Mon Feb 22, 2010 9:25 pm
crazycage :
central day :D
cant wait,going to be awesome... :Q :Q :Q
FRSJON
Postby crazycage on Thu Feb 25, 2010 10:25 pm
few more snap's , new dash flocked in a custom grey ,work was done by raj @ autoflock :D
crazycage
Postby crazycage on Thu Feb 25, 2010 10:35 pm
and some more lol, box is now full of oil and made a pipe for my new air filter :D .
some nice new stainless steel cap head bolts for the top mounts :D
crazycage
Postby jonyb4 on Fri Feb 26, 2010 4:53 am
awsome thread mate, such an inspiring build, really shows what can be done to a fiesta :Q
couldnt clean the tank need a new one
btw i got a nice and clean header tank if you throw me a £7 ill pop it in the post for you soon as :Q
Postby creator on Fri Feb 26, 2010 12:30 pm
someones been busy 8) lol looks spot on mate.dash looks sweet been hearing really good things about that company and from the pics i can see why.
you been out mapping yet then mate?
creator
Postby crazycage on Fri Feb 26, 2010 5:50 pm
creator :someones been busy 8) lol looks spot on mate.dash looks sweet been hearing really good things about that company and from the pics i can see why.
out tonight mate :D
crazycage
Postby crazycage on Fri Feb 26, 2010 11:29 pm
had it out for its first run since oct last year, on new injectors and ecu ect and all is fine boost upto 0.6bar :o more to come and soon :)
crazycage
Postby jonyb4 on Fri Feb 26, 2010 11:42 pm
:Q
Postby dangerousdave on Fri Feb 26, 2010 11:52 pm
sounds sweet mate :) weres the video? lol :D
dangerousdave
Postby Dave G fsi on Sat Feb 27, 2010 6:47 pm
Looking good mate :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Postby luca on Sat Feb 27, 2010 7:51 pm
Are you strapping to the dyno to see what power she is running at.
luca
Postby crazycage on Sat Feb 27, 2010 11:43 pm
luca :Are you strapping to the dyno to see what power she is running at.
yes mate will be on a dyno as soon as the boost is back to where i want it lol :) .
but f**k me it flys on .6 bar :o
p-s not that im that bothered what it makes as long as its 350+ :o
crazycage
Postby cowie20 on Sat Feb 27, 2010 11:59 pm
350+ hell yeah :Q
cowie20
Postby creator on Sun Feb 28, 2010 2:38 am
nice one mate sounding all good so far :D
creator
Postby crazycage on Sun Feb 28, 2010 12:53 pm
forgot to say im testing a new head gasket its a ford part and 1.8mm thick has dropped my cr from 8-8-1 down to 8-3-1,will see if its any good but it should be as its basicaly the same as the focus st and rs but a little thicker :)
crazycage
Postby luca on Sun Feb 28, 2010 1:01 pm
whats it off then mate..
luca
Postby cowie20 on Sun Feb 28, 2010 1:12 pm
hey mate did you fit the sub frame back on your car? asking as i cant fit mine due to exhaust and when i looked back at your pictures when you had the st170 engine it doesnt look like you have fitted it.
cowie20
Postby crazycage on Sun Feb 28, 2010 1:16 pm
luca :whats it off then mate..
its just a 2.0l zetec /st170 gasket that ford use when the head and block have been skimmed a bit too far ,a friend in fords told me about it, not Manny people know there is such a gasket i needed the part nomber to get it as the tech gay didnt know about it lol.
crazycage
Postby crazycage on Sun Feb 28, 2010 1:18 pm
cowie20 :hey mate did you fit the sub frame back on your car? asking as i cant fit mine due to exhaust and when i looked back at your pictures when you had the st170 engine it doesnt look like you have fitted it.
do you mean the brace that links the wishbones then no i havent tryed to fit it but i will in the summer :)
crazycage
Postby cowie20 on Sun Feb 28, 2010 1:44 pm
yeah the brace mate, am thinking cutting mine and making a new bit to go under exhaust, exhaust is bang on in line with it or do you think i could just space the brace down with 1" steel blocks between the brace and floor, if you know what i mean.
cowie20
Postby HCS PIMP on Sun Feb 28, 2010 4:45 pm
would that not put more stain on the bolts ??
thinking about it so long as the bolts and threads are good nick should be ok
just use some washers or some 15mm thick sheet metal
HCS PIMP
Postby cowie20 on Sun Feb 28, 2010 5:18 pm
yeah true, ive used just solid brass spacers about 15mm. its temp tho as its all i had, ill get 15mm bar and weld it to the brace and re drill the holes. should be solid enough
cowie20
Postby luca on Sun Feb 28, 2010 6:12 pm
Ive retained the lower brace between wishbones and have 1inch alloy spacers.
There is no extra strain on the bolts.. aslong as you use longer high tensile bolts.
luca
Postby HCS PIMP on Sun Feb 28, 2010 6:13 pm
you thought could be a problem with the waste gate or actuator causing the low boost ?? or maybe the map sensor
HCS PIMP
Postby crazycage on Sun Feb 28, 2010 7:29 pm
HCS PIMP :you thought could be a problem with the waste gate or actuator causing the low boost ?? or maybe the map sensor
i havent got a boost problem mate :D i always start mapping with the lowest boost i can run then start turning it up till its where i want it .
crazycage
Postby creator on Mon Mar 01, 2010 11:03 pm
you managed to get more mapping in mate? has the boost been pushed up yet? :devil: :devil:
creator
Postby crazycage on Tue Mar 02, 2010 9:33 pm
creator :you managed to get more mapping in mate? has the boost been pushed up yet? :devil: :devil:
no mate not yet im in no rush i have 6 weeks till central day :)
crazycage
Postby cowie20 on Tue Mar 02, 2010 10:04 pm
mines is up and running now mate, cant get rev counter to work, i connected wire that went to ofab ecu to the gotech, but doesnt work? you any ideas as you were running gotech before was you.
cheers :Q
cowie20
Postby crazycage on Wed Mar 03, 2010 8:50 am
cowie20 :mines is up and running now mate, cant get rev counter to work, i connected wire that went to ofab ecu to the gotech, but doesnt work? you any ideas as you were running gotech before was you.
cheers :Q
ahh cool mate made up for you. take the wire from the clocks, iirc its the green one and run it too any of the two outside wires on the plug for your coil pack ,thats how mine has been for years :D
crazycage
Postby creator on Wed Mar 03, 2010 9:11 am
crazycage :
6weeks :o god i need to keep track of time lol though i had longer than that haha,do you know what boost your going to be runnin then mate or are you just going to keep increasing till you cant go no more? lol
creator
Postby cowie20 on Wed Mar 03, 2010 9:36 am
nice one mate will do that today. cheers :D
cowie20
